HomeSeer HS-FLS100+ Z-Wave Plus Floodlight Sensor
Forum rules
Tue Oct 09, 2018 10:31 am
boisy offline
I purchased one of these off of Amazon and installed it on an older floodlight today:
https://products.z-wavealliance.org/products/2947
Here's the installation instructions for it: https://homeseer.com/wp-content/uploads ... nual2b.pdf
I'm an Insteon guy, so Z-wave is a bit new for me. I do have the Aeotec Gen5 stick hooked to my Mac, and have been able to get this new HomeSeer device into inclusion mode. I have a single device in Indigo for this: Notification Sensor.
My guess is that this device is not supported, because although I can see the state is off, it does not come on when the motion sensor activates the lights (I do see the Z-Wave status bar at the bottom of the Indigo window activate though, so traffic is passing back and forth).
What information can I provide to get this supported?
Tue Oct 09, 2018 2:59 pm
Re: HomeSeer HS-FLS100+ Z-Wave Plus Floodlight Sensor
Open the device config dialog and click the Submit Device Information button (assuming it's there, I think it should be). Fill out the resulting form as completely as possible and that will get it onto our list.
You might be able to catch the motion sensor on/off commands using the raw Z-Wave commands. You'd need to trigger the motion sensor (and the associated off/timeout) and then dump the recent Z-Wave commands to find the specific command.
FYI, because of the sheer volume of Z-Wave devices (thousands vs 10's of Insteon), it's always a good idea to check the Compatible Devices list before buying something. If a device you want isn't there then you can ask on the forums.
Tue Oct 09, 2018 3:59 pm
boisy offline
Thanks Jay. I filled out the device report.
Coming from Insteon, I just expect things to work, but now I'm seeing that Z-wave has a hearty ecosystem of devices, and not all are supported by Indigo.
I see that there's a way to dump device details. I'll add that here:
Oct 9, 2018 at 4:58:32 PM
   Z-Wave                          Indigo Device "003 - Notification Sensor" Z-Wave Properties:
Indigo Z-Wave Version: 2.0.119
Node ID: 3
Model: Notification Sensor
Model ID: 0201000B
Manufacturer: HomeSeer
Manufacturer ID: 000C
Protocol Version: 5.03
Application Version: 1.03
Model Definition Version: 0
Library Type: 3
Class Name: Notification Sensor
Class Hierarchy: 04 : 07 : 01
Command Class Base: 00
Command Versions: 85v1 86v1 55v1 59v1 5Av1 5Ev1 9Fv1 20v1 70v1 25v1 71v1 6Cv1 30v1 31v5 72v1 73v1 7Av1
Features: routing, beaming
Neighbors: - none -
Associations: 1:[1] 2:[]
Config Values: - none -
Tue Oct 09, 2018 5:00 pm
Many times a device will just work (on/off/dim, thermostats, locks, simple sensors, etc). When devices serve multiple purposes (have multiple personalities) or are not main-stream devices then they often need a custom definition.
Sun May 12, 2019 4:19 pm
Indigo 7.3 (and 7.3.1) are now available and should support the HomeSeer Floodlight Sensor (HS-FLS100+).
Sun Aug 22, 2021 8:29 am
drewcaplan offline
Hi, can anybody verify whether this is actually supported? It still is not in the compatibility database. Thx.
Sun Aug 22, 2021 10:01 am
aldera offline
I’ve had it for a while and it works just fine.
Sun Aug 22, 2021 4:47 pm
It is listed on the compatible devices web page, but probably not under the category you checked. It is currently under motion sensors and not lighting. Currently there is an internal imitation that each device can only be listed under a single category, which we hope to address at some point.
Mon Aug 23, 2021 9:51 am
We also need a search now that the database is getting big. We'll look at adding that as well.
