Forum rules
- Posted on
Thu Oct 18, 2018 3:54 pm
jay (support)
offline
- Site Admin
Have you submitted the device info using the Submit Device Information button in the config dialog? If it shows up, please fill out the form that it takes you to. If the Submit Device Information button isn't there, then click the Write Device Details to Event Log button and copy/paste the results from the event log into a reply.
In the meantime, you can of course adjust that config parameter using the Interfaces->Z-Wave->Modify Config Parameter... menu item.
- Posted on
Fri Oct 19, 2018 9:38 am
jay (support)
offline
- Site Admin
Go ahead and do the Write Device Information to Log and copy/paste it here. It might be in our DB already, but without knowing the exact Z-Wave manufacturer/model information (that's not the model number in the subject line) it's hard to tell (GE has a TON of different model numbers).
- Posted on
Sat Oct 20, 2018 1:44 pm
jay (support)
offline
- Site Admin
Found it. The person that submitted it failed to include a link to it's docs which is required to get params added. I've made a note of the link you provided.
- Posted on
Sun May 12, 2019 4:17 pm
matt (support)
offline
- Site Admin
Indigo 7.3 (and 7.3.1)
are now available and should support the GE Smart Lighting and Appliance Control Receptacle Outlet (14288).
