Ecobee Plugin
Tue Jan 17, 2017 8:51 am
BillC offline
Re: Ecobee Plugin
Once you install, you'll need to get a PIN from the plugin configuration page and enter it on the Ecobee web site to authorize access
Can someone advise me how/where to do this? I've found two possible areas: Add a new thermostat (the website doesn't recognize the PIN) and the Access restriction (which only accepts numbers).
Has the website changed somehow or am I just missing something? :(
Tue Jan 17, 2017 9:08 am
Re: Ecobee Plugin
https://www.ecobee.com/consumerportal/i ... l#/my-apps
(it's the "My Apps" item in the pull down menu from the icon in the top right corner)
Then the "Add Application" button.
Tue Jan 17, 2017 2:46 pm
BillC offline
Re: Ecobee Plugin
Thanks, Joe. Worked fine.
Tue Jan 17, 2017 5:15 pm
towsled offline
Re: Ecobee Plugin
This last weekend I purchased an Ecobee3 thermostat and decided to try this plugin. Excellent plugin and works great! I do have a question though; I noticed that the thermostat device in Indigo does not have an "occupancy" trigger event (or at least I can not find it) like the sensors do. I was hoping to trigger events in the room where my thermostat is located by accessing the thermostat's occupancy sensor; is there a way to do this? Any help would be greatly appreciated.
Dan..
Sat Jan 21, 2017 2:04 pm
MKuchnic offline
Re: Ecobee Plugin
I've installed the ecobee plug-in and it works very well. The remote sensor feature of the plug-in allows me yo know when someone is in the basement and set some lights, etc. in the basement.
I'm planning on adding an I/O line to sense the station my alarm and then have the thermostat set to away mode, and I discovered it's not working. Any plans for adding this, or should I just set the temperature lower instead?
Mark
Mon Jan 23, 2017 5:27 pm
Jann offline
Re: Ecobee Plugin
Having issues turning fan to "ALWAYS ON" from "auto on".
I choose ALWAYS ON from the dropdown, the green line bops back and forth in the status section then the "controls" section re-updates back to "auto on"
Anyone else having this issue?
BTW: Lost control no the 15th, didn't notice till today. had to remove app from ecobee site and re-gen pin and redo the addition.
Jann
Wed Jan 25, 2017 10:34 am
brlandy offline
Re: Ecobee Plugin
For anyone experiencing the disconnect issue, you might try testing with this patch (one line change) to Plugins/Ecobee.indigoPlugin/Contents/ServerPlugin/plugin.py:
@@ -73,7 +73,7 @@
                        self.pluginPrefs[ACCESS_TOKEN_PLUGIN_PREF] = self.ecobee.access_token
                        self.pluginPrefs[AUTHORIZATION_CODE_PLUGIN_PREF] = self.ecobee.authorization_code
                        self.pluginPrefs[REFRESH_TOKEN_PLUGIN_PREF] = self.ecobee.refresh_token
-               else:
+               if self.ecobee.refresh_token == '':
                        self.pluginPrefs[ACCESS_TOKEN_PLUGIN_PREF] = ''
                        self.pluginPrefs[AUTHORIZATION_CODE_PLUGIN_PREF] = ''
                        self.pluginPrefs[REFRESH_TOKEN_PLUGIN_PREF] = ''
I've been running with this change since Jan 2 and have not needed to re-authenticate.
Brian
Wed Jan 25, 2017 10:38 am
Jann offline
Re: Ecobee Plugin
How would we apply this?
Wed Jan 25, 2017 10:51 am
rapamatic offline
Re: Ecobee Plugin
Brian
Thanks Brian. I'll put this in tonight to test.
If it works for a few of us, maybe you can submit a pull request to Jason?
Wed Jan 25, 2017 10:57 am
brlandy offline
Re: Ecobee Plugin
Yes, I'll definitely submit a pull request. Since I can't be 100% sure the patch worked so thought getting more feedback before submitting would be helpful.
As far as how to apply, you can edit the file directly and replace that one line (#76). The above patch provides some context so you can be more certain you are in the right spot. You are changing:
to:
The full path of the file to edit is:
/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Ecobee.indigoPlugin/Contents/Server Plugin/plugin.py
Be sure to keep the indenting unchanged.
Thu Jan 26, 2017 1:39 pm
rapamatic offline
Re: Ecobee Plugin
That change is working fine for me. No issues so far.
Sun Feb 05, 2017 6:45 pm
MKuchnic offline
Re: Ecobee Plugin
Hi...
I just installed v1.1.1 and I noticed the changes to the controls. The "resume from all holds" works great! Unfortunately the "set away mode" still doesn't work. :cry:
I ran into a problem with v1.0 when I tried to set the temperature (I'm running the thermostat in Celsius) and I think that may have been the problem. I had to totally delete the thermostat and remove the app from the Ecobee site to stop the thermostat from rebooting every half hour. I'll do some more testing with this version and try to see if it happens again.
Thanks for the update!
Mark
Thu Feb 23, 2017 11:22 am
dvottero offline
Re: Ecobee Plugin
I can also confirm that in 1.1.1 the setAwayStatus isn't working -- I'm getting a "plugin does not define method setAwayStatus".
Otherwise, very awesome plug-in! Kudos.
Thu Apr 13, 2017 2:02 pm
mclass offline
Ecobee Plugin
Have just attempted to install this plugin, on Indigo 7 running under OSX 10.10.5. The plugin fails to start with the following event log entry:
 Ecobee Error                    Error in plugin execution InitializeMain:
  File "plugin.py", line 4, in <module>
  File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Ecobee.indigoPlugin/Contents/Server Plugin/pyecobee/__init__.py", line 2, in <module>
  File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Ecobee.indigoPlugin/Contents/Server Plugin/requests/__init__.py", line 59, in <module>
  File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Ecobee.indigoPlugin/Contents/Server Plugin/requests/models.py", line 21, in <module>
  File "/Library/Python/2.7/site-packages/urllib3/util/__init__.py", line 4, in <module>
  File "/Library/Python/2.7/site-packages/urllib3/util/request.py", line 5, in <module>
ImportError: cannot import name UnrewindableBodyError
   Stopping plugin "Ecobee 1.1.1" (pid 315)
   Stopped plugin "Ecobee 1.1.1"
I suspect that it may be an issue with my Python install, as initially urllib3 was absent - I installed it with
 sudo pip install urllib3
But my Python skills are non-existent, so maybe someone can correct the error of my ways!! :oops:
Thanks in anticipation!
Sat Apr 15, 2017 1:11 am
mclass offline
Re: Ecobee Plugin
All sorted! Updated Python 2.7 & re-installed urllib3, rebooted. Deleted the plugin & reloaded. All appears to be good!
Page 4 of 12 1, 2, 3, 4, 5, 6, 7 ... 12
