Indigo XMPP Client
Wed Jul 09, 2014 8:01 pm
jheddings offline
Indigo XMPP Client
Source Code: https://github.com/jheddings/indigo-xmpp
Download: https://github.com/jheddings/indigo-xmpp/releases/download/v0.1.0/XMPP-Client-0.1.0.zip
This is a basic plugin that logs into an XMPP account and interprets messages as Indigo commands. It provides basic control over devices, variables & action groups through a chat interface, such as Google Talk or Jabber. There is still a lot of work to do, so please consider this a "proof of concept" at this point.
Setup:
- Create a dedicated Jabber or Gmail account (this will be the "bot" account)
- Add the bot as a friend/contact on your regular account
- You may need to log in as the bot and accept the contact request
Installation:
- Install xmpppy to under the Python 2.5 site_packages. This is easiest to do using the command line: easy_install-2.5 xmpppy
- Install the plugin, restart the Indigo server
- After enabling the plugin, you will need to provide the login information for your bot
Examples of commands:
- turn on House Lights
- set mode to away
- run My Custom Action Group
- status Daily Schedule
Limitations / Known Issues:
- The bot does not respond to all commands every time - may be an issue in xmpppy
- The bot assumes "Title Case" on all items except variables (first letter of each word must be capitalized)
Some of the ideas for this plugin come from DVDDave's iMessage Script
Standard disclaimer: this bot is very experimental. I have tried to test it thoroughly, however there are likely some cases I've missed. It shouldn't do anything harmful, but it may not work entirely as expected. If you find issues or have any comments, please report them here and I will try to update the plugin accordingly.
Sun Jul 13, 2014 5:20 pm
Re: Indigo XMPP Client
Very neat. I just added it to our plugin list under the miscellaneous plugins section.
Thanks for sharing it with folks!
Thu Dec 18, 2014 1:52 am
jtodd offline
This is great - it will replace the OpenFire->Asterisk(XMPP)->Indigo pipeline that I've been running at the moment, which is kind of a hack.
I'm on 10.6, and installed xmpppy 0.5.0rc1 (as root) without a problem with easy_install-2.5 but after a re-launch of Indigo I get this:
XMPP Client XMPP Client ONLINE...
XMPPClient XMPP Client OFFLINE...
XMPP Client Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
...and obviously the user isn't connected. These error then repeat every 10 seconds. Any ideas here? It's not even trying to connect to the XMPP server I have configured, according to a packet trace.
JT
Mon Sep 12, 2016 2:56 pm
jtodd offline
I've just upgraded to 10.11 (El Capitan) and installed xmpppy to try this again. Sadly, the original plugin file seems to be missing from Box (where it was linked in the original post.) Is there an updated version of where this file lives?
JT
Fri Nov 25, 2016 11:15 pm
jheddings offline
Sorry it took so long to reply to this one... In case you still need it, I've made the source and a download available through GitHub:
Note that I haven't used this plugin for a while, so it may be broken in newer versions of macOS or Indigo. I'll try to respond to bug reports as time allows.
Thu Dec 29, 2016 11:48 am
jheddings offline
This plugin has been moved to a dedicated forum. Please check there for updates and questions.
