Ring Panic Button device definition request
Forum rules
Mon Mar 04, 2024 2:33 pm
Butch2427 offline
Looking for a future device definition for the Ring Panic Button:
Amazon link:
https://www.amazon.com/dp/B07MV5B9XC?ps ... ct_details
This included without issue but isn't currently responding to indigo. I submitted a request for definition but was unable to tell if that actually went through.
Indigo Z-Wave Version: 2023.2.0
Node ID: 135
Model: Notification Sensor
Model ID: 08010101
Manufacturer: Ring
Manufacturer ID: 0346
Protocol Version: 6.04
Application Version: 10.15
Model Definition Version: 0
Library Type: 3
Class Name: Notification Sensor
Class Hierarchy: 04 : 07 : 01
Command Class Base: 00
Command Versions: 20v1 5Ev1 55v1 9Fv1 85v1 59v1 80v1 70v1 5Av1 72v1 71v1 73v1 6Cv1 86v1 84v2 7Av1
Features: routing, battery, beaming, waking
Neighbors: 7, 9, 11, 13, 14, 17, 20, 22, 23, 24, 25, 42, 45, 46, 48, 54, 58, 59, 62, 63, 67, 68, 69, 72, 73, 75, 76, 77, 78, 79, 98, 99, 111, 113, 119, 120, 121, 134
Associations: 1:[1]
Config Values: - none -
Cheers.
