FluxLED / MagicHome plugin
Sun Nov 26, 2023 10:51 am
DVDDave offline
Re: FluxLED / MagicHome plugin
FlyingDiver wrote:
Same error message. Don't know if it matters but I did notice that the numbers in the Custom States box in the Device display don't update. This was true in the original Python 2 version as well.
Sun Nov 26, 2023 11:00 am
Well, I'm not signing up to fix problems that existed in the most recent Python2 version. Once we get this moved into the Indigodomo Open Source repository, you can open issues on GitHub for any problems. Maybe someone will fix them.
Sun Nov 26, 2023 11:17 am
DVDDave offline
Of course that's true. :) I was only mentioning it since it could possibly have something to do with the updating error messages. I would be happy if you stopped here and simply suppressed the error message since it doesn't seem to affect anything. I really appreciate what you've done here, Joe.
Tue Nov 28, 2023 5:20 pm
Joe, I made a note last week to look at this plugin when I got home (as I'd said I would a while ago... and didn't)!
It looks like you've included the latest flux_led module from github and fixed up the plugin to use it.
You've also used https://forums.indigodomo.com/viewtopic.php?f=134&t=19314&start=75#p182732 to add timeout parameters on two of the calls to WifiLedBulb(device.address).
Can I suggest (untested) that you do the same on the other references to the same call?
I'm suspecting the random appearance of errors, and the fixes proposed by hackintosh four years ago, were around the calls timing out - he's proposed two fixed calls with a timeout parameter but not the rest.
Peter
Tue Nov 28, 2023 5:29 pm
I'll take a look. Right now I'm waiting for it to get cloned into the Indigodomo repo.
Tue Nov 28, 2023 5:31 pm
No problem.
Thu Nov 30, 2023 11:01 am
DVDDave offline
Hi Joe,
I see that your new version is in the repo now. As expected, it still gives the same repeating error. However, I've been running with your previous version with the error suppressed and it's been working fine on the latest Indigo version. Thanks again for taking this on.
--Dave
Thu Nov 30, 2023 11:04 am
DVDDave wrote:
Hi Joe,
--Dave
Install the version in the Plugin Store. If that one is still showing the errors, file an issue using the link in the plugin store description.
Thu Nov 30, 2023 11:15 am
DVDDave offline
Will do
Thu Nov 30, 2023 11:48 am
DVDDave offline
DVDDave wrote:
Will do
Whoops, so sorry for this newb question but I can't find how to post an issue in your new fork on Github. (I assume that's the link you're talking about since the other one goes to this thread.) How do I start a new issue? Thanks.
Thu Nov 30, 2023 12:23 pm
Looks like issues are not enabled for that repo. I'll get that fixed.
Fri Dec 01, 2023 10:06 am
It's been fixed, you can submit the issue now.
Fri Dec 01, 2023 10:09 am
DVDDave offline
Done, thanks.
Tue Jan 16, 2024 6:32 am
CBowles offline
Quick and dirty fix to suppress repeating IP address error...
Replace line 103 with:
self.debugLog(f"Error updating device: {device.name}. Is the IP address {device.address} correct?")
This puts the error in the debug log so is only shows if Debug logging in enabled in the plugin config.
