Parental control of ipads
Wed Aug 30, 2017 10:32 am
Gusten offline
Hi, anyone have any cool Idea of shut down iPads as a parent control from indigo.
I tried an iOS app called OurPact and from it I could shut down controlled devices, it would be cool if there was a way to do this from indigo somehow.
/Martin
Wed Aug 30, 2017 12:24 pm
Re: Parental control of ipads
Do you want to totally shut them down, or would just disabling the internet on them be good enough?
Wed Aug 30, 2017 12:34 pm
Gusten offline
Total shutdown would be the preferd way, but disable internet is would be an option. I have UniFi wifi so maybe there is a way to connect those iPads to a separate network and turn that of.
Thu Aug 31, 2017 12:34 am
Vangelis offline
Have a look at the UniFi Controller API. You could put your kids iPads on their own SSID and disable that, or there might be a way to add a routing statement to 127.0.0.1
Vangelis
Thu Aug 31, 2017 9:17 am
virgahyatt offline
I would check to see if they had Timed Access Control for unifi. You just designate what hours that particular mac address is allowed access. No need for a different SSID.
Also, I would suggest locking them instead of shutting down. Updates and backups will typically occur overnight when plugged in, connected to wifi and locked.
