Lutron RadioRA 2 (and Caseta) plugin
Sat Nov 12, 2016 11:13 pm
markf424 offline
Re: Lutron RadioRA 2 (and Caseta) plugin
The easiest way I've found is to use the Lutron app on your device. Go to the settings (gear) icon/Advanced/Integration/Send Integration Report. It will create an email detailing all of the Integration IDs for your scenes and your devices.
<Note, accidentally PMed this to mcfarlde but wanted to drop it here for future/community reference.>
Sun Nov 13, 2016 10:04 am
ourjoint offline
Can anyone give me a hand getting this to work? My current home using insteon, but I bought the pro bridge and a caseta plug to test. I'm building a new home and hoping to use all lutron controlled by indigo. The caseta app is working just great. Turned on telnet, put in the static IP address of the bridge, ran the id report and put in the id of the plug....but NADA from indigo. Don't know what to do further.
Tue Nov 15, 2016 11:31 pm
markf424 offline
Sure. What are you seeing in your Event Log?
Can your Indigo server host telnet to the Lutron bridge from the Terminal?
It's always worth restarting the plugin if you're seeing odd messages in the Event Log. Sometimes things appear to get out of sync.
Wed Nov 16, 2016 12:08 pm
RatRanch offline
mcfarlde wrote:
Hello,
I'm using Indigo 6Pro trial with this plugin for a Caseta Dimmer and Pico Remote. I assume that I select RadioRA 2 Dimmer as the model? Any clues on how to find the Integration ID?
Regards,
mcfarlde
Easiest way to determine a single Integration ID is from the Indigo Event Log:
1. If the Event Log window isn't already visible, press ⌘ 8 to open it
2. Enable debug by choosing Lutron RadioRA2/Caseta --> Toggle Debugging
3. Press a button on the Pico. You should see something like this in the log:
  Lutron RadioRA2/Caséta Debug   Received a Device message:
~DEVICE,125,4,3
  Lutron RadioRA2/Caséta Debug   Received a pico button status message:
~DEVICE,125,4,3
~DEVICE,125,4,4
~DEVICE,125,4,4
The first number displayed is the Integration ID of the Pico, in this case 125.
Cheers,
-Jim
Mon Nov 21, 2016 4:51 pm
jenwill1 offline
Hello,
I'm a novice user on Indigo 7 and testing the Lutron Smartbridge Pro for using Lutron lighting in a new home versus my current Leviton z-wave devices.
I wanted to test your plugin and have v7.01 loaded at this point. My log shows the following:
Nov 21, 2016, 4:47:05 PM
Disabling plugin "Lutron RRA2/Caséta 7.0.1"
Stopping plugin "Lutron RRA2/Caséta 7.0.1" (pid 28128)
Stopped plugin "Lutron RRA2/Caséta 7.0.1"
Enabling plugin "Lutron RRA2/Caséta 7.0.1"
Starting plugin "Lutron RRA2/Caséta 7.0.1" (pid 28245)
Started plugin "Lutron RRA2/Caséta 7.0.1"
Nov 21, 2016, 4:47:46 PM
Lutron RRA2/Caséta Error Unrecognized command: login:
I am sure I have a bad configuration file ? Please find a screenshot attached.
Thanks for the help !
Configuration.tiff
Configuration.tiff (105.96 KiB) Viewed 5810 times
Mon Nov 21, 2016 4:54 pm
Please turn on debug level logging in the plugin config dialog, then restart the plugin.
Mon Nov 21, 2016 4:57 pm
jenwill1 offline
Looks like I don't know what I'm doing on username/password....
Nov 21, 2016, 4:56:03 PM
Starting plugin "Lutron RRA2/Caséta 7.0.1" (pid 28352)
Lutron RRA2/Caséta Debug logLevel = 10
Lutron RRA2/Caséta Starting up Lutron
Lutron RRA2/Caséta Checking for updates...
Lutron RRA2/Caséta Debug Plugin version detected: 7.0.1
Lutron RRA2/Caséta Debug Current version is: 7.0.1
Lutron RRA2/Caséta Debug Getting latest release from FlyingDiver/Indigo-radiora2...
Lutron RRA2/Caséta Debug GET /repos/FlyingDiver/Indigo-radiora2/releases/latest
Lutron RRA2/Caséta Debug HTTP 200 OK
Lutron RRA2/Caséta Debug Latest release is: 7.0.1
Lutron RRA2/Caséta No updates are available
Lutron RRA2/Caséta Debug updateFrequency = 86400.0
Lutron RRA2/Caséta Running ipStartup
Lutron RRA2/Caséta Connecting via IP to 10.0.1.27
Lutron RRA2/Caséta Debug self.connIP.read:
Lutron RRA2/Caséta Debug username failure.
Lutron RRA2/Caséta Debug End of connection process.
Nov 21, 2016, 4:56:35 PM
Thanks !
Mon Nov 21, 2016 4:59 pm
Try it with a lower case El in the username field. "lutron".
Mon Nov 21, 2016 5:03 pm
jenwill1 offline
Starting plugin "Lutron RRA2/Caséta 7.0.1" (pid 28411)
Configuration.tiff
Configuration.tiff (107.17 KiB) Viewed 5788 times
Mon Nov 21, 2016 5:06 pm
Ok, no clue here. I know that's the default login for a RadioRa2 system, but I've never used Caseta. Maybe there's something you have to do on the SmartBridge Pro enable the integration interface and set the username/password.
One of the other developers will need to chime in on this.
Mon Nov 21, 2016 5:12 pm
jenwill1 offline
Hey thanks for your response and efforts !
Mon Nov 21, 2016 5:21 pm
markf424 offline
You have to enable telnet on your caseta bridge by using the Lutron app. It is located under Settings/Advanced/Integration. Your username/password combination should be fine.
Mon Nov 21, 2016 5:29 pm
jenwill1 offline
I have Telnet enabled already. I'm still using DHCP as I have not assigned a static IP address but the IP address hasn't changed. I noticed on the RadioRa2 iOS app it has a username and password. Don't see one on the Caseta app ?
Tue Nov 22, 2016 7:24 am
jenwill1 offline
I opened a terminal window and used a telnet command to log in to the smart bridge using lutron/integration as the username and password. The first time it failed, the second time I was in. I tried to reload the plugin and received the following log using lutron/integration:
Starting plugin "Lutron RRA2/Caséta 7.0.1" (pid 36010)
Nov 22, 2016, 7:18:27 AM
Lutron RRA2/Caséta Debug Setting configDone to True
Lutron RRA2/Caséta Debug Setting flag to run startup
Lutron RRA2/Caséta Debug True, True, True
Nov 22, 2016, 7:18:59 AM
Again I tried telnet using terminal and it took two login attempts again...
Tue Nov 22, 2016 8:19 am
Can you grab the latest snapshot from the GitHub repository and try it?
https://github.com/FlyingDiver/Indigo-r ... c57dde.zip
I'm not tagging this as a release yet.
Page 9 of 14 1 ... 6, 7, 8, 9, 10, 11, 12 ... 14
