TP-Link Plugin v 0.9.3
Tue Jun 01, 2021 5:42 am
changeagent offline
Re: TP-Link Plugin v 0.9.3
I had been running version 0.2.0 of the plug-in that was working fine with a few HS110 smart plugs. I saw that a new version (0.9.5) was available and tried running it. I received errors. I then enabled version 0.8. Similar error. I tired 0.9.6, too. Errors. In the meantime, version 0.2.0 is back up and running fine for me, but I wanted to provide you with this feedback:
Starting plugin "TP-Link Device 0.2.0" (pid 13249)
Started plugin "TP-Link Device 0.2.0"
TP-Link Device sent "TP-Link Plug" on
TP-Link Device sent "TP-Link Plug" off <-Plug works fine with version 0.2.0
Jun 1, 2021 at 7:18:32 AM
Stopping plugin TP-Link Device (pid 13249)
Stopped plugin TP-Link Device
Upgrading plugin TP-Link Device to newer version 0.8.0 (previous version moved to trash)
Loading plugin "TP-Link Device 0.8.0"
Starting plugin "TP-Link Device 0.8.0" (pid 13263)
TP-Link Device Log level set to info
Started plugin "TP-Link Device 0.8.0"
TP-Link Device Polling started for TP-Link Plug@10.0.1.16.
TP-Link Device Error (tpl_polling.py:run:353): Error attempting to update TP-Link Plug: 'power_mw'. Will try again in 10 seconds
TP-Link Device Error (tpl_polling.py:run:353): Error attempting to update TP-Link Plug: [Errno 57] Socket is not connected. Will try again in 10 seconds
TP-Link Device Error (tpl_polling.py:run:118): TP-Link Plug connection failed with ([Errno 57] Socket is not connected)
TP-Link Device Error (tpl_polling.py:run:353): Error attempting to update TP-Link Plug: 'system'. Will try again in 10 seconds
TP-Link Device Error (tpl_polling.py:run:348): Unable to update TP-Link Plug: after 10 attempts. Polling for this device will now shut down. ('power_mw')
Jun 1, 2021 at 7:20:54 AM
Stopping plugin TP-Link Devices (pid 13263)
Stopped plugin TP-Link Devices
Upgrading plugin TP-Link Devices to newer version 0.9.5 (previous version moved to trash)
Loading plugin "TP-Link Devices 0.9.5"
Starting plugin "TP-Link Devices 0.9.5" (pid 13290)
TP-Link Devices Log level set to info
Started plugin "TP-Link Devices 0.9.5"
TP-Link Devices Polling started for TP-Link Plug@10.0.1.16.
TP-Link Devices Error (tpl_relay_poll.py:run:316): Error attempting to update TP-Link Plug: 'power_mw'. Will try again in 10 seconds
TP-Link Devices Error (tpl_relay_poll.py:run:311): Unable to update TP-Link Plug: after 10 attempts. Polling for this device will now shut down. ('power_mw')
TP-Link Devices Polling stopped for TP-Link Plug@10.0.1.16.
Jun 1, 2021 at 7:23:38 AM
Stopping plugin TP-Link Devices (pid 13290)
Upgrading plugin TP-Link Devices to newer version 0.9.6 (previous version moved to trash)
Loading plugin "TP-Link Devices 0.9.6"
Starting plugin "TP-Link Devices 0.9.6" (pid 13316)
Started plugin "TP-Link Devices 0.9.6"
TP-Link Devices Error (tpl_relay_poll.py:run:322): Error attempting to update TP-Link Plug: 'power_mw'. Will try again in 10 seconds
TP-Link Devices Error (tpl_relay_poll.py:run:317): Unable to update TP-Link Plug: after 10 attempts. Polling for this device will now shut down. ('power_mw')
Reverted back to 0.2.0 and all is fine...
Tue Jun 01, 2021 8:46 am
jtburgess offline
Thanks. Something is wrong with the polling.
I’ll take a look and get back to you. ... but I can’t get to it until Thursday.
— john
Fri Jun 04, 2021 11:18 am
jtburgess offline
The reason 0.2.0 works is that there is no polling.
[Polling is used to detect state changes outside of indigo, e.g. you turned the device on/off by hand, and monitor energy usage.]
You're triggering the same python exception in all newer versions, something about "power_mw" which is one of the energy monitoring attributes.
My guess is that there is some attribute missing from the device state as it was created in 0.2.0.
Or you're trying to monitor energy usage, but the device doesn't actually support that feature.
Please try deleting your device and re-adding it after installing the latest update.
Since no-one else has reported this error, that adds to my suspicion.
Thanks, John
Thu Jun 24, 2021 10:54 am
vtmikel offline
John,
Any chance the plugin could support the KL430 LED lights?
I have mine working with Indigo but with a fair amount of hackery.
Mike
Fri Jul 09, 2021 4:18 pm
changeagent offline
That worked! Thank You...
Thu Oct 14, 2021 10:08 am
jenwill1 offline
I bought a KP400 to use to control an outdoor fountain. I tried to load 0.9.3 on me Indigo v 2021.1 server and it booted Indigo v 7.5 software/server. Is 0.9.3 compatible with v 2021.1 ?
Thanks and look forward to using the plugin.
Will
Thu Oct 14, 2021 11:02 am
jtburgess offline
It should be, but you should install the latest version, 0.9.8, which I AM using on v2021.1
-- John
Thu Oct 14, 2021 11:18 am
The problem is that Big Sur sometimes doesn't do file associations correctly, so rather than use the most recently installed app to open a file (in this case, the plugin), it sometimes launches an older version. The easiest fix is to delete the prior Indigo install (in your case 7.5).
Thu Oct 14, 2021 3:01 pm
jenwill1 offline
That did it, installed 0.9.8. Thanks for the help.
I had to delete all prior versions in the applications folder.
Appreciate the quick response !
Will
Mon Oct 18, 2021 9:23 am
jenwill1 offline
I received the KP400 yesterday. Breeze to setup. Am using the Indigo to schedule and Apple Bridge to have Siri/Homekit control as well instead of Google/Alexa that comes with their app. Thanks for the plugin !
Will
Mon Nov 29, 2021 7:39 am
Ramias offline
For whatever reason I have devices that sometimes miss polling and get set to offline after I think 10 consecutive polls. I have a script I run nightly to re-enable device communication for all my devices but would it be possible to add a configuration toggle to leave device communication on for every device even if it misses polling? I'd rather have the log spam than devices with communication disabled throughout the day.
If you think it may help I'm happy to look at the code and try to add it.
Wed Dec 15, 2021 5:18 pm
farberm offline
Will this work with tp-link KP125 smart wifi plug?
Tue Dec 28, 2021 10:12 am
johnpolasek offline
Since the KP400 works, I'd assume all the KP* have the same protocol although I'm only familiar with the HS and KL series. My only problem with this plugin is that he uses IP rather than MAC addresses to identify devices. It's not much of a problem at my house, but my sister has a very retarded ISP that doesn't believe anyone needs fixed IPs and forces all the devices to go through their DHCP in their router... so every time there is a power failure, all 8 of the Kasa devices I installed play musical IPs and stop working (or worse start responding to the wrong triggers) until I can get there to run the Angry IP Scanner and reconfigure them to the new reality.
Wed May 11, 2022 1:10 pm
jenwill1 offline
My 0.98 TP-Link plugin quick working... not sure what happened. I'm running Indigo 2022.1
I have a Kasa outdoor outlet, been run-in for about 9 months or so before this issue.
The error message I get when I try and turn it off/on is:
Ignored device "Fountain" action request (communication is disabled)
I have reloaded the plugin and deleted and added the device again.
Anything else to try ?
Here is the device details...
TP-Link Devices Tp-Link device report
TP-link Device Type: tplinkSmartPlug
Indigo Device Name: Fountain
IP Address: 192.168.1.244
MAC Address: 00:5F:67:10:86:AB
Device ID: 800629A4CB478794286F402A7BD29A321E4CE9D7
Alias: Fountain
Model: KP400(US)
Polling enabled: True
On state polling freq: 10
Off state polling freq: 30
Outlet Number: 1
Multiple Outlets: True
Energy reporting: False
Thanks !
Wed May 11, 2022 1:35 pm
MarcoGT offline
I also have random problems with a Kasa plug; sometimes I see communication disabled and the only thing is to unplug/plug it again (and enable the communication)
It seems that it disconnects from wifi somehow
Users browsing this forum: No registered users and 27 guests
