Do you want the airco turned on?
Tue Sep 22, 2020 2:08 pm
macpro offline
Received a Remotec ZXT-600 today to control the airco in our living room and defined the following:
If the temperature gets above 25 degrees in the living room and the outside door and window are closed, then, if the TV is on, a message shows up on the TV to ask if I want the airco on.
And if I press the OK button on the TV remote, the airco indeed turns on.
I just love the way I can connect all my devices using Indigo.
Wed Sep 23, 2020 2:13 am
agame offline
Re: Do you want the airco turned on?
impressive! what are you using to message the tv?
Wed Sep 23, 2020 2:28 am
macpro offline
The TV has an API over a serial connection. I've written a Python script that is run by Indigo and uses this API to talk and listen to the TV.
Some other features is has:
When Indigo detects that someone is at our frontdoor, a PIP window is opened on the TV with a live stream from the camera at the door.
I can also present a menu on the TV with devices in the house and turn them on or off.
Wed Sep 23, 2020 3:03 am
agame offline
cool! I use the security spy Apple TV app, so viewing cams is easy ... but no way of having it pop automatically.
Thu Jun 03, 2021 6:12 pm
ryanbuckner offline
What kin d of TV do you have ?
Thu Jun 03, 2021 11:26 pm
macpro offline
We have Loewe TVs.
