Indigo and Zigbee
Wed Feb 24, 2021 4:21 pm
aldera offline
Re: Indigo and Zigbee
CliveS wrote:
aldera wrote:
Looks like I'll have to do some reading up on the MQTT subject. I don't have any Zigbee devices right now but I noticed that a lot of them are somewhat cheaper now. When I first started playing around with HA, I could have sworn that Zigbee was at least as expensive or even more. Thanks for all the info so far and I'll take a look at the MQTT stuff and see if it's worth it.
Ralph
And remember that MQTT is not just for Zigbee devices, the Shelly devices can use MQTT and they are much cheaper than Fibaro and Aeotec, I have a motorhome with Victron Solar Controller and Shunt which is wired to a Raspberry Pi running Victron software with built in MQTT and Node Red which when on the drive outside can see our WiFi so with Joe's plugins I can now see realtime the volts, current, power, State of Charge of the lithium battery and days left before it is empty, you can also use it to interface with personal weather stations and numerous other devices, which is why it is the standard for IoT interfacing.
BTW, I am no geek whizkid, I cannot code a plugin, my python is basic (very) and I had a lot of trouble getting my head around MQTT (still get confused with Shims), Node Red looks fun but I cannot do much with that either so don't give up, ask here and we all learn a bit more.
Yeah, I think I'll be doing a little reading up on the MQTT subject and see what it can offer me. Technology is moving so damn fast that it's hard to keep up with it all.
Ralph
Thu Feb 25, 2021 3:16 pm
This post is another update on the progress of linking Indigo to Hubitat devices.
First off, I would like to thank Clive for his help with detailed testing and feedback, which has helped me iron out a number of bugs and encouraged the introduction of improvements and new features! :)
It is now working well enough for me that I have it running on my production Indigo system. :D
It currently handles Hubitat device types: Switch [buttons], Contact Sensor, Motion Sensor, Outlet [Socket] and Temperature Sensor. These devices are reflected in Indigo equivalents.
It handles Hubitat device properties of: Acceleration, Battery, Button, Contact, Humidity, Illuminance, Motion, OnOff, Power, Energy, Presence, Pressure, Temperature and Voltage. These properties are reflected in Indigo device states, either Indigo pre-defined or custom.
The properties selected are optional and can be configured. So for example, temperature can be defined as ºC, ºF, convert ºC to ºF or convert ºF to ºC. All numeric fields can have their number of decimal places specified. So for example, a temperature could be received with two decimal places and stored and reported in Indigo as one decimal place. Additionally, for each property, you can specify whether you want device updates reported to the Indigo log or not.
Another useful feature for power reporting, is to specify a minimal level that has to be achieved for a device not to report zero. For example, I have a Salus SP600 power socket that frequently reports 0 watts or 1 watt when off. Setting the limit to 2 watts ensures that Indigo isn't bombarded with these updates as they are filtered out.
All the above gives a reasonable level of flexibility with how the devices are handled.
Next phase (I think) will include looking at supporting LED strips (RGBW) and Thermostats.
Sat Feb 27, 2021 10:32 am
aaronlionsheep offline
autolog wrote:
Here is a screen capture of the Hubitat devices in indigo:
Forgive me for taking this thread slightly off topic, but what is this UI I see in the background? You have been able to include the Temperature and Humidity (with a beautiful progress bar) in the Device Details. I did some investigating, but I couldn't find your code published anywhere to try and figure out how you did that :shock:
Sat Feb 27, 2021 11:03 am
aaronlionsheep wrote:
...Forgive me for taking this thread slightly off topic, but what is this UI I see in the background? You have been able to include the Temperature and Humidity (with a beautiful progress bar) in the Device Details. I did some investigating, but I couldn't find your code published anywhere to try and figure out how you did that :shock:
It is standard indigo properties set in devices.xml for standard Indigo device types e.g. :
            if type_id == "temperatureSensor":
                if not values_dict.get("uspTemperature", False):
                    error_dict['hubitatDevice'] = u"Hubitat device does not support temperature!"
                    values_dict["supportsTemperatureReporting"] = True
                    values_dict["NumTemperatureInputs"] = 1
                    if bool(values_dict.get("uspHumidity", False)):
                        values_dict["NumHumidityInputs"] = 1
I will PM you a link to the code, and the you can investigate at your leisure. :)
I will be putting it up on Github when I have completed a few more device types, which will probably be within a month (hopefully).
Sun Feb 28, 2021 12:34 pm
Different Computers offline
CliveS wrote:
aldera wrote:
I had a lot of trouble getting my head around MQTT.
Me TOO.
In fact, I had so much trouble, and there were so many poor tutorials out there, that I gave up on it.
What I found was all very general or very specific--either "this is why MQTT is great" or "How to attach an Acme Roadrunner Juicer to a T-1000 with a rPi0".
Can you point me at a tutorial that's in between these two? I even got as far as installing Mosquitto on my linux box and it received and sent test commands, but I had NO idea how to proceed from there.
Sun Feb 28, 2021 2:39 pm
MQTT is just a messaging protocol. Clients connect to a broker, and tell the broker what messages they want. The same or other clients send messages to the broker, and if the message is on the subscription list for a specific client, that client gets a copy of the message. That's it.
Messages are identified by the "topic", which is a hierarchical text string. So "indigo" might be the top level in a hierarchy, with "indigo/devices" as an intermediate level, and "indigo/devices/4582739" as a device specific topic. Wildcards are allowed when subscribing, so a subscription to the "indigo/#" topic will get the client all messages that start with "indigo/".
The contents (payload) of a message can be pretty much anything, but in the Indigo world there's two primary types: "Raw", which means it's a simple string, or "JSON", which means it's a string that can be converted into a Python data structure. The contents of the payload is totally up to the sender of the message, and is usually structured the same for any particular topic string.
So to use MQTT, you need a client device that publishes (sends) MQTT messages. From there, you proceed based on what messages it sends.
Mon Mar 08, 2021 10:28 am
mundmc offline
CliveS wrote:
Me TOO.
I got my feet wet by:
a) starting an mqtt server (any will do, nas, docker, native mac or windows)
b) publish messages from a device like your phone to a topic. Keep the messages super simple, like a string “test”
c) use a separate device to subscribe to that topic and receive the broadcast
d) experiment with json formatting as the payload {“command”:”test”}
e) install MQTT Connector
f) try to get Indigo to fire triggers in response to a published topic
g) install Shims and try to create devices on the fly from payloads
Sun May 30, 2021 4:40 pm
mclass offline
Hi!
I have worked my way through this thread, and have been wondering why the Sonoff Zigbee Bridge with Tasmota MQTT has not yet appeared in the discussion. Seems ideal as with wifi connection to the network the bridge can be placed centrally within the Zigbee network.
Has anyone had any experience with the Sonoff Bridge?
mclass
Sun May 30, 2021 4:51 pm
siclark offline
Interesting product and great price point. Not sure if it’s been out that long. The main problem I see is lack of support for other brands products. Is the reason some of us looked for a Hue alternative as it didn’t support sensors.
What incentive does Sonoff have to support all new devices coming to the market ?
Sun Nov 14, 2021 11:15 am
cesarvog offline
I ended up choosing a different solution to integrate my growing Zigbee devices into my Indigo control center.
Some time ago, I replaced my Hue Bridge with a Dresden-Eletroniks Conbee II Zigbee USB interface.
I'm glad I did it, because it not only has better range than the 2nd gen Hue Hub I was using, but also supports additional Zigbee device types, like switches, sensors,.... It comes with it's own set of software applications: deCONZ is the back-end software that talks to the hardware inside either the Conbee II or the Raspbee II (similar hardware in a Raspberry Pi GPIO interface model). For the front-end, there is the Phoscon App, which is a web based panel that talks to the deCONZ back-end and presents a nice enough interface to interact with the Zigbee devices registered into the Conbee II USB interface, or the Raspbee II GPIO interface.
To try to integrate it with Indigo, I first tried using zigbee2mqtt, therefore bypassing the need for deCONZ entirely. Zigbee2MQTT talked to an MQTT Broker (in my case, Mosquitto), which then is accessed from Indigo by the excellent Indigo MQTT Connector and MQTT Shims plugins (Thanks for both, Joe).
Integration worked fairly well, but I had some difficulty wrapping my head around how to set bulbs RGB color and/or color temp. Once I had each individual bulb set to the desired color (which was done posting msgs on MQTT Explorer) , then I could use Indigo to turn on/turn off, which worked every time, as expected. But later, when I had to replace a bulb, I could not, once again, wrap my head around to the setup specifics...
So thats why I very recently decided to give the Dresden-Eletroniks deCONZ back-end and Phoscon App front-end a new try...
I re-installed deCONZ into the same Raspberry Pi that also supports my z-wave remote interface (via ser2net - exactly like Homeseer's. Z-NET) and that lives hidden in a cupboard in the center of the house. Once it was installed, I installed Homebridge on my Mac to integrate the deCONZ back-end with Apple's HomeKit. It worked right after installation.
The OEM software also allowed me to update the firmware on my Conbee II interface to the latest version, and also to choose a different Zigbee channel for my mesh to work on, thus avoiding 2.4 Ghz channels that could interfere with Wifi.
Then, I reinstalled the Hue Lights Indigo plugin (Thanks, Mr. Sheldon), to integrate Indigo with deCONZ. This was easy, because the deCONZ Rest API is basically the same as the Hue API. The plugin worked right out of the box with the deCONZ back-end!
Next thing was defining Indigo devices for each deCONZ device or groups of devices. From then, I could automate them from Indigo and everything worked exactly as expected.
The Hue Lights plugin obvioulsy does not support every type of Zigbee devices, since it's oriented to the Hue Bridge, which mostly supports devices types also made by Phillips/Signify, but I was able to have the plugin support a few cheap 3 way Zigbee switches I got from an online store, with no difficulty at all. All I had to do was to modify a single text file to include the exact device model, as presented in the Homebridge web panel, or in the Phoscon App.
Knowing myself, I can say that I do intend to get a Hubitat Elevation Hub sometime in the near future. Just to give it a try, as I was bitten by the HomeAutomation fly several years ago... But, for now, I'm a happy camper with the results of integrating my Zigbee based devices into my Indigo system.
For anyone willing to go the deCONZ route, please be aware that, from Indigo to Zigbee devices react instantaneously. On the other hand, let's say I turn on/off a device elsewhere (on the a physical switch for example, or via Homebridge, or Phoscon App, or any of the many other Hue compatible apps existing in the iPhone App Store, then there is a noticeable 2-8 seconds delay for the change to be reflected in Indigo's interface.
That doesn't bother me at all, because I'm used to use Indigo only, whenever I want to control any of my so called "smart" devices, as I see it as my main smart devices control center.
Cesar
Sun Nov 14, 2021 3:19 pm
Nice. It could be the delay is caused by the reporting schedule of the device that you're controlling locally (or other step in the chain). If you haven't already, you might look for a setting/parameter somewhere in the chain that could speed up the status change message.
Thanks for sharing!
Wed Nov 17, 2021 12:02 am
mundmc offline
Indigo and Zigbee
Cesar
I will join your Patreon if you start a YouTube channel where you demonstrate stuff like what you just described! Thank you for such an awesome walk-through of your thought process and execution on this project- it is both inspiring and dangerously tempting…
