MQTT Gateway Plugin
Mon Feb 01, 2016 10:53 am
bluenoise offline
Re: MQTT Gateway Plugin
All right, it seems I was greatly overthinking the solution to my problem. I looked at the source code of the MQTT Gateway plugin and found a reference that I hadn't seen. So, my updated script is here:
poolMax = indigo.variables[1141597781] # "pool_temp_max" variable that is reset each morning
poolTemp = indigo.devices[102542860] # "Pool Temperature" sensor via MQTT
message = poolTemp.states["topicMessage"] # MQTT message payload from temperature sensor
# If the daily maximum temperature is less than our new temperature, update the daily max to the new value
if float(poolMax.value) < float(message):
   indigo.variable.updateValue(poolMax, message)
This is much nicer. I hadn't found this reference in any documentation for scripting using custom plugin devices.
Mon Feb 01, 2016 11:05 am
jeremyjjr offline
Nicely done!
Mon Feb 01, 2016 11:37 am
Not knowing anything about how that plugin works, I didn't chime in. However, for future reference in the scripting tutorial: Access a custom device state.
Mon Feb 01, 2016 1:36 pm
bluenoise offline
jeremyjjr wrote:
Nicely done!
Thanks! I'm slowly learning more about both MQTT and python scripting in Indigo. I've already queued up another project idea that I'm going to tackle in the coming weeks.
Thanks for that link, Jay. I had seen that page in the past, but didn't remember that's where I should look for information to solve this problem. I've saved that link because I'll be using it a lot going forward! :)
Mon Feb 01, 2016 1:39 pm
bluenoise offline
I have a feature request for this plugin:
I'd like the ability to optionally disable logging of MQTT events on specific devices. For example, my temperature sensors are flooding my Indigo log whenever there is a new reading.
In the short term, I could modify the plugin source to suppress this logging, but I thought others might like that feature, too.
Tue Feb 02, 2016 3:35 am
jeremyjjr offline
Done. I've updated the plugin to v1.0.6 and added a new device property called 'Disable Topic Update'. When checked in the device config page, any updates from the queue will not be displayed in the log file.
Hope that helps.
J.
Tue Feb 02, 2016 10:10 am
bluenoise offline
Hope that helps.
J.
Thank you so much for the awesome support, Jeremy!
I'm getting this in my log after the update and it stopped working. Everything looks correct in my device settings, so I'm stumped.
  Started plugin "mqttGateway 1.0.6"
  Error                           device "Family Room Temperature" state key onOffState not defined (ignoring update request)
  Error                           device "Garage Door" state key onOffState not defined (ignoring update request)
  Error                           device "Pool Temperature" state key onOffState not defined (ignoring update request)
Mon Feb 08, 2016 1:43 pm
rlust offline
Since my update to 1.6 theMQTT gateway is not working. I also am getting error on startup.
Any ideas on this issue, and where can I get the previous version?
Thanks for your work and help!
Randy
Tue Feb 09, 2016 4:01 am
jeremyjjr offline
Okay, so the 1.0.6 release had a couple of bugs in the code - apologies. I've moved things around a little and hopefully all should be working once you update to 1.0.7. Link at the top of the thread as usual.
Please let me know how you get on.
Jeremy.
Tue Feb 09, 2016 8:52 am
rlust offline
Thanks so much for all of your work Jeremy!
That fixed it!!!
Tue Feb 09, 2016 9:48 am
bluenoise offline
I just installed the update and it's working with my MQTT devices. I still get this when the plugin is restarted:
  Started plugin "mqttGateway 1.0.7"
It does not seem to affect operation, so I'm not too concerned about it. It appears to be an error from Indigo and not the plugin itself as I didn't find that text in the plugin's code.
Tue Feb 09, 2016 9:49 am
jeremyjjr offline
MQTT Gateway Plugin
If you edit the config of each device and click Save on the dialog without changing anything, does that remove the error?
Tue Feb 09, 2016 10:40 am
bluenoise offline
I toggled the "On/Off State" checkbox on then off in each before hitting save, so I didn't make any change. I got this in the log for the temperature sensing devices:
  Script Error                    embedded script: invalid literal for float(): test message
     embedded script, line 8, at top level
ValueError: invalid literal for float(): test message
When I tried it a second time, that error didn't happen. When I reloaded the plugin, I got the same errors mentioned previously regarding On/Off state key.
Tue Feb 09, 2016 11:30 am
jeremyjjr offline
Okay, so I think we can safely say this is an iterative process :D
I did some digging around the On/Off state property of the MQTT device. If the 'Show On/Off State' checkbox is not ticked in the Device config dialog, then any attempt to access the onOffState property of the device will fail. I've updated the code to 1.0.8 (yes, again!) to check that the device supports the property before trying to update it - this should remove the errors you are seeing when the plugin loads for the first time.
As for the error you posted in the log - looks like this is being generated by an action or trigger script rather than the plugin itself? If I'm correct, then paste the code and we can take a look.
J.
Tue Feb 09, 2016 4:25 pm
rlust offline
Sorry to ask, but can I get a copy of 17,, 1.8 might have introduced some issues for me?
Page 3 of 9 1, 2, 3, 4, 5, 6 ... 9
Users browsing this forum: No registered users and 28 guests
