Popp smoke detector
Forum rules
Wed Feb 16, 2022 5:40 am
haakon offline
Popp smoke detector
Hi, again! Two Popp smoke detectors are listed as supported by Indigo (004001 and 009402). They both seem to be out of production though.
Will Popp's new smoke detector (701486) work with Indigo? Or will specific support for the new model, and hence an Indigo update, be needed?
Here is a link to the current Popp smoke detector with siren:
https://www.popp.eu/products/smoke-sensor-siren/
Thu Feb 24, 2022 4:03 pm
Re: Popp smoke detector
Similar answer for this one as for your HeatIt post. Unfortunately, we won't know until someone tries it. It might match and use one of the existing Popp definition Indigo has. If it doesn't, then we can help you figure out the correct Match Raw Packet type trigger to define.
