Fibaro - The Heat Controller
Forum rules
Mon Aug 28, 2023 12:16 pm
gillekes offline
Re: Fibaro - The Heat Controller
Any progress on adding the Heat Controller?
Gilles
Mon Nov 27, 2023 5:03 am
gillekes offline
Any news on adding the heat controller?
Thanks.
Gilles
Tue Nov 28, 2023 1:55 pm
Sorry, this one slipped through the cracks – we'll look at getting into the next release.
Sun Dec 03, 2023 3:22 am
pnm offline
Are you getting any closer to adding this, it's now been a year since I posted the initial request?
I can get the TRV to work, but the additional temperature sensor won't report the battery status.
Edit
Just seen the recent post, so I'm guessing 2024 now.
Wed Jan 24, 2024 1:45 pm
Indigo 2023.2.0 is now available and includes support for this Fibaro thermostat. We don't have one to QA against, so let us know if it works for you.
Wed Jan 24, 2024 1:56 pm
gillekes offline
Thank you Matt,
I'll be back at home after the 5th of February. I'll post feedback then.
Sun Mar 10, 2024 1:32 pm
gillekes offline
Hi Matt,
I got finally time to mount and test the Heat Controller.
The device is recognised with the external temperature sensor and I'm able to set the temperature.
Points that are not working:
- There is no temperature reading - states (null)º
- When setting the thermostat to the highest temperature (on the physical device - valve fully opened - magenta color) Indigodomo doesn't recognise the mode with the following line in the log:
"Z-Wave received "059 - Thermostat" mode is unknown"
In the device window - custom state:
"zwaveHvacOperationMode = 31"
"zwaveHvacOperationModeName = unknown
Thanks.
Gilles
Mon Mar 11, 2024 1:56 pm
Hi Gilles,
Please re-sync the device in Indigo, try sending it a status request (using the button in the Main Window UI), then copy/paste the Event Log window results into a reply for me.
The unknown mode log lines are a known limitation of Indigo, which is that Indigo only supports OFF/HEAT/COOL/AUTO modes for thermostat devices.
Mon Mar 11, 2024 2:41 pm
gillekes offline
Hi Matt,
Please find the log after resyning and the update request
Z-Wave Syncing - started for "059 - Thermostat"
Z-Wave Debug SENT getNodeNeighbors: 01 06 00 80 3B 01 01 42
Z-Wave Debug RCVD getNodeNeighbors: 01 20 01 80 08 61 04 05 04 40 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 F2 (no inbound callback)
Z-Wave Debug . . getNodeNeighbors: nodeId 059, neighbors: 4, 9, 14, 15, 19, 25, 27, 35, 47, 56
Z-Wave Syncing - retrieved module neighbors list: 4, 9, 14, 15, 19, 25, 27, 35, 47, 56
Z-Wave Syncing - assigning return route to "059 - Thermostat"
Z-Wave Debug SENT assignReturnRoute: 01 05 00 46 3B 01 86
Z-Wave Debug RCVD assignReturnRoute: 01 04 01 46 01 BD (no inbound callback)
Z-Wave Debug RCVD assignReturnRoute: 01 05 00 46 01 00 BD
Z-Wave Debug . . assignReturnRoute: node 059, success 1
Z-Wave Debug SENT requestNodeInfo: 01 06 00 60 3B 24 E9 6F
Z-Wave Debug RCVD nodeInfoFrame: 01 22 00 49 84 3B 1C 04 08 06 5E 86 8E 31 40 43 53 98 9F 55 56 59 5A 60 6C 71 72 75 80 70 81 7A 73 22 85 A8
Z-Wave Debug . . nodeInfoFrame: node 059, combined class list: 20v1 40v1 43v1 72v1 86v1 5Ev1 8Ev1 31v1 53v1 98v1 9Fv1 55v1 56v1 59v1 5Av1 60v1 6Cv1 71v1 75v1 80v1 70v1 81v1 7Av1 73v1 22v1 85v1
Z-Wave Debug SENT requestManufactureInfo: 01 09 00 13 3B 02 72 04 25 EA 65
Z-Wave Debug RCVD requestManufactureInfo: 01 07 00 13 EA 00 00 02 03 (node ACK)
Z-Wave Debug RCVD requestManufactureInfo: 01 0E 00 04 00 3B 08 72 05 01 0F 13 01 10 01 BC
Z-Wave Debug . . requestManufactureInfo: node 059, manufacturerId 010F, productId 13011001
Z-Wave Debug . . requestManufactureInfo: Fibaro System, Radiator Thermostat (FGT001)
Z-Wave Syncing - retrieved manufacture and model names: Fibaro System - 010F, Radiator Thermostat (FGT001) - 13011001
Z-Wave Debug SENT requestVersInfoGen: 01 09 00 13 3B 02 86 11 25 EB 85
Z-Wave Debug RCVD requestVersInfoGen: 01 07 00 13 EB 00 00 03 03 (node ACK)
Z-Wave Debug RCVD requestVersInfoGen: 01 11 00 04 00 3B 0B 86 12 03 04 3D 04 07 01 01 02 0A 7F
Z-Wave Debug . . requestVersInfoGen: node 059, protoVers 4.61, appVers 4.07
Z-Wave Syncing - retrieved protocol version 4.61, app version 4.07
Z-Wave Debug SENT requestVersInfoCmdClass: 01 0A 00 13 3B 03 86 13 31 25 EC B3
Z-Wave Debug RCVD requestVersInfoCmdClass: 01 07 00 13 EC 00 00 03 04 (node ACK)
Z-Wave Debug RCVD requestVersInfoCmdClass: 01 0A 00 04 00 3B 04 86 14 31 05 68
Z-Wave Debug . . requestVersInfoCmdClass: node 059, class command 31 using version 5
Z-Wave Debug . . requestVersInfoCmdClass: node 059, combined class list: 20v1 40v1 43v1 72v1 86v1 5Ev1 8Ev1 31v5 53v1 98v1 9Fv1 55v1 56v1 59v1 5Av1 60v1 6Cv1 71v1 75v1 80v1 70v1 81v1 7Av1 73v1 22v1 85v1
Z-Wave Debug SENT requestVersInfoCmdClass: 01 0A 00 13 3B 03 86 13 60 25 ED E3
Z-Wave Debug RCVD requestVersInfoCmdClass: 01 07 00 13 ED 00 00 03 05 (node ACK)
Z-Wave Debug RCVD requestVersInfoCmdClass: 01 0A 00 04 00 3B 04 86 14 60 04 38
Z-Wave Debug . . requestVersInfoCmdClass: node 059, class command 60 using version 4
Z-Wave Debug . . requestVersInfoCmdClass: node 059, combined class list: 20v1 40v1 43v1 72v1 86v1 5Ev1 8Ev1 31v5 53v1 98v1 9Fv1 55v1 56v1 59v1 5Av1 60v4 6Cv1 71v1 75v1 80v1 70v1 81v1 7Av1 73v1 22v1 85v1
Z-Wave Syncing - retrieved class hierarchy: Routing Slave : Thermostat : General Thermostat (v2) (04 : 08 : 06, base 40)
Z-Wave Syncing - retrieved command classes: 20v1 40v1 43v1 72v1 86v1 5Ev1 8Ev1 31v5 53v1 98v1 9Fv1 55v1 56v1 59v1 5Av1 60v4 6Cv1 71v1 75v1 80v1 70v1 81v1 7Av1 73v1 22v1 85v1
Z-Wave Syncing - retrieved capabilities: routing, battery, beaming, security, frequentWaking
Z-Wave Debug SENT requestMultiEndPointInfo: 01 09 00 13 3B 02 60 07 25 EE 70
Z-Wave Debug RCVD requestMultiEndPointInfo: 01 07 00 13 EE 00 00 02 07 (node ACK)
Z-Wave Debug RCVD requestMultiEndPointInfo: 01 0B 00 04 00 3B 05 60 08 00 02 00 A4
Z-Wave Debug . . requestMultiEndPointInfo: node 059, numEndPoints 2, sameClass False, notStatic False
Z-Wave Debug SENT requestMultiEndPointDetails: 01 0A 00 13 3B 03 60 09 01 25 EF 7C
Z-Wave Debug RCVD requestMultiEndPointDetails: 01 07 00 13 EF 00 00 03 07 (node ACK)
Z-Wave Debug RCVD requestMultiEndPointDetails: 01 1A 00 04 00 3B 14 60 0A 01 08 06 5E 8E 40 43 53 98 9F 59 6C 71 75 80 81 85 22 BB
Z-Wave Debug . . requestMultiEndPointDetails: node 059, endPoint 1, notStatic False, class hierarchy 08 : 06
Z-Wave Debug . . requestMultiEndPointDetails: node 059, combined multi-endpoint types: 1:(08 : 06)
Z-Wave Debug . . requestMultiEndPointDetails: node 059, combined multi-endpoint classes: 1:[5E 8E 40 43 53 98 9F 59 6C 71 75 80 81 85 22]
Z-Wave Debug SENT requestMultiEndPointDetails: 01 0A 00 13 3B 03 60 09 02 25 F0 60
Z-Wave Debug RCVD requestMultiEndPointDetails: 01 07 00 13 F0 00 00 03 18 (node ACK)
Z-Wave Debug RCVD requestMultiEndPointDetails: 01 16 00 04 00 3B 10 60 0A 02 21 01 5E 8E 31 98 9F 59 6C 71 80 85 22 0B
Z-Wave Debug . . requestMultiEndPointDetails: node 059, endPoint 2, notStatic False, class hierarchy 21 : 01
Z-Wave Debug . . requestMultiEndPointDetails: node 059, combined multi-endpoint types: 1:(08 : 06), 2:(21 : 01)
Z-Wave Debug . . requestMultiEndPointDetails: node 059, combined multi-endpoint classes: 1:[5E 8E 40 43 53 98 9F 59 6C 71 75 80 81 85 22], 2:[5E 8E 31 98 9F 59 6C 71 80 85 22]
Z-Wave Syncing - retrieved multi-endpoint types: 1:(08 : 06), 2:(21 : 01)
Z-Wave Syncing - retrieved multi-endpoint classes: 1:[5E 8E 40 43 53 98 9F 59 6C 71 75 80 81 85 22], 2:[5E 8E 31 98 9F 59 6C 71 80 85 22]
Z-Wave Debug SENT requestAssociationGroupCount: 01 09 00 13 3B 02 85 05 25 F1 88
Z-Wave Debug RCVD requestAssociationGroupCount: 01 07 00 13 F1 00 00 02 18 (node ACK)
Z-Wave Debug RCVD requestAssociationGroupCount: 01 09 00 04 00 3B 03 85 06 01 48
Z-Wave Debug . . requestAssociationGroupCount: node 059, group count: 1
Z-Wave Debug SENT requestAssociations: 01 0A 00 13 3B 03 85 02 01 25 F2 8F
Z-Wave Debug RCVD requestAssociations: 01 07 00 13 F2 00 00 02 1B (node ACK)
Z-Wave Debug RCVD requestAssociations: 01 0B 00 04 00 3B 05 85 03 01 01 00 48
Z-Wave Debug . . requestAssociations: node 059, group: 1, num associations: 0, max associations: 1, replies left: 0
Z-Wave Debug . . requestAssociations: node 059, group: 1, associations: []
Z-Wave Syncing - retrieved group 1 associations: []
Z-Wave Debug SENT addInterfaceMultiInstanceAssociation: 01 0D 00 13 3B 06 8E 01 01 00 01 01 25 F3 84
Z-Wave Debug RCVD addInterfaceMultiInstanceAssociation: 01 07 00 13 F3 00 00 02 1A (node ACK)
Z-Wave Syncing - added group 1 multi association to interface
Z-Wave Debug . . addInterfaceAssociation: node 059, group: 1, associations: [1]
Z-Wave Debug SENT requestClockInfo2: 01 09 00 13 3B 02 81 05 25 F4 89
Z-Wave Debug RCVD requestClockInfo2: 01 07 00 13 F4 00 00 04 1B (node ACK)
Z-Wave Debug RCVD requestClockInfo: 01 0A 00 04 00 3B 04 81 06 34 25 58
Z-Wave Debug . . requestClockInfo: node 059, 20:37 day-of-week 1
Z-Wave Debug SENT setClock: 01 0B 00 13 3B 04 81 04 34 25 25 F5 9C
Z-Wave Debug RCVD setClock: 01 07 00 13 F5 00 00 02 1C (node ACK)
Z-Wave Syncing - synced server clock to module (20:37, Monday)
Z-Wave Debug SENT requestBatteryLevel2: 01 09 00 13 3B 02 80 02 25 F6 8D
Z-Wave Debug RCVD requestBatteryLevel2: 01 07 00 13 F6 00 00 03 1E (node ACK)
Z-Wave Debug RCVD requestReply1: 01 0A 00 04 00 3B 04 22 01 01 02 EE (hex)
Z-Wave Debug timeout waiting for reply from module (retrying)
Z-Wave Debug SENT requestBatteryLevel2: 01 09 00 13 3B 02 80 02 25 F7 8C
Z-Wave Debug RCVD requestBatteryLevel2: 01 07 00 13 F7 00 00 02 1E (node ACK)
Z-Wave Debug RCVD requestBatteryLevel: 01 09 00 04 00 3B 03 80 03 64 2D
Z-Wave Debug . . requestBatteryLevel: node 059, level 100
Z-Wave Syncing - retrieved battery level of 100%
Z-Wave Syncing - complete
Z-Wave Debug SENT requestHvacMode: 01 0D 00 13 3B 06 60 0D 01 01 40 02 25 F8 2E
Z-Wave Debug RCVD requestHvacMode: 01 07 00 13 F8 00 00 02 11 (node ACK)
Z-Wave Debug waiting up to 3.0 seconds for module reply after sending request
Z-Wave Debug terminatingSyncUI
Z-Wave sent "059 - Thermostat" mode status request
Z-Wave Debug RCVD multiEndPointPacket: 01 0D 00 04 00 3B 07 60 0D 01 01 40 03 01 E5
Z-Wave Debug . . multiEndPointPacket: node 059, endPoint 1
Z-Wave Debug RCVD setHvacMode: 01 09 00 04 00 3B 03 40 03 01 FF
Z-Wave Debug . . setHvacMode: node 059, endpoint 1, value 1
Z-Wave received "059 - Thermostat" mode is heat
Z-Wave Debug SENT requestSetpointVal: 01 0E 00 13 3B 07 60 0D 01 01 43 02 01 25 F9 2F
Z-Wave Debug RCVD requestSetpointVal: 01 07 00 13 F9 00 00 03 11 (node ACK)
Z-Wave sent "059 - Thermostat" heat setpoint status request
Z-Wave Debug RCVD multiEndPointPacket: 01 10 00 04 00 3B 0A 60 0D 01 01 43 03 01 22 00 C8 1C
Z-Wave Debug RCVD requestSetpointVal: 01 0C 00 04 00 3B 06 43 03 01 22 00 C8 FF
Z-Wave Debug . . requestSetpointVal: node 059, endpoint 1, type 1, raw value 2200...
Z-Wave Debug . . requestSetpointVal: 20.0 °C (float: 20.000000)
Z-Wave received "059 - Thermostat" heat setpoint is 20.0 °C
Z-Wave Debug SENT requestVarSensorStatus: 01 0E 00 13 3B 07 60 0D 01 02 31 04 01 25 FA 5B
Z-Wave Debug RCVD requestVarSensorStatus: 01 07 00 13 FA 00 00 03 12 (node ACK)
Z-Wave sent "059 - External Sensor" status request
Z-Wave Debug RCVD multiEndPointPacket: 01 10 00 04 00 3B 0A 60 0D 02 01 31 05 01 22 00 E1 42
Z-Wave Debug . . multiEndPointPacket: node 059, endPoint 2
Z-Wave Debug RCVD requestVarSensorStatus: 01 0C 00 04 00 3B 06 31 05 01 22 00 E1 FF
Z-Wave Debug . . requestVarSensorStatus: node 059, endpoint 2, type 1, raw value 2200...
Z-Wave Debug . . requestVarSensorStatus: 22.5 °C (float: 22.500000)
Z-Wave received "059 - External Sensor" sensor update to 22.5 °C
Z-Wave Debug SENT requestHvacMode: 01 0D 00 13 3B 06 60 0D 01 01 40 02 25 FB 2D
Z-Wave Debug RCVD requestHvacMode: 01 07 00 13 FB 00 00 03 13 (node ACK)
Z-Wave Debug SENT requestSetpointVal: 01 0E 00 13 3B 07 60 0D 01 01 43 02 01 25 FC 2A
Z-Wave Debug RCVD requestSetpointVal: 01 07 00 13 FC 00 00 03 14 (node ACK)
