Use dew point instead of relative humidity
Sun Jun 05, 2016 12:55 pm
PvG offline
Until recently I used a simple threshold on the humidity in our bathroom to control the fan of our central ventilation system. This doesn't work optimal: in winter the air is quite dry over here and in summer the humidity is quite high. So, to make sure that the fan turns off in summer, I needed to adapt the threshold.
I now changed this to dew point control: if the dew point temperature in the bathroom comes too close to the lowest temperature in house, the fan is turned on. The calculation is quite simple and is easy to integrate in python: Tdewpoint = Temp - (100 - RH) / 5. This should provide better control in both summer and winter. My $0.02. :wink:
I use the following python code triggered by temp/humidity changes in the bathroom. It sets 3 variables which are used for plotting and fan control:
# determine minimum in-house temperature
T1 = float(indigo.devices[1341195411].displayStateValRaw) # "0.garage.temperature"
T2 = float(indigo.devices[1715241931].displayStateValRaw) # "0.keuken.temperature"
T3 = float(indigo.devices[391429136].displayStateValRaw) # "0.woonkamer.eethoek.temperature"
T4 = float(indigo.devices[740772309].displayStateValRaw) # "0.woonkamer.zithoek.temperature"
T5 = float(indigo.devices[102683172].displayStateValRaw) # "1.badkamer.temperature1"
T6 = float(indigo.devices[1635136217].displayStateValRaw) # "1.badkamer.temperature2"
T7 = float(indigo.devices[1572729555].displayStateValRaw) # "2.slaapkamer.temperature"
mintemp = min(T1, T2, T3, T4, T5, T6, T7)
indigo.variable.updateValue(1201762210, value=unicode(mintemp)) # "afzuiging_mintemp"
# calculate dew point
temperature = float(indigo.devices[102683172].displayStateValRaw) # "1.badkamer.temperature1"
humidity = float(indigo.devices[687813397].displayStateValRaw) # "1.badkamer.humidity1"
dewpoint = temperature - (100.0 - humidity) / 5 # accurate +/-1 C for RH > 50%
indigo.variable.updateValue(1092135224, value=unicode(dewpoint)) # "afzuiging_dewpoint"
# determine whether to humid
if dewpoint > mintemp - 4.0:
   humid = "true"
   humid = "false"
indigo.variable.updateValue(1955231371, value=humid) # "afzuiging_humid"
Users browsing this forum: No registered users and 21 guests
