Secure SIR321 (Horstmann) Countdown timer.
Forum rules
Wed Nov 08, 2017 2:05 pm
xkrgeezer offline
Re: Secure SIR321 (Horstmann) Countdown timer.
Hi Peter,
thanks for your support.
I'm not finding ver .27 on this link. https://github.com/howartp84/ZwaveSenso ... master.zip
Thu Nov 09, 2017 4:19 pm
Sorry, I pushed the code for .27 but not the plist which tells Indigo which version it is.
Live now.
Peter
Fri Nov 10, 2017 1:54 am
xkrgeezer offline
Hi Peter, looks like you're getting there.
I can see the temp in the event log but not against the dummy device
10 Nov 2017, 07:51:37
Action Group new action group
Z-Wave Sensor Logger Debug Node: 10
Z-Wave Sensor Logger Requesting humidity for node 10
Z-Wave sent "Office Underfloor" raw command [31 04 05]
Z-Wave Sensor Logger Requesting temperature 1 for node 10
Z-Wave sent "Office Underfloor" raw command [31 04 01]
Z-Wave Sensor Logger Requesting temperature 2 for node 10
Z-Wave Sensor Logger Requesting temperature 3 for node 10
Z-Wave Sensor Logger Requesting temperature 4 for node 10
Z-Wave Sensor Logger Requesting temperature 5 for node 10
10 Nov 2017, 07:52:15
Z-Wave received "Office underfloor - Temp" sensor update to 16.4 °C
Error XML Parse Error: not well-formed (invalid token)
Error On character 443 of line number 1.
Z-Wave Sensor Logger Debug Bitmask: 0b100010, DP: 1, Scale: 0, ByteLength: 2
Z-Wave Sensor Logger Debug Temperature Reported (Node 10 Endpoint None): 16.4 celsius
Fri Nov 10, 2017 4:49 am
Looking at that, Indigo itself is seeing the temperature as well - do you therefore need my plugin for this?
(I’ll still fix that error, but interested if Indigo is displaying it anywhere?)
Fri Nov 10, 2017 6:34 am
xkrgeezer offline
You're right. Matt has been working on the issue as well. Yesterday I tested a private beta version and it's solved the issue but just needs some minor tweaking before being release in 7.1.1
I'm happy to continue to test your plugin in you want me to.
Fri Sep 28, 2018 1:09 pm
Indigo 7.2.0 is now available for download and has Z-Wave support for the Horstmann Secure Countdown Timer (SIR321).
