Thingspeak Plugin
Sun Mar 09, 2014 2:21 pm
Thingspeak Plugin
Available Now:
Overview:
The Thingspeak plugin is designed to allow users to upload device states and variable values to Thingspeak.
Installation and Configuration:
Before you can use the plugin, you need to have an active Thingspeak account.
There are only a couple of settings for the plugin. The first is to set how often you would like the plugin to upload data and the second is how long you would like to wait for a response from the Thingspeak servers. To use the plugin, you must create Thingspeak devices. Each device represents one Thingspeak Channel. It's under the 'Edit Device Settings' where the bulk of the configuration takes place. Each Thingspeak device can support up to eight values (a limit for individual Thingspeak channels.) To upload more values, add additional Thingspeak devices. Right now, Thingspeak only supports numeric values and the Thingspeak plugin supports numeric and boolean values (it coverts boolean values to numerics). The device configuration settings are pretty self explanatory.
The chart below is a sample of a Thingspeak chart--these are created via the Thingspeak website--not the plugin itself. However, Thingspeak charts can be placed into HTML iFrames and used in conjunction with Indigo Control Pages.
Other Plugin Features:
- reports device health to the main Indigo UI. When the plugin is successfully reporting, the UI will display a green indicator.
- tries to strip non-numeric characters from the value before attempting upload (leaves the source variable unchanged.)
- attempts to overcome adverse conditions like variable deletions, etc.
Please post any bugs or questions about the plugin to this forum.
Example of a Thingspeak chart.
Sun Mar 09, 2014 3:25 pm
Re: Thingspeak Plugin
Hi Dave,
Great contribution -- I approved the submission to the user contribution library here:
http://www.perceptiveautomation.com/fil ... php?id=276
And the direct link to the plugin download is:
http://www.perceptiveautomation.com/ind ... Plugin.zip
Thanks for sharing this with folks!
Sun Mar 09, 2014 4:32 pm
matt (support) wrote:
Hi Dave,
Great contribution -- I approved the submission to the user contribution library...
Thanks Matt. My pleasure!
Sun Mar 09, 2014 4:42 pm
Great plugin.. looking forward to seeing it support devices!
I’ve found a couple of minor issues.. one is that updated preferences on upload times don’t seem to make any difference until you reload the plugin. The second, and i’m not sure if this might be what you mean by "Thingspeak only supports numeric values” but if i have a value of say 20.3 it’ll upload that as 203.
Sun Mar 09, 2014 5:10 pm
Thanks for letting me know about the bugs.
Devices are a little trickier because it's tough to generate a dynamic list of device states--especially only the numeric ones.
UPDATE: I've fixed both bugs for the next update:
- Going forward, the upload interval will update itself on the next cycle (it's either that or force an upload with a config save.)
- The numeric thing was me getting a little too aggressive. What I'm trying to do is convert values such as "20.3 °F" into "20.3" but wound up stripping the decimal point too.
Thanks again.
Sun Mar 09, 2014 7:56 pm
Dave,
great plugin!! and so simple..
as for stripping letters from text:
varValue= "the voltage is 13.7 V!"
number = ''.join(i for i in varValue if (i.isdigit() or i=="."))
number = 13.7
For selecting properties from a device, look at the python code in indigoplot.
I have spend MANY hours making that work.
The trick is to reduce the number of things presented to the user, some devices have a LOT of properties and most are just text.
Sun Mar 09, 2014 8:13 pm
Thanks so much Karl. Still a work in progress (I suppose they are never done...) I have landed on the following which is effectively the same thing as what you've suggested.
seq = ''.join([c for c in seq if c in '1234567890.'])
I will definitely take a look at indigoplot. I had something working but it was basically a dump of all device states which, while it would work, could be hundreds of choices long in no time.
Thanks again and any ideas for improvements would be most welcome.
Dave
Sun Mar 09, 2014 8:41 pm
One way to do it is:
preselect devices (i.e. that have a prop with a number)
present that filtered device list, user picks a device
after device is selected then present the props that have a number.
it took me some time to figure that out and you will need to understand the hierarchy of several dynamic lists and which one will get updated when..
there are 19 in the config screen
one way to do it is to have check buttons that enabled and disable certain sections
its fun once it works..
Sun Mar 09, 2014 8:51 pm
text --> number:
accept = -999999991.1
   x = float(''.join([c for c in val if c in '1234567890.']))
   accept =x
except:
  if val.upper()  =="TRUE"  or val.upper() =="ON":  accept = 1.
  if val.upper()  =="FALSE" or val.upper() == "OFF":  accept = 0.
reject if accept == -999999991.1
otherwise it can be used as floating point number or 1/0
True and false can be plotted as 1 / 0 i.e. on /off i.e. AC is on/off
Sun Mar 09, 2014 9:39 pm
this should core all(?) possibilities:
   def getNumber(self,val):
      x = ""
         x = float(val)
         return x
      except:
         xx = ''.join([c for c in val if c in '1234567890.'])
         if len( ''.join([c for c in xx if c in '1234567890']) ) !=0: return xx  # remove strings that have leters and dots eg "abc.xyz"
            val = str(val).upper()
            if val== "TRUE"  or val =="ON"  :  x= 1.                                                      # true --> 1,  false --> 0
            if val== "FALSE" or val =="OFF" :  x= 0.
      return x
returnNumber = self.getNumber("theString") or number
this one will handle:
1.0 --> 1.0
0.0 --> 0.0
a.b --> ""
"the value is 12.7v" --> 12.7
"a is better than b." --> ""
True --> 1.0
"true" --> 0.0
False --> 0.0
"false" --> 0.0
"on" "ON" "oN" --> 1.0
"off" "OFF" "oFF"--> 0.0
"" if none of above
Sun Mar 09, 2014 9:43 pm
The attached will make a list of devices / variables that satisfy the "number" criteria as variable value or have a property with a "number"
   def preSelectDevices(self):            # Select only device/properties that are supported:  numbers, bool, but not props that have "words"
      self.listOfPreselectedDevices=[]
      self.devIdToTypeandName={}
      self.logMessage(u" listOfPreselectedDevices 1 "+ str(self.listOfPreselectedDevices))
      for dev in indigo.devices.iter():
         theStates = dev.states.keys()
         count =0
         for test in theStates:
               if "Mode" in test or "All" in test:
                  skip= True
                  skip= False
            except:
               skip=False
            if not skip:
               val= dev.states[test]
               x = self.getNumber(val)
            if x !="":
               count +=1
         if count>0:                                       # add to the selection list
               self.listOfPreselectedDevices.append((dev.id, dev.name))            ## give all id's and names of  devices that have at least one of the keys we can track
               self.devIdToTypeandName[dev.id]="Dev-",dev.name
            except:
               self.logMessage(u" listOfPreselectedDevices 2-1 error id, name "+ str(dev.id) + " " +str(dev.id)+" " + str(self.listOfPreselectedDevices),0)
      for theVar in indigo.variables:
         val = theVar.value
         if x!="":
               self.listOfPreselectedDevices.append((theVar.id, "Var-"+str(theVar.name)))
               self.devIdToTypeandName[theVar.id]= "Var-",theVar.name
            except:
               self.logMessage(u" listOfPreselectedDevices 2-2 error id, name "+ str(theVar.id) + " " +str(theVar.id)+" " +  str(self.listOfPreselectedDevices),0)
      return
Mon Mar 10, 2014 6:16 am
Thanks Karl. This method seems to be working well. I had to play with the indents a bit to get it to work, but that's to be expected. Will now take a look at the device state code you provided.
Thanks very much!
Dave
Mon Mar 10, 2014 9:29 am
I believe the SDK contains an example of a dynamic list that gets rebuilt based on a selection change in another list - I believe it's the custom device example plugin. It's actually pretty simple - just implement a dynamic list of states where you get the device from a menu field. Mark the menu with the devices to reload dynamic fields:
<Field id="sourceDeviceMenu" type="menu">
   <Label>Device to add to scene:</Label>
   <List class="self" method="sourceDevices" dynamicReload="true"/>
</Field>
and whenever the user selects something different in that menu all dynamic fields will get reloaded - and your states list dynamic method can get the value of sourceDeviceMenu (in the above example), build the state list, and return that.
Mon Mar 10, 2014 10:46 am
Jay,
the challenge is: if you just do it linear (device+property) you get e.g. 50 devices * 10 states =500 as the selection list.
would be good if the menu structure would allow for a hierarchical selection list: first you select the device and AFTER you have done that, the second list picks up the device id and creates the list of properties for that device. Right now they are all at the same level, no priority and the second one goes before the first one and and so on, they get called many times.
If you implement that the next time I could have saved ~ 10 days of fiddling with 16 dynamic lists
but thats the fun .. at least for me..
ps if you have not seen the movie "Tim's Vermeer" I highly recommend it.
It is about technology, art, and a 5 year commitment proving that the first color copy machine was invented by a Dutch painter in the 16 hundreds - one copy takes 1 year though, and the pixels size is 1mmx1mm, but still..
Mon Mar 10, 2014 11:38 am
RogueProeliator offline
I am pretty sure you can do this now... and I am assuming (I know, dangerous) this is what Jay was getting at, so maybe an alternative explanation would help.
Your first drop down is a list of the devices (all or an allowable subset or whatever) and the second (properties) box is initially an empty list; in your code if there is no current device selection you return an empty list.
When the user makes a selection, the properties drop down, being a dynamic list, could react to the change in the selected device. If you can't get it reacting then you could have a button that, when clicked, "selects" the device and loads the properties for it. However, as per Jay's post, I am thinking that you can indeed react to the device selection box having been changed.
Hopefully I understood both of you or I could just be talking for no reason here ;-)
Adam
