- Posted on
Wed Aug 24, 2022 10:47 am
farberm
offline
I do not have any triggers set....
Here is the info from debug mode..
Aug 24, 2022 at 12:35:58 PM
Caddx Security System processing message: Partition Status Message, partition: 1, length: 9
Caddx Security System Debug partitionStatusMessage: partition status message dictionary: ['09', '86', '00', '20', '00', '00', '40', '01', '00', 'c2']
Caddx Security System Debug partitionStatusMessage: partition status message bit map dictionary: ['00100000', '00000000', '00000000', '01000000', '00000001', '00000000', '11000010']
Caddx Security System update partition status: device state records successfully updated with partition status message: partition: 1
Caddx Security System update keypad status: device state records successfully updated with partition status message: keypad: 1
Caddx Security System Debug sendMsg: >> sent message: 1d, ACK, bytearray(b'\x01\x1d\x1e\x1f')
Caddx Security System processing message: Partitions Snapshot Message, partition 1 - 8, length: 9
Caddx Security System Debug partitionSnapshotMessage: snapshot partition message dictionary: ['09', '87', '01', '02', '02', '02', '02', '02', '02', '02']
Caddx Security System Debug partitionSnapshotMessage: snapshot partition message bit map dictionary: ['00000001', '00000010', '00000010', '00000010', '00000010', '00000010', '00000010', '00000010']
Caddx Security System update partition snapshot: device state records successfully updated with partition snapshot message: all active partitions:
Caddx Security System Debug updateAlarmDisplay: display message byte: 00000001
Caddx Security System partition 1: 'Not Ready!'
Caddx Security System keypad 1: LCD message line 1: "System Not Ready", LCD message line 2: "For help, press ->"
Caddx Security System processing message: Zone Status Message, zone: 5, length: 8
Caddx Security System Debug zoneStatusMessage: zone status message dictionary: ['08', '84', '04', '01', '58', '13', 'e0', '01', '00']
Caddx Security System Debug zoneStatusMessage: zone status message bit map dictionary: ['00000001', '01011000', '00010011', '11100000', '00000001', '00000000']
Caddx Security System Debug zoneStatusMessage: zone group type 'no zone group match', no zone group match dictionary: '010110000001001111100000'
Caddx Security System update zone status: device configuration ui records successfully updated with zone status message: zone: 5
Caddx Security System update zone status: device state records successfully updated with zone status message: zone: 5
Error device "Caddx_zone 005 - MOTION DETECTOR" state key onOffState not defined (ignoring update request)
Caddx Security System zone 005: 'Triggered!' {MOTION DETECTOR }
Caddx Security System update zone status: zoneState device state value successfully updated with zone status message: zone: 5
Caddx Security System processing message: Zones Snapshot Message, block address: 0, group: zone 1 - zone 16
Caddx Security System Debug zoneSnapshotMessage: zone snapshot message dictionary: ['0a', '85', '00', '00', '00', '01', '00', '00', '00', '80', '00']
Caddx Security System Debug zoneSnapshotMessage: zone snapshot message bit map dictionary: ['00000000', '00000000', '00000001', '00000000', '00000000', '00000000', '10000000', '00000000']
Caddx Security System Debug partitionStatusMessage: partition status message dictionary: ['09', '86', '00', '20', '00', '00', '40', '01', '04', 'c2']
Caddx Security System Debug partitionStatusMessage: partition status message bit map dictionary: ['00100000', '00000000', '00000000', '01000000', '00000001', '00000100', '11000010']
Caddx Security System Debug partitionSnapshotMessage: snapshot partition message dictionary: ['09', '87', '03', '02', '02', '02', '02', '02', '02', '02']
Caddx Security System Debug partitionSnapshotMessage: snapshot partition message bit map dictionary: ['00000011', '00000010', '00000010', '00000010', '00000010', '00000010', '00000010', '00000010']
Caddx Security System Debug updateAlarmDisplay: display message byte: 00000011
Caddx Security System partition 1: 'Disarmed!'
Caddx Security System keypad 1: LCD message line 1: "System Ready", LCD message line 2: "Type code to arm"
Caddx Security System Debug zoneStatusMessage: zone status message dictionary: ['08', '84', '04', '01', '58', '13', 'e0', '00', '00']
Caddx Security System Debug zoneStatusMessage: zone status message bit map dictionary: ['00000001', '01011000', '00010011', '11100000', '00000000', '00000000']
Caddx Security System zone 005: 'Normal!' {MOTION DETECTOR }
Caddx Security System Debug zoneSnapshotMessage: zone snapshot message dictionary: ['0a', '85', '00', '00', '00', '00', '00', '00', '00', '80', '00']
Caddx Security System Debug zoneSnapshotMessage: zone snapshot message bit map dictionary: ['00000000', '00000000', '00000000', '00000000', '00000000', '00000000', '10000000', '00000000']
Aug 24, 2022 at 12:36:21 PM
Could it be one of my config settings for #210 or #211 segment
- caddx.jpg (493.41 KiB) Viewed 2161 times
