[~] tornado% telnet 10.0.1.222 5000
Trying 10.0.1.222...
Connected to 10.0.1.222.
Escape character is '^]'.
[~] tornado% telnet
telnet> set termdata
Will print hexadecimal representation of terminal traffic.
telnet> open 10.0.1.222 5000
?> 0x0 ff
?> 0x0 fe
?> 0x0 ff
?> 0x0 ff
?> 0x0 ff
?> 0x0 ff
?> 0x0 ff
?> 0x0 fe
?> 0x0 fe
?> 0x0 f7
?> 0x0 df
?> 0x0 eb
?> 0x0 eb
?> 0x0 df
?> 0x0 ff
?> 0x0 fe
?> 0x0 ff
?> 0x0 fc
?> 0x0 ff
?> 0x0 fe
~> 0x0 7e
?> 0x0 f8
?> 0x0 ff
farberm wrote:tornado:
I am happy to help but would need alittle help to provide whatever information you need. I am connected only thru the screenlogic adapter. I do not have a 485-RS232 connection setup.
Just let me know what you need from me.
farberm wrote:The new screenlogic2
Basic Acknowledge Packet: (Sent from LX3xxx to controller)
Byte 0 SYNC BYTE 0 0xFFh (always)
Byte 1 SYNC BYTE 1 0xAAh (always)
Byte 2 Destination Address 0x0Fh (always)
Byte 3 LX3xxx Version 0x??h (see definitions)
Byte 4 OpCode 0x02h (always)
Byte 5 Info Field Length 0x10h (always)
Byte 6 Minutes 0x00h - 0x3Bh (see definitions)
Byte 7 Hours 0x00h - 0x17h (see definitions)
Byte 8 Primary Equipment 0x??h (see definitions)
Byte 9 Secondary Equipment 0x??h (see defiintions)
Byte 10 Delay/Heat Source 0x??h (see definitions)
Byte 11 Water Temperature 0x??h (see definitions)
Byte 12 Solar Temperature 0x??h (see definitions)
Byte 13 Spa Water Temp 0x??h (3830 only - see definitions)
Byte 14 Spa Solar Temp 0x??h (3830 only - see definitions)
Byte 15 Desired Pool Temp 0x??h (see definitions)
Byte 16 Desired Spa Temp 0x??h (see definitions)
Byte 17 Air Temperature 0x??h (see definitions)
Byte 18 Spare/Future Use 0x??h (see definitions)
Byte 19 Spare/Future Use 0x??h (see definitions)
Byte 20 Equip/Sensor Stat 0x??h (see definitions)
Byte 21 Product Type/Stat 0x??h (see definitions)
Byte 22 Hi Byte of Checksum 0x??h (see definitions)
Byte 23 Lo Byte of Checksum 0x??h (see definitions)
Radjin wrote:Using the plugin with Pentair's RS232 Serial interface; is there a list of the items you can control and how they can be controlled (example: intelliflo pump 0-100% or Heating: 80-106 degrees)?
Radjin wrote:Yes I read the protocol in the guide. I was hoping I was missing something. I wonder why they offer heat but not pump speed control? Does anyone know of a way to use indigo and control pump speed.
Users browsing this forum: No registered users and 30 guests
