- Posted on
Thu Mar 17, 2016 2:37 am
mwoodage
offline
Hi Nick,
Thanks for the updated PlugIn, its working, sort of. It seams to error a few times and then pick up the data, then error again. I've attached the log to this reply and happy to send more details if required, just let me know.
Thanks for updating,
Martin
2016-03-17 08:21:23.985 Application Upgrading plugin "NetworkOwl" to newer version 1.4 (previous version moved to trash)
2016-03-17 08:21:24.024 Application Loading plugin "NetworkOwl 1.4"
2016-03-17 08:21:24.026 Application Starting plugin "NetworkOwl 1.4" (pid)
2016-03-17 08:21:25.304 Application Started plugin "NetworkOwl 1.4"
2016-03-17 08:21:25.315 NetworkOwl NetworkOwl: starting listener on port 22600
2016-03-17 08:21:27.865 NetworkOwl Error Error in plugin execution runConcurrentThread:
File "plugin.py", line 152, in runConcurrentThread
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/NetworkOwl.indigoPlugin/Contents/Server Plugin/NetworkOwl.py", line 107, in runProtocol
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/NetworkOwl.indigoPlugin/Contents/Server Plugin/NetworkOwl.py", line 167, in processDataPacket
<type 'exceptions.IndexError'>: list assignment index out of range
2016-03-17 08:21:27.866 NetworkOwl Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
2016-03-17 08:21:37.865 NetworkOwl NetworkOwl: starting listener on port 22600
2016-03-17 08:21:39.040 NEST Home 3 Hallway Thermostat ambient_temperature_c updated to 19.0
2016-03-17 08:21:39.943 NetworkOwl Error Error in plugin execution runConcurrentThread:
2016-03-17 08:21:39.944 NetworkOwl Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
2016-03-17 08:21:49.947 NetworkOwl NetworkOwl: starting listener on port 22600
2016-03-17 08:22:03.905 NetworkOwl Error Error in plugin execution runConcurrentThread:
2016-03-17 08:22:03.906 NetworkOwl Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
2016-03-17 08:22:13.908 NetworkOwl NetworkOwl: starting listener on port 22600
2016-03-17 08:22:15.885 NetworkOwl Error Error in plugin execution runConcurrentThread:
2016-03-17 08:22:15.887 NetworkOwl Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
2016-03-17 08:22:25.886 NetworkOwl NetworkOwl: starting listener on port 22600
2016-03-17 08:22:28.859 NetworkOwl NetworkOwl: generating watts: 819
2016-03-17 08:22:28.860 NetworkOwl NetworkOwl: exporting watts: 0
2016-03-17 08:22:41.153 NEST Home 3 Hallway Thermostat ambient_temperature_c updated to 19.0
2016-03-17 08:22:51.865 NetworkOwl Error Error in plugin execution runConcurrentThread:
2016-03-17 08:22:51.866 NetworkOwl Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
2016-03-17 08:23:01.866 NetworkOwl NetworkOwl: starting listener on port 22600
2016-03-17 08:23:03.865 NetworkOwl Error Error in plugin execution runConcurrentThread:
2016-03-17 08:23:03.866 NetworkOwl Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
2016-03-17 08:23:13.865 NetworkOwl NetworkOwl: starting listener on port 22600
2016-03-17 08:23:15.865 NetworkOwl Error Error in plugin execution runConcurrentThread:
2016-03-17 08:23:15.866 NetworkOwl Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
2016-03-17 08:23:25.870 NetworkOwl NetworkOwl: starting listener on port 22600
2016-03-17 08:23:29.000 NetworkOwl NetworkOwl: generating watts: 836
2016-03-17 08:23:29.001 NetworkOwl NetworkOwl: exporting watts: 0
2016-03-17 08:23:39.865 NetworkOwl Error Error in plugin execution runConcurrentThread:
2016-03-17 08:23:39.866 NetworkOwl Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
2016-03-17 08:23:43.333 NEST Home 3 Hallway Thermostat ambient_temperature_c updated to 19.0
2016-03-17 08:23:49.870 NetworkOwl NetworkOwl: starting listener on port 22600
2016-03-17 08:23:52.040 NetworkOwl Error Error in plugin execution runConcurrentThread:
