I am looking to hook up my Pentair i-link to my mac. What are you using to connect from the serial port of the link?
A serial to usb adapter or
global cache serial to ethernet? or
something else?
farberm wrote:Where does it inform me of the port. I do not think I saw that anywhere
farberm wrote:I am using the I- link with a global cache its H flex poe device with a serial connector with the settings above for baud etc
I have reloaded the plugin after changing to port 4999
Is there a specific command thru terminal that I can use to test
The communication that you can recommend?
I have no firewall to ended in so that should not be an issue
