IFTTT Action plugin
Wed Jun 03, 2020 7:26 pm
FlyingDiver online
Re: IFTTT Action plugin
dkillmer wrote:
I see. I am using Webhooks to trigger a message from IFTTT. I confirmed the event name in IFTTT matches the event name in the Indigo trigger and I am not passing any values. The Webhook I created says it is active and it has never run. Thanks for your help!
Let's start at the beginning. You're using the IFTTT plugin to (attempt to) trigger an IFTTT action, correct? So that's not a message "from IFTTT"? What does this IFTTT action actually do? Post a screenshot.
Wed Jun 03, 2020 8:41 pm
dkillmer offline
Yes, that is correct. Screenshot attached.
Wed Jun 03, 2020 8:55 pm
FlyingDiver online
Try activating that without using the plugin. Put this in a Python script action:
import requests
requests.get("https://maker.ifttt.com/trigger/DrivewayAlert/with/key/<API-KEY>")
Edit that last part to put in the API key you're using.
Wed Jun 03, 2020 9:05 pm
dkillmer offline
Yes, that worked.
Thu Jun 04, 2020 6:40 am
dkillmer offline
Thank you!
Thu Jun 04, 2020 7:35 am
FlyingDiver online
Good to know. A plugin is really kinda overkill for this, since it's such a simple Python script.
Tue Dec 29, 2020 10:07 am
ckeyes888 offline
I assume it may be possible to turn on an Alexa device, not available to Indigo?
Carl
Wed Jul 28, 2021 5:39 pm
AutoMation01 offline
Greetings all ---
Can the three values in this plugin be used to pass indigo variables?
I am looking to pass Netatmo - (wind / gust / temp) values that are already stored as indigo variables to apilio logic blocks? I have a IFTTT web hook setup that invokes my ifttt to apilio recipe and can pass static values to it, would now like to pass the indigo vars instead of the static values?
Is there a format to do this in the three values field in this plugin? Or is there an easier / better way to do this as a script?
Any advise / assistance is appreciated.
Wed Jul 28, 2021 8:42 pm
AutoMation01 wrote:
Greetings all ---
OK ... so this seems to work as a script:
#!/usr/bin/env python3.7
import requests
myVar_gust = (indigo.variables[1727362904].getValue(float))
myVar_wind = (indigo.variables[23371740].getValue(float))
myVar_temp = (indigo.variables[131355202].getValue(float))
key_val = "my key here"
the_url = "https://maker.ifttt.com/trigger/netatmo/with/key/" + key_val + "?&value1=" + str(myVar_gust) + "&value2=" + str(myVar_wind) + "&value3=" + str(myVar_temp)
indigo.server.log(str(requests.get(the_url)), type=" ====> : ")
I would be interested to know if there is an easier way to simply pass the indigo variables through the plugin three values with some type of special formatting or something?
Thanks ....
