Fibaro Roller Shutter 3 not accepting changes
Forum rules
Thu Feb 03, 2022 6:30 am
Frakke offline
I installed 2 new roller shutters from Fibaro.
But, after calibrating, it doesn't seems that paramater 150 is putting itself to 1. It stays at 2.
Also parameter 156 and 157 aren't set..
But most importantly for me, if I change parameter 152 - Venetian blind - time of full turn of the slats - it's saving the setting, but doesn't seems to have any effect.
I also did a test with a Fibaro Home Controller 3, and when doing this here, everything works as it should..
https://manuals.fibaro.com/content/manu ... T-v1.2.pdf
Any help with this please?
Regards
Thu Feb 03, 2022 2:38 pm
Re: Fibaro Roller Shutter 3 not accepting changes
Try the following: Re-sync it in Indigo, change the parameters how you want them (and verify it is NOT working correctly), then re-sync it again. Copy/paste the Event Log window contents of all of that into a reply so we can try to see what is occurring.
Thu Feb 03, 2022 3:38 pm
Frakke offline
I just did it, it also did 2 times a new calibration after hitting sync..
   Z-Wave                          Syncing - started for "Lamel Bureau Rechts - Power"
   Z-Wave                          Syncing - retrieved module neighbors list: 40, 43, 44, 46, 48, 54, 55, 86, 100, 114, 115, 119, 121, 127, 128, 130
   Z-Wave                          Syncing - assigning return route to "131 - Lamel Bureau Rechts - Power"
   Z-Wave                          Syncing - retrieved manufacture and model names: Fibaro System - 010F, Shutter Controller (FGR223) - 03031000
   Z-Wave                          Syncing - retrieved protocol version 6.02, app version 5.01
   Z-Wave                          Syncing - retrieved class hierarchy: Routing Slave : Mulitlevel Switch : Motor Control Class B (04 : 11 : 06, base 26)
   Z-Wave                          Syncing - retrieved command classes: 20v1 85v1 86v1 8Ev1 55v1 56v1 98v1 59v1 5Av1 5Bv1 5Ev1 9Fv1 60v4 22v1 25v1 26v4 6Cv1 32v3 70v1 71v1 72v1 73v1 75v1 7Av1
   Z-Wave                          Syncing - retrieved encrypt commands: - none -
   Z-Wave                          Syncing - retrieved capabilities: routing, beaming, security
   Z-Wave                          Syncing - retrieved multi-endpoint types: 1:(11 : 06), 2:(11 : 06)
   Z-Wave                          Syncing - retrieved multi-endpoint classes: 1:[5E 26 85 8E 59 98 9F 6C 32 71 22], 2:[5E 26 85 8E 59 98 9F 6C 22]
   Z-Wave                          Syncing - retrieved group 1 associations: []
   Z-Wave                          Syncing - retrieved group 2 associations: []
   Z-Wave                          Syncing - retrieved group 3 associations: []
   Z-Wave                          Syncing - added group 1 multi association to interface
   Z-Wave                          Syncing - retrieved parameter 151 "Operating mode" is 2 "Venetian with Position"
   Z-Wave                          Syncing - retrieved parameter 150 "Force calibration" is 1 "Calibrated"
   Z-Wave                          Syncing - device "131 - Lamel Bureau Rechts - Power" parameter 150 "Force calibration" changed to 2 "Force Calibration Now" (was 1 "Calibrated")
   Z-Wave                          Syncing - retrieved parameter 156 "Up movement duration" is 6000 * 10 milliseconds
   Z-Wave                          Syncing - retrieved parameter 157 "Down movement duration" is 2301 * 10 milliseconds
   Z-Wave                          Syncing - device "131 - Lamel Bureau Rechts - Power" parameter 157 "Down movement duration" changed to 6000 * 10 milliseconds (was 2301 * 10 milliseconds)
   Z-Wave                          Syncing - retrieved parameter 152 "Slats duration and gate close timer" is 150 * 10 milliseconds
   Z-Wave                          Syncing - device "131 - Lamel Bureau Rechts - Power" parameter 152 "Slats duration and gate close timer" changed to 100 * 10 milliseconds (was 150 * 10 milliseconds)
   Z-Wave                          Syncing - retrieved parameter 153 "Slats position return to previous" is 1 "When Indigo Controlled or Switch Operated"
   Z-Wave                          Syncing - retrieved parameter 154 "Motor stop delay after end switch" is 10 * 100 milliseconds
   Z-Wave                          Syncing - retrieved parameter 155 "Motor operation detection" is 10 watts
   Z-Wave                          Syncing - retrieved parameter 20 "Switch type" is 0 "Momentary"
   Z-Wave                          Syncing - retrieved parameter 40 "Switch 1 scenes" is 0 "Disabled"
   Z-Wave                          Syncing - retrieved parameter 41 "Switch 2 scenes" is 0 "Disabled"
   Z-Wave                          Syncing - retrieved parameter 24 "Reverse S1 and S2 input operation" is false
   Z-Wave                          Syncing - retrieved parameter 25 "Reverse Q1 and Q2 output operation" is false
   Z-Wave                          Syncing - retrieved parameter 61 "Power report threshold" is 15 %
   Z-Wave                          Syncing - retrieved parameter 62 "Periodic power reports" is 3600 seconds
   Z-Wave                          Syncing - retrieved parameter 60 "Include internal usage in power reports" is false
   Z-Wave                          Syncing - retrieved parameter 65 "Energy report threshold" is 10 * 0.01 kWh
   Z-Wave                          Syncing - retrieved parameter 66 "Periodic energy reports" is 3600 seconds
   Z-Wave                          sent "Lamel Bureau Rechts - Up Down" status request
   Z-Wave                          sent "Lamel Bureau Rechts - Up Down" power status request
   Z-Wave                          sent "Lamel Bureau Rechts - Up Down" energy status request
   Z-Wave                          received "Lamel Bureau Rechts - Up Down" status update brightness 100
   Z-Wave                          sent "Lamel Bureau Rechts - Tilt" status request
   Z-Wave                          received "Lamel Bureau Rechts - Tilt" status update brightness 100
   Hue Lights                      received "Hue outdoor temperature" sensor update to 7.2 ºC
   Z-Wave                          received "Toilet - Tilt/Tamper" status update is off
   Z-Wave                          received "Toilet - Motion Sensor" status update is off
   Z-Wave                          received "Toilet - Motion Sensor" status update is on
   Trigger                         Toilet Timestamp
   Trigger                         Bureau Garage Timestamp
3 Feb 2022 at 22:33:08
   Z-Wave                          received "Woonkamer Achteraan - Luminance" sensor update to 0 lux
3 Feb 2022 at 22:33:40
   Z-Wave                          sent "Lamel Bureau Rechts - Tilt" set brightness to 0
   Z-Wave                          received "Lamel Bureau Rechts - Up Down" status update brightness 93
   Z-Wave                          sent "Lamel Bureau Rechts - Up Down" set brightness to 85
   Z-Wave                          sent "Lamel Bureau Rechts - Tilt" set brightness to 100
   Z-Wave                          received "Lamel Bureau Rechts - Up Down" status update brightness 92
   Z-Wave                          received "Lamel Bureau Rechts - Up Down" status update brightness 85
   Z-Wave                          device "131 - Lamel Bureau Rechts - Power" parameter 152 "Slats duration and gate close timer" changed to 50 * 10 milliseconds
   Z-Wave                          Syncing - retrieved parameter 156 "Up movement duration" is 2164 * 10 milliseconds
   Z-Wave                          Syncing - device "131 - Lamel Bureau Rechts - Power" parameter 156 "Up movement duration" changed to 6000 * 10 milliseconds (was 2164 * 10 milliseconds)
   Z-Wave                          Syncing - retrieved parameter 157 "Down movement duration" is 2287 * 10 milliseconds
   Z-Wave                          Syncing - device "131 - Lamel Bureau Rechts - Power" parameter 157 "Down movement duration" changed to 6000 * 10 milliseconds (was 2287 * 10 milliseconds)
   Z-Wave                          Syncing - device "131 - Lamel Bureau Rechts - Power" parameter 152 "Slats duration and gate close timer" changed to 50 * 10 milliseconds (was 150 * 10 milliseconds)
Fri Feb 04, 2022 11:26 am
I might have found the issue – Indigo's definition has that parameter as having a size of 2 bytes but the PDF specifies 4 bytes. I'm going to email you offline so you can try a fix.
Tue May 10, 2022 3:27 pm
Indigo 2022.1.0 is now available and should fix the problem of Indigo not being able to change the module's setting.
