Plugin for Haiku Fan with SenseME
Sun Feb 09, 2020 9:46 pm
mpleeds offline
Re: Plugin for Haiku Fan with SenseME
One more thing, -- To increment fan light brightness, I have tried the following script:
fan_id = 11175177
bright_change = 1
senseMeID = "com.pennypacker.indigoplugin.senseme"
senseMePlugin = indigo.server.getPlugin(senseMeID)
office_fan = indigo.devices[fan_id].name
   current_fan_bright = int(indigo.devices[fan_id].states["brightness"])
except:
   indigo.server.log("could not read the current fan brightness")
   return
new_fan_bright = current_fan_bright + bright_change
if new_fan_bright > 7:
   indigo.server.log("could not change the fan brightness beyond level 16")
   return
elif new_fan_bright < 0:
   indigo.server.log("could not change the fan brightness below level 0")
   return
output_str = ""
if new_fan_bright > current_fan_bright:
   output_str = "increasing "
   output_str = "decreasiong "
indigo.server.log(output_str + "'" + office_fan + "' brightness from " + str(current_fan_bright) + " to " + str(new_fan_bright))
senseMePlugin.executeAction("fanLightBrightness", deviceId=fan_id, props={'brightness':str(new_fan_bright)})
When I run this script, the event log reports:
Feb 9, 2020 at 7:38:04 PM
   Script                          increasing 'Haiku Office Fan' brightness from 0 to 1
   SenseME Fan Debug               set brightness to None this:
I think there is a problem with the last line of script?
Sun Feb 09, 2020 11:06 pm
I believe you get a string as brightness from reading the state
You need an integer when you add
Also
It is better to post code as [ code ]
Then you can see the proper indents etc
Mon Feb 10, 2020 7:55 am
vtmikel offline
The fan light can go from 0 to 16, so adjust the boundary check appropriately.
Then, try this (note that the parameter that the Plugin Action expects is called "lightLevel"):
senseMePlugin.executeAction("fanLightBrightness", deviceId=fan_id, props={'lightLevel':str(new_fan_bright)})
Or, also try removing the str() on the new brightness level and passing the integer value:
senseMePlugin.executeAction("fanLightBrightness", deviceId=fan_id, props={'lightLevel':new_fan_bright})
Mon Feb 10, 2020 9:42 am
mpleeds offline
Yes, simply changing the parameter from "brightness" to "lightLevel" corrected the problem and it now functions with passing either the string or integer value.
For future reference, is there a resource available from within Indigo which provides access the correct parameter nomenclature for a given device or plugin?
For example:
fanLightBrighness/lightLevel
fanSpeed/speed
Thanks to both of you for helping sort this out.
Mon Feb 10, 2020 9:44 am
vtmikel offline
In this case I looked at the ways to call the plugin's supported actions for setting the brightness and fan level. If you look at Actions.XML for the plugin, it has the method names and parameters. Glad it is working for you.
Sun Apr 12, 2020 11:06 am
Ramias offline
For those having trouble with version 0.70 of this plugin, I think I've had a breakthrough (At least for me) to the KeyError on line 544;
Starting with line 544, comment out these lines from the plugin's plugin.py file:
        fan = self.allfans[dev.id]
        if tempUnits == 'C':
            temp = int(float(fan['coolingIdealTemp']) / 100.0)
            dev.updateStateOnServer('coolingIdealTemp', temp)
            temp = int(float(fan['sleepIdealTemp']) / 100.0)
            dev.updateStateOnServer('sleepIdealTemp', temp)
            temp = int((int(fan['coolingIdealTemp']) / 100.0) * 9 / 5) + 32
            temp = int((int(fan['sleepIdealTemp']) / 100.0) * 9 / 5) + 32
Save and reload the plugin. Add new fans. Open and edit and save existing fans.
You can then uncomment those lines, reload the plugin, and open/edit/save should work for all existing fans.
I'm sure there's an actual "code" way to fix this, but this is how I was able to get v 0.70 working for me. It's not every day I buy new fans, so I can probably stick with this for now. Hopefully this helps somebody else.
Tue Aug 11, 2020 5:47 am
jenkins007 offline
This is a great way to automate these fans. I have 3 of them and will make triggers to execute this action group.
I am getting an error on the last line:
 senseMePlugin.executeAction("fanSpeed", deviceId=fan_id, props={'speed':str(new_fan_speed)})
The error is
Script Error embedded script: Python argument types in
PluginInfo.executeAction(PluginInfo, str)
did not match C++ signature:
executeAction(CPlugin {lvalue}, CCString actionTypeId, unsigned long deviceId=0, boost::python::api::object props=None, bool waitUntilDone=True)
embedded script, line 31, at top level
ArgumentError: Python argument types in
I tried changing the str to integer and continue to get this error. I am using plugin version 0.7.0 and 7.4 Indigo. The plugin works well in getting status of the fans and on/off, but not incrementing speed.
Matthew
Matthew
Wed Aug 12, 2020 5:07 am
jenkins007 offline
Interesting, I changed the device ID to the Python reference (even though I had fan_id referencing it elsewhere), and it worked. I wonder if that is supposed to happen?
Matthew
Wed Aug 12, 2020 11:02 am
The error is saying that you are calling executeAction only with a single argument (which is probably the actionTypeId of "fanSpeed"). Maybe the line of code you think is being executed is a different one? You can debug into this more by logging each argument (to log an argument as a string try using: str(type(fan_id)) to see what is actually being passed in. Also add log lines before and after each executeAction() call so you can see which one is actually failing.
Sun Aug 16, 2020 5:00 am
jenkins007 offline
Thanks Matt. When I change the fan device Id from the referenced one to that actual numbers the error goes away. The script runs and tells me that the fan speed is changing ( I used the code in this thread without changing anything other than the python device reference which was a cut-and-paste).
However, the actual fan speed does not change. I know there have been at least 2 firmware updates this year. Maybe there are other factors involved?
Matthew
Wed Aug 19, 2020 5:31 pm
What does it log when you execute the script? I'm not familiar with the Haiku hardware or firmware updates, so I'm not sure if that might be related or not.
Back to the fan_id argument problem, I'd be curious what this logs if you put it directly before the executeAction() line:
indigo.server.log("fan_id type: {},  fan_id val: {}".format(type(fan_id),fan_id))
and then execute it use both an integer of the fan_id (which showed the strange error you originally posted above) as well as the device instance (which sounds like it works?). That is, execute the script twice once each with the respective fan_id values.
Fri Oct 02, 2020 6:45 am
jenkins007 offline
I used this code:
fan_id = indigo.devices[654330629] # "Mandy Fan"
The output:
   Script                          fan_id type: <class 'indigo.Device'>,  fan_id val: address :
batteryLevel : None
buttonGroupCount : 0
configured : True
description : Also known as Kitana
deviceTypeId : SenseME_fan
displayStateId : statusString
displayStateImageSel : FanOff
displayStateValRaw : off / on
displayStateValUi : off / on
enabled : True
energyAccumBaseTime : None
energyAccumTimeDelta : None
energyAccumTotal : None
energyCurLevel : None
errorState :
folderId : 674758727
     com.pennypacker.indigoplugin.senseme : (dict)
          fanIP : 192.168.1.32 (string)
          fanMAC : 20:F8:5E:1E:F0:1F (string)
          fanName : Kitana (string)
          fanTempUnits : F (string)
lastChanged : 2020-10-02 07:08:38
lastSuccessfulComm : 2020-10-02 07:08:38
model : SenseME fan
ownerProps : com.pennypacker.indigoplugin.senseme : (dict)
pluginId : com.pennypacker.indigoplugin.senseme
protocol : Plugin
remoteDisplay : True
states : States : (dict)
     beep : ON (string)
     brightness : 14 (integer)
     coolingIdealTemp : 66.2 (real)
     coolingIdealTemp.ui : 66.2 F (string)
     direction : forward (string)
     direction.forward : true (bool)
     direction.reverse : false (bool)
     fan : off (on/off bool)
     fan_motion : ON (string)
     indicators : ON (string)
     light : on (on/off bool)
     light_motion : OFF (string)
     motion : off (on/off bool)
     sleepIdealTemp : 66.2 (real)
     sleepIdealTemp.ui : 66.2 F (string)
     sleepMode : OFF (string)
     smartmode : COOLING (string)
     speed : 0 (integer)
     statusString : off / on (string)
     whoosh : OFF (string)
subModel :
supportsAllOff : False
supportsStatusRequest : False
version : None
Matthew
Fri Oct 02, 2020 8:19 am
Did you put that log line directly before the executeAction() call line?
And did you see after the debug log information in the Event Log window the same error you saw before?
That is, can you copy/paste the entire Event Log results (not just the result of the debug line)?
Tue May 17, 2022 9:52 am
Ramias offline
Just opened up the Haiku app on my phone (since my Mac is rebooting with the MacOs 12.4 update) and there's a new Big Ass Fans app that also requires a firmware update (and says the old app will no longer work).
I value my control of these fans with Indigo more than any new feature so will resist the upgrade urge for now.
Update: Thread on this from another platform: https://github.com/home-assistant/core/issues/69370
Looks like this new firmware is a breaking change but other devs have worked out the new protocol.
Tue May 17, 2022 11:55 am
vtmikel offline
I meant to post on this as well. I had the same thought as you, and did not upgrade. Breaking my indigo integration would be killer. I’ve gotten it to where my fan speed is 100% controlled by Indigo.
t
