Swancoat wrote:v2.0.2 posted with fix for Zone Device state.
Strange, cleaned out metadata but for some reason I still get the error below. Also I noticed the speakAnnouncement stopped working (error picture attached).
Swancoat wrote:So that first bug looks like the same one as the first round where some unusual characters or something are messing up the encoding. I added a Unicode-decode to the metadata, hopefully that helps.
Second one is related to the state reporting problem you mentioned earlier. Somewhere between getting rid of the two device types (or maybe the newer plugin API) the state was being treated more as a string than a boolean. That should be corrected now as well now.
(Both bugs seemed to trip on debug logging lines ironically).
Version 2.0.3 posted now.
Swancoat wrote:v2.0.4 posted.
Swancoat wrote:Hmmm, that could be two things. Seems like it's not an error, but that the plugin just isn't getting it from Shairport Sync.
Has the source been continuously connected to Shairport Sync? The DACP data only gets transmitted to the NuVo plugin when a source connects, so even though you may stay connected to the Shairport Sync if you reload the NuVo plugin it loses that data. Just disconnect the audio source and reconnect. Or try a different source (computer, iPhone).
It's likely that you've done that. You can see if Shairport Sync has the data itself. There are actions in that plugin to also issue PREV or NEXT. See if you can do it from the Shairport Sync plugin.
If you can't do it from there either, check if you're running the latest version of Shairport Sync on your Pi or whatever it's running on. I did have an issue when I was developing this where the DACP port just wasn't showing up in Shairport Sync, but the developer issued a bug fix for that.
Swancoat wrote:No clue really? Looks like it's referencing something inside the serial port module?
Are you connecting via serial or the Ethernet port?
