A day in the life...
Thu Aug 20, 2015 6:53 am
john polasek offline
Re: A day in the life...
" At the end of the charging session, Indigo alerts me to how many kWh were consumed via an interface with SiteSage." What kind of interface do you have with Sitesage? They demanded a huge payout and NDA if I wanted to do something similar...
Thu Aug 20, 2015 6:56 am
Bollar offline
I did sign an NDA, but did not have to pay a fee. I wrote a simple Python script to pull data via the API.
It's a shame they're so tight with access.
Sun Apr 03, 2016 8:51 pm
dz1rfj offline
howartp wrote:
At 6.30am, my bedroom motion sensor starts watching me, and Airfoil starts announcing the time every 5 minutes until I go to work - once I wake up, the sensor turns on my bedside lamp.
At 6.45 and 7am Airfoil announces today's weather. At 8.30, if I haven't already pressed a manual keypad button to do this earlier, Airfoil and all bedroom lights/devices turn off.
Entering the kitchen, the down lighters come on dim unless it's bright enough.
Throughout the day, the heating comes on/off depending on schedule and the temps reported by sensors around house. Any lights left on in unattended rooms go off after 5-10 mins depending on room, and TV goes off after 15 minutes.
When alarm is set, all devices and lights go off.
Tea time, mum turns on the Chip Pan - Airfoil warns us to put on a pair of goggles to avoid the toxic fumes when she leaves it cooking unattended, reminds her it's still on every minute, and turns it off after 10 minutes.
Sunset, the house lamps (and Christmas lights) come on.
On entering bedroom, lamp comes on - unless TV is on, because that's bright enough.
Bedtime, setting the alarm knocks off all lights/devices and heating and the day starts again tomorrow.
HI,
Migrating form Vera, and I was wondering how you have Airfoil announce the time every five minutes, are you using a separate plug in ?
-Brian
Sun Apr 03, 2016 11:57 pm
canalrun offline
I have a simple set up up where I mainly use Indigo as an alerter.
When someone presses the doorbell button, the Aeon doorbell generates an "On" event which I use to flash Z-Wave bulbs (Python script) that I have located in each room of the house.
If my Z-Smoke smoke detector goes off, it generates an event which I use to flash light bulbs in my bedroom and also cycle On/Off a plug-in outlet to which I have a 9V "wall wart" DC supply that powers a bed shaker.
I also have a few motion detectors and plug-in wall outlets to turn on/off lights.
Barry.
Mon Apr 04, 2016 12:42 am
dz1rfj wrote:
HI,
You just need the Airfoil plugin and a schedule.
In the schedule, I think I have a two-line script (action > server > execute python) that says something along the lines of:
indigo.speak("the time is " . timedate.getTime)
I'll check it tonight.
Oeter
Mon Apr 04, 2016 12:52 am
Actually, just checked.
I changed it at some point - the schedule just starts a 5 minute timer IF variable holDontWake is false.
Then there's a trigger on the timer expiring that restarts the timer and executes the following.
The code could be shrunk - I copied it from a larger script I have where I speak lots of things 'if debug()' which is why there's a separate function calling speak().
I have various routines that know when I've left/got up/gone to work, so one of those will stop the timer.
Peter
Mon Apr 04, 2016 11:50 am
dz1rfj offline
Peter, thanks for the reply. I tried this, but must be missing something.
##Speak Time
def speak(inText):
indigo.server.speak(inText)
thetime = datetime.strftime(datetime.now(),"%H %M")
speak("The time is " + thetime)
Does python require a start and an end like a vba function ? and what is the strftime in that line, is formatting the time string ?
-Brian
Mon Apr 04, 2016 12:09 pm
Hello dz1rfj, I just replied to your other thread with a possible solution.
Dave
Mon Apr 04, 2016 12:35 pm
You missed a line: from datetime import datetime
strftime is String-format-time. It formats the time so Indigo says 'zero seven fifty five' for example.
I think %h instead of %H is without the leading zero from memory.
Mon Apr 04, 2016 12:38 pm
dz1rfj offline
Yes! Thank you.. It now works, and I was able to locate the python reference about the difference in the capitalizations, thanks for pointing that out. This is getting really interesting now, great tools, and a great community.
-Brian
Mon Apr 04, 2016 12:42 pm
My mum loves it (not!) when Indigo reminds her to take her tablets three times during breakfast; but it does usually work because she has them more than she used to.
"Have you eaten your tablets yet? You never eat your tablets on time, you naughty girl" three times winds her up :-)
Mon Apr 04, 2016 1:14 pm
dz1rfj offline
That is AWESOME! I might set that up for me now, before I totally lose my mind, although , my wife ways I am already there :?
-Brian
Mon Apr 04, 2016 1:40 pm
I love that! I need to do something like that to wind up the wife!
Mon Apr 04, 2016 1:47 pm
"Darling, could you pass Durosity the <...> please?"
Mon Apr 04, 2016 1:56 pm
Bacon. It's always bacon.
