Secure SIR321 (Horstmann) Countdown timer.
Forum rules
Tue Jul 25, 2017 3:33 am
xkrgeezer offline
I've just purchased a Secure SIR321 Countdown Timer to use with my underfloor heating, thinking that is was supported by Indigo as Horstmann. But I've misread the product number :oops:
http://www.vesternet.com/z-wave-secure-wall-switch
Indigo sees it as a Horstmann relay switch. I can turn the switch on an off , but I cannot see the optional temperature probe readings.
I've tried changing the configuration, but it's not made any difference. And I'm not seeing any errors.
Not sure if a new define definition is required, Or a simple change on my side.
But any help would be very welcome.
Screen Shot 2017-07-25 at 10.10.22.png (123.04 KiB) Viewed 5345 times
Tue Jul 25, 2017 8:16 am
Re: Secure SIR321 (Horstmann) Countdown timer.
It will likely require a device definition. In the device config dialog, click the Submit Device Information button.
Tue Jul 25, 2017 11:24 am
xkrgeezer offline
Thank you. I think I already did this, but I've just done it again to be sure.
Wed Jul 26, 2017 5:59 am
xkrgeezer offline
Hi Jay, will it take long to get a new Device Definition?
I've thought up a great use for these switches. I intend replacing my Underfloor heating thermostats with the Secure SIR321 which will allow me to control the Underfloor Heating in each room more effectively. But more importantly I'll be able to activate the underfloor heating when there is spare solar power as indicated by Network Owl.
It seems like the perfect device for this - along with not being too expensive and it can be manually activated for 30, 60, 120 minutes.
Wed Jul 26, 2017 9:11 am
I'm not sure how long it will take, but it is definitely on our definitions ToDo list.
Fri Oct 27, 2017 7:20 am
xkrgeezer offline
Hi Matt,
Is this moving up to the top of your todo list?
Any idea when you might have new Device Definition done?
Fri Oct 27, 2017 3:30 pm
It is definitely on the list still, but I don't believe it has the coveted top spot. :wink: If the primary limitation is lack of support for the temperature sensor then we'll look into getting something in soon.
Sat Oct 28, 2017 2:57 am
xkrgeezer offline
Thanks. It's good to know it's still on your ToDo list. Yes it's the temperature support that I need to ensure the floor doesn't overheat. The device works fine other than that.
Sat Oct 28, 2017 3:31 am
Have a look at my Sensor Logger Plugin.
It probably reads temperature for you.
Tue Nov 07, 2017 8:43 am
xkrgeezer offline
Hi Howartp, thanks for your reply. I installed your ZWave Sensor logger Plugin. I created a dummy device. But I'm not seeing any temp reports. In the event log every minute I'm seeing this:
7 Nov 2017, 14:33:56
Z-Wave Sensor Logger Error Error in plugin execution ReceivedBroadcast:
File "plugin.py", line 346, in zwaveCommandReceived
IndexError: list index out of range
any ideas what could be wrong?
Tue Nov 07, 2017 1:11 pm
Sorry, try v1.0.25
I had a bug in there.
Peter
Tue Nov 07, 2017 1:22 pm
xkrgeezer offline
Hi Peter,
I'm seeing a different error now.
7 Nov 2017, 19:19:27
Z-Wave Sensor Logger Debug Bitmask: 22, DP: 1, Scale: 0, ByteLength: 2
File "plugin.py", line 359, in zwaveCommandReceived
TypeError: unsupported operand type(s) for +: 'float' and 'str'
Regards,
Nigel
Tue Nov 07, 2017 1:44 pm
Sorry, try v1.0.27
I don't have any temperature devices so can't test these bits as easily!
You might get errors about Unicode 'c and 'f readings now...?
Peter
Tue Nov 07, 2017 2:03 pm
xkrgeezer offline
Hi Peter,
Have you updated the link with ver 1.0.27?
I'm still getting v1.0.26
7 Nov 2017, 20:00:43
Reloading plugin "Z-Wave Sensor Logger 1.0.26"
Stopping plugin "Z-Wave Sensor Logger 1.0.26" (pid 29659)
Stopped plugin "Z-Wave Sensor Logger 1.0.26"
Starting plugin "Z-Wave Sensor Logger 1.0.26" (pid 29690)
Started plugin "Z-Wave Sensor Logger 1.0.26"
Z-Wave Sensor Logger Debug startup called
Z-Wave sent "Office Underfloor" on
Z-Wave Sensor Logger Debug Bitmask: 0b100010, DP: 1, Scale: 0, ByteLength: 2
File "plugin.py", line 360, in zwaveCommandReceived
NameError: global name 'dectemp' is not defined
Wed Nov 08, 2017 1:43 pm
Sorry, I meant .26 last night
.27 now live with fix for dectemp.
Peter
