Graphite data logger
Sat Dec 31, 2016 11:05 am
jh71283 offline
Hi all
I have written a plugin to log various data to Graphite. Once the data is logged in Graphite, you can use something such as Grafana to produce some nice graphs and dashboards :
Screen Shot 2016-12-31 at 16.51.49.png (98.18 KiB) Viewed 7323 times
Screen Shot 2016-12-31 at 16.52.29.png (139.22 KiB) Viewed 7323 times
You can find the plugin at: https://github.com/jh71283/IndigoGreenSkyDataLogger
... To log a variable to Graphite, simply put it into a folder called Graphite. All variables in here will be sampled once a second and sent to Graphite. It's that simple!
Sat Dec 31, 2016 3:16 pm
Re: Graphite data logger
Thanks for sharing – that does produce some very nice looking graphs!
Sun Jan 01, 2017 6:16 am
AndyVirus offline
Thanks for this!
I set up a graphite server VM using Synthesise (https://github.com/obfuscurity/synthesize) to try this out and works great.
2 things:
1) All variables in other folders do not get sent/logged to graphite (as you stated) but the ones that do not reside in a folder do, not sure if this is expected or a bug.
2) Is there a way to send ALL variables to Graphite as i already have lots of folders for Heating, blinds, movement etc and I don't want to duplicate these into a folder called graphite (with duplicate triggers) to get them into graphite.
Thanks again!
Mon Jan 02, 2017 5:56 am
jh71283 offline
Hi Andy
No, I didn't expect that to be that case. The plugin specifically looks for the Graphite folder, and then loops through the variables in that folder so I am a bit stumped on that one!
I'll have a look at some other options for which variables get sent across too.
Mon Jan 02, 2017 6:45 am
AndyVirus offline
I only found that by accident as after a fresh install of both the plugin and graphite a few variables showed up unexpectedly. I dont have many that are not in folders, i think only a few pibeacon variables are not and i dint need to graph those. I can see in your plugin.py that the folder "graphite" is defined, if trivial is there a way to define additional folders? Thats all im after really so i can graph my "heating" folder etc.
Mon Jan 02, 2017 12:58 pm
jh71283 offline
OK I have just pushed version 2.0.1 to the github repo.
I've made it a major version change as it includes breaking changes.
When you upgrade to this version, you will need to tell the plugin which variables to log, otherwise it will not log any.
Variables now have their folder name appended to them prior to being sent to Graphite, meaning that any variables you already have, will change in Grafana.
indigo.Sheep and indigo.Dog will now become indigo.Graphite.Sheep and indigo.Graphite.Dog (Because they are from the Graphite folder)
However this of course means that there is no need to put your variables in the Graphite folder at all.
Tue Jan 03, 2017 3:18 pm
blysik offline
This is very cool! However, if an Indigo variable or folder has a space in the name, you should replace that space with an underscore.
Tue Jan 03, 2017 6:58 pm
blysik offline
Any chance this plugin could implement an Action? ie, "Log a data point to graphite", you supply the namespace, and either a variable, or a value, and it sends it one off to the configured graphite server.
Wed Jan 04, 2017 1:15 am
jh71283 offline
Both good ideas, blysik!
I'll take a look.
Wed Jan 04, 2017 1:26 am
juntta offline
Or how about utilizing the SQL logger database as data source?
That way both variables & device data could be used in Graphite.
Wed Jan 04, 2017 2:27 am
jh71283 offline
My main problem with doing that is that a user then has to configure an extra system - postgres, and the SQL logger plugin.
And the other thing is that I find the schema of the SQL logger output a little odd, and incomplete.
A separate table per device / variable makes little sense to me, along with the fact that there is nowhere in that database that stores the names of the devices / variables.
I also can't remember if there is a master table containing a list of the devices / variables, or if you have to hunt the schema.
There opinions are of course, my own, and other people may love the way the database is laid out.
Wed Jan 04, 2017 10:19 am
juntta offline
I can understand your point - plugin that needs plugin which requires another plugin can be endless cycle!
Maybe some other plugin developers can give you hints how they've managed to tackle those database questions.
I think your approach is great but I wouldnt mind keeping same data in one place and avoid copying it.
Sun Jan 15, 2017 3:06 pm
sparky21 offline
This is cool. I live in graphite/grafana at my job, so its fun to see this. I'm motivated to setup an unused system to run graphite on now :-)
Sat Jan 21, 2017 9:30 am
elov offline
I want to share that I've made a fork of your plugin which includes this extended functionality:
Automatic enumeration of all indigo devices and their state values. So everything that can be casted into a float/int will be exported.
RegEx filters for both device names and state names, so I can remove or only include the devices and states I want.
So now I have an automated solution that send brightness, on/off states, curEnergyLevel and so forth for all my Z-wave devices automatically, simple set and forget without having to create any vars for each value. I even get RSSI value logged for every Wifi device connected through the Unifi plugin. :)
I'll get the code uploaded if anyone is interested with a small guide of how I setup InfluxDB and Grafana locally on my Mac mini running Indigo.
Cheers
Sat Jan 21, 2017 12:47 pm
blysik offline
Sweet!
Users browsing this forum: No registered users and 30 guests
