Fibaro Universal Sensor Support
Forum rules
Sat Dec 02, 2017 12:53 pm
forestfield offline
Hi ,
I've just bought a Fibaro FGBS-001 Universal Sensor (https://www.amazon.co.uk/gp/product/B00 ... UTF8&psc=1), and it's not being fully recognised. Indigo sees it as an FGBS321, but doesn't add support for the 2 output relays. Also it should support up to 4 ds18b20 temperature sensors; I have 1 connected...
From the event log at sync...
2017-12-02 18:03:42.093 Z-Wave  Syncing - started for "083 - Binary Sensor (routing)"
2017-12-02 18:03:42.135 Z-Wave  Syncing - retrieved module neighbors list: - none -
2017-12-02 18:03:42.136 Z-Wave  Syncing - assigning return route to "083 - Binary Sensor (routing)"
2017-12-02 18:03:42.505 Z-Wave  Syncing - assigned return route
2017-12-02 18:03:43.117 Z-Wave  Syncing - retrieved manufacture and model names: Fibaro System - 010F, Universal Sensor (FGBS321) - 05011002
2017-12-02 18:03:43.405 Z-Wave  Syncing - retrieved protocol version 3.52, app version 2.01
2017-12-02 18:03:43.690 Z-Wave  Syncing - retrieved class hierarchy: Routing Slave : Binary Sensor : Binary Sensor (routing) (04 : 20 : 01, base 30)
2017-12-02 18:03:43.691 Z-Wave  Syncing - retrieved command classes: 20v1 60v2 85v1 86v1 70v1 8Ev1 30v1 72v1 7Av1
2017-12-02 18:03:43.691 Z-Wave  Syncing - retrieved encrypt commands: - none -
2017-12-02 18:03:43.692 Z-Wave  Syncing - retrieved capabilities: routing, beaming
2017-12-02 18:03:44.279 Z-Wave  Syncing - retrieved multi-endpoint types: 1:(20 : 01), 2:(20 : 01)
2017-12-02 18:03:44.280 Z-Wave  Syncing - retrieved multi-endpoint classes: 1:[30 9C], 2:[30 9C]
2017-12-02 18:03:44.854 Z-Wave  Syncing - retrieved group 1 associations: []
2017-12-02 18:03:45.141 Z-Wave  Syncing - retrieved group 2 associations: []
2017-12-02 18:03:45.427 Z-Wave  Syncing - retrieved group 3 associations: []
2017-12-02 18:03:45.715 Z-Wave  Syncing - added group 1 association to interface
2017-12-02 18:03:46.004 Z-Wave  Syncing - added group 2 association to interface
2017-12-02 18:03:46.291 Z-Wave  Syncing - added group 3 association to interface
2017-12-02 18:03:46.584 Z-Wave  Syncing - retrieved parameter 3 "Input 1 type" is 1 "Normally Closed"
2017-12-02 18:03:46.874 Z-Wave  Syncing - retrieved parameter 4 "Input 2 type" is 1 "Normally Closed"
2017-12-02 18:03:47.165 Z-Wave  Syncing - retrieved parameter 12 "Temperature sensitivity" is 8
2017-12-02 18:03:47.451 Z-Wave  Syncing - retrieved parameter 14 "Enable scene commands" is false
2017-12-02 18:03:47.987 Z-Wave  Syncing - created device "083 - Input 1"
2017-12-02 18:03:48.022 Z-Wave  Syncing - created device "083 - Input 2"
2017-12-02 18:03:48.038 Z-Wave  Syncing - complete
And dumping the device definition
 Z-Wave  Indigo Device "083 - Input 1" Z-Wave Properties:
Indigo Z-Wave Version: 2.0.111
Node ID: 83
Model: Universal Sensor (FGBS321)
Model ID: 05011002
Manufacturer: Fibaro System
Manufacturer ID: 010F
Protocol Version: 3.52
Application Version: 2.01
Model Definition Version: 8
Library Type: 3
Class Name: Binary Sensor (routing)
Class Hierarchy: 04 : 20 : 01
Command Class Base: 30
Command Versions: 20v1 60v2 85v1 86v1 70v1 8Ev1 30v1 72v1 7Av1
Multi-Endpoint Types: 1:(20 : 01), 2:(20 : 01)
Multi-Endpoint Classes: 1:[30 9C], 2:[30 9C]
Features: routing, beaming
Neighbors: - none -
Associations: 1:[1] 2:[1] 3:[1]
Config Values: 12:8 3:1 4:1 14:0
-- Paul --
Sat Dec 02, 2017 2:36 pm
Gusten offline
Re: Fibaro Universal Sensor Support
The relays only follows the inputs, they are not controllable.
Sun Dec 03, 2017 3:08 am
forestfield offline
Aha - basic misunderstanding! However the temperature monitoring was the bit I was really after...
Sun Dec 03, 2017 7:27 am
Did you add the temp sensor after pairing it with indigo? If so you’ll need to unpair then repair it. Same goes for if you ever add more or replace a module (I’ve got several of these hooked up and fully working)
Sun Dec 03, 2017 9:01 am
forestfield offline
Excellent - that did the job. I did resync, but hadn't thought about re-pairing.
Didn't help that one of pack of 5 ds18b20's I bought is bad - and that's the one I's connected. Luckily had a spare pi to test them all.
-- Paul --
Mon Dec 04, 2017 1:30 pm
Yeah testing the ds18b20 is a faf with the universal sensor having to pair and unpair. Still once they’re working they tend to keep working in my experience.. in the last 4 years I’ve only had one failure and I think I have about 30 sensors in various places.
