Page 5 of 12
Re: Ecobee Plugin
Posted:
Fri Apr 21, 2017 12:50 pm
by cwf
I'm getting this error in the logs when I try to make a change from Indigo:
File "plugin.py", line 286, in actionControlThermostat
File "plugin.py", line 340, in _handleChangeSetpointAction
ValueError: zero length field name in format
Did I do something wrong in the setup?
UPDATE: answered my own question...upgraded to Indigo 7 and it works now.
Re: Ecobee Plugin
Posted:
Wed May 17, 2017 12:38 am
by kwijibo007
Thanks for writing this plugin
I just purchased an ecobee4. Any chance this will work right off the bat?
Pete
Re: Ecobee Plugin
Posted:
Wed May 17, 2017 10:09 am
by Jann
Inasmuch as this works w/the 3, yes... Special features no. Plug in has not been updated w/Alexa features. etc.
Re: Ecobee Plugin
Posted:
Wed May 17, 2017 10:13 am
by rapamatic
I haven't looked at the code in a while, it may require a small change to recognize the ecobee4 when it gets the list of all devices from the ecobee server, but this should be a very simple change.
Regarding Alexa, I'd be very surprised if ecobee opened up any Alexa access with their API - I would think we'd need a plugin for Amazon/Alexa to accomplish that...
Re: Ecobee Plugin
Posted:
Wed May 17, 2017 4:29 pm
by kwijibo007
rapamatic wrote:I haven't looked at the code in a while, it may require a small change to recognize the ecobee4 when it gets the list of all devices from the ecobee server, but this should be a very simple change.
Thanks, the ecobee4 is on back order, as soon as it arrives I'll test and report back.
rapamatic wrote:Regarding Alexa, I'd be very surprised if ecobee opened up any Alexa access with their API - I would think we'd need a plugin for Amazon/Alexa to accomplish that...
Yeah, I don't expect so... There's an awesome Alexa plugin already
https://www.indigodomo.com/library/372/. It works brilliantly!
Re: Ecobee Plugin
Posted:
Tue May 23, 2017 7:24 am
by NewfD90
Wondering why my the plugin state eventually always becomes unauthenticated. When this happens, of course, the device control and status no longer functions.
If I re-authenticate with a new pin, all works well. For a while. And then eventually, it becomes unauthenticated again.
Anybody else experiencing this?
Re: Ecobee Plugin
Posted:
Tue May 23, 2017 7:34 am
by brlandy
I posted a patch for this earlier in the thread, January 25th. I finally got around to submitting a pull request recently so hopefully it makes it into the next release. It is a one line change to the plugin so relatively simple to do manually.
Re: Ecobee Plugin
Posted:
Tue May 23, 2017 9:47 am
by NewfD90
Got it; thanks very much!
Re: Ecobee Plugin
Posted:
Thu Jun 22, 2017 5:59 am
by NewfD90
OK, I applied the patch and all was well for a few weeks.
Unfortunately, it's become unauthenticated again.
Am I the only person seeing this all the time?
Re: Ecobee Plugin
Posted:
Thu Jun 22, 2017 8:06 am
by lsawyer
I am having the same issue. I patched the file and it continued to loose its authentication.
NewfD90 wrote:OK, I applied the patch and all was well for a few weeks.
Re: Ecobee Plugin
Posted:
Thu Jun 22, 2017 9:34 am
by NewfD90
lsawyer wrote:I am having the same issue. I patched the file and it continued to loose its authentication.
Good to know I'm not unique. Thanks!
Re: Ecobee Plugin
Posted:
Sat Jun 24, 2017 9:44 am
by blysik
I continue to occasionally lose authentication, even with the patched file also.
Re: Ecobee Plugin
Posted:
Sat Jun 24, 2017 9:45 am
by rapamatic
Me too, but definitely less often....
Re: Ecobee Plugin
Posted:
Wed Jun 28, 2017 2:33 am
by zaiks
Hello to Indigo community! I'm not new to the system but havent had any specific need nor question to participate in this forum before.
I have a customer with 20-zone floor heating and vey good need for Ecobee 3 devices
Hence my questions
- does the plugin/Indigo have capacity to handle this amount of devices?
- can I somehow regulate the polling intervals so I don't use all 85 000 tries in few days (best would be different day/night intervals)
- how can I change the setpoints so that it isn't only overriding Comfort settings but changes them?
Re: Ecobee Plugin
Posted:
Wed Jun 28, 2017 9:01 am
by jay (support)
I can't speak to anything specific about the plugin since we didn't develop it, but Indigo 7 doesn't place any limitations on the number/types of devices (nor did Indigo 5/6 Pro).
