Black Cat (neo Electronics) Cat's Eye Sensor
Forum rules
Mon Sep 18, 2017 8:45 pm
mclass offline
Black Cat Controls (https://www.blackcatcontrolsystems.com.au/) is marketing their own branded PIR and luminosity sensor. This is manufactured by Neo Electronics (http://www.szneo.com/en/products/show.php?id=190
It's main attraction over other PIR's is its compact form factor - about the size of a table tennis ball - and it is claimed to be available in US, EU and JP models
I have been able to include the device, and synch it to Indigo with some difficulty - I think as the need to keep it awake during the process! However Indigo does not recognize the device, and I would like to request its support. The reported details are:
   Z-Wave                          Indigo Device "016 - Black Cat Sensor" Z-Wave Properties:
Indigo Z-Wave Version: 2.0.68
Node ID: 16
Model: Notification Sensor
Model ID: 00036083
Manufacturer: Unknown
Manufacturer ID: 0258
Protocol Version: 4.05
Application Version: 3.80
Model Definition Version: 0
Library Type: 6
Class Name: Notification Sensor
Class Hierarchy: 04 : 07 : 01
Command Class Base: 00
Command Versions: 20v1 80v1 84v2 85v1 86v1 30v1 70v1 71v1 72v1 73v1 59v1 31v7 5Av1 5Ev1
Features: routing, battery, beaming, waking
Neighbors: 1, 4, 5, 8
Associations: 1:[1] 2:[] 3:[] 4:[]
Config Values: - none -
With ZWave debug on, the device reports the following status:
Z-Wave Debug                    RCVD requestAlarmSensorStatus: 01 10 00 04 00 10 0A 71 05 00 00 00 FF 07 08 00 00 75
   Z-Wave Debug                    . .  requestAlarmSensorStatus: node 016, endpoint None, cmdClass 71, type 0, value 0, classSubKey 710000
   Z-Wave Debug                    . .  requestAlarmSensorStatus: typeExt 7, valueExt 8, classSubKeyExt 7100000708
   Z-Wave Debug                    RCVD requestBinarySensorStatus: 01 0A 00 04 00 10 04 30 03 FF 0C 25
   Z-Wave Debug                    . .  requestBinarySensorStatus: node 016, endpoint None, type 12, value 255
As reported in other posts, there is a whole range of Neo stuff that needs to be suported by Indigo if possible.
mclass
Tue Sep 19, 2017 5:52 am
johnpolasek offline
Re: Black Cat (neo Electronics) Cat's Eye Sensor
I have the Fibaro version, which looks like the same hardware;
https://www.amazon.com/Fibaro-FGMS-001-ZW5-Motion-Multisensor/dp/B01KOGDETI/ref=sr_1_1?s=electronics&ie=UTF8&qid=1505821885&sr=1-1&keywords=fibaro+motion+sensor
the one I got only seems to have about a 10 ft (3 m) detection range for a human sized object, which works out well for a hallway or over an entrance door, but not so good for a room.
Sat Sep 23, 2017 9:08 pm
I've added beta support for this motion sensor to this download. Unfortunately, it has different configuration parameters than the Fibaro, and the Neo version actually has different parameters than the Black Cat model. They all three are somewhat similar, but based on the documentation I could find there are differences. I didn't add UI for all the configuration parameters – just the main ones. Please let me know if the core functionality works (motion and lux reporting).
Thu Nov 09, 2017 7:23 pm
Indigo 7.1.1 is now available for download and includes support for the Black Cat Motion Sensor (ZWBCCE21S) and Neo CoolCam Motion Sensor (NAS-PD02Z).
