Zooz ZSE41 not working right
Forum rules
Sat Jan 21, 2023 11:26 pm
t-star offline
I know this device was originally added a little back. Just got a new one. You can see that when it gets an open or close notification it comes across as a change to the status update. Not the open or close. It isn’t triggering open/close “events”.
I do have the reverse open close flag on in the device. See device properties below.
Z-Wave received "EXT-BMT-GATE" status update is off
Z-Wave received "EXT-BMT-GATE" status update is on
Jan 22, 2023 at 12:01:25 AM
Z-Wave Indigo Device "EXT-BMT-GATE" Z-Wave Properties:
Indigo Z-Wave Version: 2022.2.1
Node ID: 83
Model: Open / Close XS Sensor (ZSE41)
Model ID: 7000E001
Manufacturer: Zooz
Manufacturer ID: 027A
Protocol Version: 7.13
Application Version: 1.30
Model Definition Version: 1
Library Type: 3
Class Name: Notification Sensor
Class Hierarchy: 04 : 07 : 01
Command Class Base: 00
Command Versions: 20v1 5Ev1 85v1 8Ev1 59v1 55v1 86v1 72v1 5Av1 73v1 80v1 9Fv1 71v1 87v1 30v1 70v1 84v2 6Cv1 7Av1
Features: routing, battery, beaming, waking
Neighbors: - none -
Associations: 1:[1] 2:[]
Config Values: 5:1 1:1
I know it may be a while before fixed. If you know what raw commands or how to tell me how to tell, I could leverage that for now.
Sun Jan 22, 2023 7:21 pm
t-star offline
Re: Zooz ZSE41 not working right
Well, it appears that I made a mistake and everything is fine. I didn't see one of the conditionals.
My bad.
