Heatit Z-Water
Forum rules
Wed May 26, 2021 2:00 pm
IndigoSam offline
Heatit Z-Water
Does anyone know if the Heatit Z-Water unit is controllable from Indigo?
e.g https://www.vesternet.com/collections/z-wave-thermostats-trvs-heating-controls/products/z-wave-heatit-z-water
Sam.
Wed May 26, 2021 2:04 pm
Re: Heatit Z-Water
Wed May 26, 2021 2:15 pm
IndigoSam offline
Re: Heatit Z-Water
That looks like the thermostat, rather than the multi-relay device? Unless I'm missing something?
Although the last post doesn't look good from a general manufacturer point of view!
Sam.
Wed May 26, 2021 7:39 pm
Re: Heatit Z-Water
No one has reported trying that module yet, so we don't have a device definition for it yet. Indigo might be able to control all of the relays out-of-the-box without a definition though. We'll need someone to try it out and report the device sync Event Log results to us if it needs a device definition.
Thu May 27, 2021 2:19 pm
IndigoSam offline
Re: Heatit Z-Water
Thanks Matt. I'm okay with spending the money for something that doesn't work straight off, as it will probably work at some point. I'm more concerned with the user report of the thermostat from the same company.
Sam.
Mon Jun 28, 2021 10:40 am
Bildhauer offline
Re: Heatit Z-Water
Hello,
I’ve installed the HeatIt system to manage my irrigation system. Now I want to have a virtual device or something similar which can do the following:
    start irrigation circle no. 1
    let it run for x minutes
    stop irrigation circle no. 1
    start irrigation circle no. 2
    stop irrigation circle no. 2
    start irrigation circle no. 3
    stop irrigation circle no. 3
    etc. …
The time each circle must run must be defined by a variable. Do you have an idea to start/ stop such an action?
Best regards
Bildhauer
Fri Oct 22, 2021 12:48 pm
Bildhauer offline
Re: Heatit Z-Water
After all I managed to use it for my (lawn) irrigation system.
Additional question: I would like to use it to control underfloor heating. Is it possible to control valves in such a way that you can say open/close it at 10%, 20%, 30% etc. and not just on/off?
Here is a link to the manual : https://manuals.heatit.com/PDF/Heatit%2 ... -A_ENG.pdf
Best regards
Bildhauer
Mon Oct 25, 2021 4:06 pm
Re: Heatit Z-Water
From the PDF it looks like the outputs are all relays, so I think it just does on/off.
Unrelated to that, can you re-sync the device in Indigo then copy/paste the Event Log result into a reply for me? I'd like to see exactly how it reports itself to Indigo, which will help us (eventually) have Indigo's sprinkler actions control it.
