- Posted on
Mon Jan 22, 2024 6:07 pm
epounds
offline
I'm using the ZEN14 double outlet and it's showing up twice in the device list. (attached) Syncing does not resolve the issue and keeps the devices disabled.
Any thoughts on how to resolve? Thanks!
Syncing - started for "Backyard Fence Switches"
Z-Wave Syncing - retrieved module neighbors list: 1, 2, 3, 4, 5, 6, 7, 8, 9, 11, 12, 16, 18, 20, 21, 24, 25, 27, 28, 32, 33, 34, 35, 36, 40, 41, 42, 43, 45, 47, 48, 50, 52, 53, 68, 71, 72
Z-Wave Syncing - assigning return route to "051 - Backyard Fence Switches"
Z-Wave Syncing - retrieved manufacture and model names: Zooz - 027A, Double Outlet Relay (ZEN14) - 7000B003
Z-Wave Syncing - retrieved protocol version 7.16, app version 1.10
Z-Wave Syncing - retrieved class hierarchy: Routing Slave : Relay Switch : -- (04 : 10 : 00, base 25)
Z-Wave Syncing - retrieved command classes: 20v1 25v1 5Ev1 85v1 8Ev1 59v1 55v1 86v1 72v1 5Av1 87v1 73v1 98v1 9Fv1 60v4 6Cv1 7Av1 70v1
Z-Wave Syncing - retrieved capabilities: routing, beaming, security
Z-Wave Syncing - retrieved multi-endpoint types: 1:(10 : 00), 2:(10 : 00)
Z-Wave Syncing - retrieved multi-endpoint classes: 1:[5E 25 85 59 8E 6C 98 9F], 2:[5E 25 85 59 8E 6C 98 9F]
Z-Wave Syncing - retrieved group 3 associations: []
Z-Wave Syncing - retrieved parameter 1 "LED behavior" is 0 "ON when switch is ON, OFF when switch is OFF"
Z-Wave Syncing - retrieved parameter 7 "LED brightness" is 2 "Dim"
Z-Wave Syncing - retrieved parameter 6 "Power up state" is 2 "Last State"
Z-Wave Syncing - retrieved parameter 8 "Enable manual control via button" is true
Z-Wave Syncing - disabling device "051 - Switch 2" using same node ID (resync disabled device with correct node ID to enable)
Z-Wave Syncing - disabling device "Backyard Fence Lights" using same node ID (resync disabled device with correct node ID to enable)
Z-Wave Syncing - disabling device "Backyard Fence Switches" using same node ID (resync disabled device with correct node ID to enable)
Z-Wave Syncing - complete
Z-Wave sent "Backyard Fence Switches" status request
- ZEN14.png (154.32 KiB) Viewed 600 times
