MCO Home A8-9 Multisensor
Forum rules
Thu Mar 02, 2023 2:16 pm
Wizard Sleeve offline
I have one of these sensors and it pretty much seems to do everything on paper. Its reporting nicely in to the indigo log and I am able to split quite a few of the reports out based on the units (ppm, lux, dBA, oC, Micro-g/m3) but some of them have the same units which I have no idea what they are for like several reports contain % so I haven't yet found a way to filter them in to variables with triggers. Would be very nice if indigo supported these as I would replace all my sensors in each room with one. I currently have no way of testing the PIR compared to my current hard wired PIRs as i cant read that yet.
The only bad thing I would say at the moment about this is the screen is on constantly and it would be nice if it went off and came back on with PIR activity or even better for the cinema room...remote controlled.
Lee
Fri Mar 03, 2023 4:51 pm
Re: MCO Home A8-9 Multisensor
Hi Lee,
That is an interesting device – I hadn't seen or heard about it before.
Please re-sync the device in Indigo and copy/paste the Event Log window results into a reply so we can see specifically how the device identifies itself.
Sun Mar 05, 2023 11:56 am
Z-Wave Syncing - started for "038 - Multilevel Sensor (routing)"
Z-Wave Debug SENT getNodeNeighbors: 01 06 00 80 26 01 01 5F
Z-Wave Debug RCVD getNodeNeighbors: 01 20 01 80 50 FC 2F EF 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 30 (no inbound callback)
Z-Wave Debug . . getNodeNeighbors: nodeId 038, neighbors: 5, 7, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 22, 25, 26, 27, 28, 30, 31, 32, 34
Z-Wave Syncing - retrieved module neighbors list: 5, 7, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 22, 25, 26, 27, 28, 30, 31, 32, 34
Z-Wave Syncing - assigning return route to "038 - Multilevel Sensor (routing)"
Z-Wave Debug SENT assignReturnRoute: 01 05 00 46 26 01 9B
Z-Wave Debug RCVD assignReturnRoute: 01 04 01 46 01 BD (no inbound callback)
Z-Wave Debug RCVD assignReturnRoute: 01 05 00 46 01 00 BD
Z-Wave Debug . . assignReturnRoute: node 038, success 1
Z-Wave Debug SENT requestNodeInfo: 01 06 00 60 26 24 4B D0
Z-Wave Debug RCVD nodeInfoFrame: 01 16 00 49 84 26 10 04 21 01 5E 86 72 5A 73 85 59 70 31 55 9F 6C 7A F4
Z-Wave Debug . . nodeInfoFrame: node 038, combined class list: 20v1 31v1 5Ev1 86v1 72v1 5Av1 73v1 85v1 59v1 70v1 55v1 9Fv1 6Cv1 7Av1
Z-Wave Debug SENT requestManufactureInfo: 01 09 00 13 26 02 72 04 25 4C DE
Z-Wave Debug RCVD requestManufactureInfo: 01 07 00 13 4C 00 00 02 A5 (node ACK)
Z-Wave Debug RCVD requestManufactureInfo: 01 0E 00 04 00 26 08 72 05 01 5F A8 03 13 52 18
Z-Wave Debug . . requestManufactureInfo: node 038, manufacturerId 015F, productId A8031352
Z-Wave Debug . . requestManufactureInfo: MCOHome, Multilevel Sensor (routing)
Z-Wave Syncing - retrieved manufacture and model names: MCOHome - 015F, Multilevel Sensor (routing) - A8031352
Z-Wave Debug SENT requestVersInfoGen: 01 09 00 13 26 02 86 11 25 4D 3E
Z-Wave Debug RCVD requestVersInfoGen: 01 07 00 13 4D 00 00 02 A4 (node ACK)
Z-Wave Debug RCVD requestVersInfoGen: 01 0F 00 04 00 26 09 86 12 03 06 07 06 04 FF 00 B0
Z-Wave Debug . . requestVersInfoGen: node 038, protoVers 6.07, appVers 6.04
Z-Wave Syncing - retrieved protocol version 6.07, app version 6.04
Z-Wave Debug SENT requestVersInfoCmdClass: 01 0A 00 13 26 03 86 13 31 25 4E 0C
Z-Wave Debug RCVD requestVersInfoCmdClass: 01 07 00 13 4E 00 00 03 A6 (node ACK)
Z-Wave Debug RCVD requestVersInfoCmdClass: 01 0A 00 04 00 26 04 86 14 31 0A 7A
Z-Wave Debug . . requestVersInfoCmdClass: node 038, class command 31 using version 10
Z-Wave Debug . . requestVersInfoCmdClass: node 038, combined class list: 20v1 31v10 5Ev1 86v1 72v1 5Av1 73v1 85v1 59v1 70v1 55v1 9Fv1 6Cv1 7Av1
Z-Wave Syncing - retrieved class hierarchy: Routing Slave : Multilevel Sensor : Multilevel Sensor (routing) (04 : 21 : 01, base 31)
Z-Wave Syncing - retrieved command classes: 20v1 31v10 5Ev1 86v1 72v1 5Av1 73v1 85v1 59v1 70v1 55v1 9Fv1 6Cv1 7Av1
Z-Wave Syncing - retrieved capabilities: routing, beaming
Z-Wave Debug SENT requestAssociationGroupCount: 01 09 00 13 26 02 85 05 25 4F 2B
Z-Wave Debug RCVD requestAssociationGroupCount: 01 07 00 13 4F 00 00 02 A6 (node ACK)
Z-Wave Debug RCVD requestAssociationGroupCount: 01 09 00 04 00 26 03 85 06 01 55
Z-Wave Debug . . requestAssociationGroupCount: node 038, group count: 1
Z-Wave Debug SENT requestAssociations: 01 0A 00 13 26 03 85 02 01 25 50 30
Z-Wave Debug RCVD requestAssociations: 01 07 00 13 50 00 00 02 B9 (node ACK)
Z-Wave Debug RCVD requestAssociations: 01 0B 00 04 00 26 05 85 03 01 01 00 55
Z-Wave Debug . . requestAssociations: node 038, group: 1, num associations: 0, max associations: 1, replies left: 0
Z-Wave Debug . . requestAssociations: node 038, group: 1, associations: []
Z-Wave Syncing - retrieved group 1 associations: []
Z-Wave Debug SENT addInterfaceAssociation: 01 0B 00 13 26 04 85 01 01 01 25 51 35
Z-Wave Debug RCVD addInterfaceAssociation: 01 07 00 13 51 00 00 02 B8 (node ACK)
Z-Wave Syncing - added group 1 association to interface
Z-Wave Debug . . addInterfaceAssociation: node 038, group: 1, associations: [1]
Z-Wave Syncing - created device "038 - Multilevel Sensor (routing)"
Z-Wave Syncing - complete
Z-Wave Debug terminatingSyncUI
Trigger Studio @ Kitchen @ Control @ Room Mode @ Normal @ Motion Detection @ OFF TIMER (10 Mins)
Z-Wave Debug RCVD requestVarSensorStatus: 01 0B 00 04 00 26 05 31 05 37 01 00 D1
Z-Wave Debug . . requestVarSensorStatus: node 038, endpoint None, type 55, raw value 0100...
Z-Wave Debug . . requestVarSensorStatus: 0% (float: 0.000000)
Z-Wave received "038 - Multilevel Sensor (routing)" sensor update to 0%
Z-Wave received "038 - Multilevel Sensor (routing)" units changed to %
Sun Mar 05, 2023 11:57 am
Hope all that is of some help
Sun Mar 05, 2023 3:37 pm
Thanks, we'll look into adding it.
Wed Jan 24, 2024 1:46 pm
Indigo 2023.2.0 is now available and includes support for the MCOHome Multi Sensor (A8-9). We don't have one to QA against, so let us know if it works for you.
