Forum rules
- Posted on
Sat Mar 19, 2022 11:44 am
mediabox
offline
What other outdoor outlet is avail except GE 45604 Z-Wave Wireless Module? I've found GE 14298 and Minoston MP22Z, however not seeing them supported. GE 45604 Z-Wave Wireless Module is getting harder to find. GE 14298 looks like the successor. Need something soon before GE 45604 goes extinct.
I can purchase the GE 14298 and send folks the debug info?
Thanks.
- Posted on
Sat Mar 19, 2022 12:05 pm
jay (support)
offline
- Site Admin
It's very likely to just work if it's a standard on/off device. Indigo will handle devices of that class type without any additional definitions.
- Posted on
Tue Mar 22, 2022 8:25 am
mediabox
offline
I did purchase the GE 14298 and basic on/off is good in v7.4.0. Thanks.
- Posted on
Tue Mar 22, 2022 10:23 am
jay (support)
offline
- Site Admin
Great! If you would, open the device config dialog and click on the submit device info button (if it shows up) - this will allow us to add it to the compatible devices database on our website.
- Posted on
Tue Mar 22, 2022 6:54 pm
mediabox
offline
I clicked [Submit to Indigo Domotics] and couldn't tell if it did anything. So then I clicked [Write Device Details To Event Log] and here it is as well:
Z-Wave Indigo Device "Outside Patio Wall Lights (west)" Z-Wave Properties:
Indigo Z-Wave Version: 7.4.0
Node ID: 115
Model: Relay Power Switch
Model ID: 4F503034
Manufacturer: General Electric
Manufacturer ID: 0063
Protocol Version: 6.04
Application Version: 5.52
Model Definition Version: 0
Library Type: 3
Class Hierarchy: 04 : 10 : 01
Command Class Base: 25
Command Versions: 20v1 85v1 22v1 25v1 86v1 27v1 2Cv1 2Bv1 6Cv1 70v1 72v1 73v1 55v1 59v1 5Av1 5Bv1 7Av1 5Ev1 9Fv1
Features: routing, beaming
Neighbors: - none -
Associations: 1:[1] 2:[] 3:[]
Config Values: - none -
