GoControl WA00Z-1
Forum rules
Sat Feb 11, 2017 8:47 pm
JonathanKing offline
GoControl WA00Z-1
I purchased a GoControl WA00Z-1 so my daughter can control the light in her room, but cannot get the thing to work in Indigo. Indigo 6 hated it, and Indigo 7 at least recognizes it as a "Basic Wall Controller". When I push either button, I get [received "Switch" scene x] where x is 1 or 2, but I can't find any way to actually use that as a trigger. I imagine I could match a raw command, but don't really want to reverse engineer how the thing works.
Suggestions welcome!
-jonathan
Sat Feb 11, 2017 9:00 pm
Re: GoControl WA00Z-1
Forgot to mention that the light to control is actually an Indigo light, so I can't just use a Z-Wave association. I might end up moving around a few devices so her room is just Z-Wave, but I'd rather get the button controller properly working in Indigo.
Sun Feb 12, 2017 3:31 pm
Open the device in Indigo, press the Edit Device Settings button, then press the button to write the device information to the Event Log widow.
Next, choose the Interfaces->Z-Wave->Configure... menu item and turn on the debug logging checkbox.
Next, on the switch press the top button 4 times (wait a few seconds between each press), then press the bottom button 4 times.
Copy/paste the Event Log results of all that into a reply for me to look at. Once you are done you'll probably want to disable the debug logging.
Sun Feb 12, 2017 10:21 pm
Thanks matt, here's the log data
Feb 12, 2017, 11:19:17 PM
Z-Wave Indigo Device "Ella's Switch" Z-Wave Properties:
Indigo Z-Wave Version: 2.0.68
Node ID: 8
Model: Basic Wall Controller
Model ID: 53433132
Manufacturer: LinearLinc
Manufacturer ID: 014F
Protocol Version: 4.05
Application Version: 5.09
Model Definition Version: 0
Library Type: 3
Class Name: Basic Wall Controller
Class Hierarchy: 04 : 18 : 01
Command Class Base: 00
Command Versions: 20v1 80v1 84v2 85v1 86v1 70v1 72v1 73v1 59v1 5Av1 5Bv1 7Av1 5Ev1
Features: routing, battery, beaming, waking
Neighbors: 1, 3, 4, 6, 7
Associations: 1:[1] 2:[] 3:[]
Config Values: - none -
Feb 12, 2017, 11:19:32 PM
Z-Wave Debug stopping node healing thread
Z-Wave Debug stopping node status polling thread
Z-Wave Debug stopped zwave packet parser thread
Z-Wave connection reset requested
Z-Wave Debug starting serial connection loop
Z-Wave Debug starting zwave packet parser thread
Z-Wave Debug SENT getVersion: 01 03 00 15 E9
Z-Wave Debug RCVD getVersion: 01 10 01 15 5A 2D 57 61 76 65 20 32 2E 37 38 00 01 9B
Z-Wave Debug . . getVersion: Z-Wave 2.78 static controller
Z-Wave Debug SENT getHomeID: 01 03 00 20 DC
Z-Wave Debug RCVD getHomeID: 01 08 01 20 01 84 CE 00 01 9C
Z-Wave Debug . . getHomeID: 0184CE00, nodeID: 001
Z-Wave Debug SENT getInterfaceFeatures: 01 03 00 05 F9
Z-Wave Debug RCVD getInterfaceFeatures: 01 04 01 05 18 E7
Z-Wave Debug . . getInterfaceFeatures: 18
Z-Wave Debug SENT getInterfaceApiCapabilities: 01 03 00 07 FB
Z-Wave Debug RCVD getInterfaceApiCapabilities: 01 2B 01 07 03 07 00 86 00 02 00 01 FE 80 FE 88 0F 00 00 00 FB 97 7F 82 07 00 00 80 00 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 C2
Z-Wave Debug . . getInterfaceApiCapabilities: supportedFuncIDs: 02 03 04 05 06 07 08 10 12 13 14 15 16 17 18 1C 20 21 22 23 24 41 42 44 45 46 47 48 49 4A 4B 4D 50 51 52 53 54 55 56 57 5A 60 61 62 63 80 90
Z-Wave Debug . . getInterfaceApiCapabilities: serialApi 3.07, manufactureId 0086, productType 0002, productId 0001
Z-Wave connected to Z-Stick S2 interface on /dev/cu.SLAB_USBtoUART (firmware 3.07)
Z-Wave Debug SENT forceSUC: 01 05 00 54 01 01 AE
Z-Wave Debug RCVD forceSUC: 01 04 01 54 01 AF
Z-Wave Debug SENT getInitialNodeData: 01 03 00 02 FE
Z-Wave Debug RCVD getInitialNodeData: 01 25 01 02 05 08 1D FF 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03 01 34
Z-Wave Debug . . getInitialNodeData: is static update controller
Z-Wave Debug . . getInitialNodeData: [1, 2, 3, 4, 5, 6, 7, 8]
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 01 BB
Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 92 16 00 02 02 01 33
Z-Wave Debug . . getNodeProtocolInfo: node 001, class name: Static Computer Controller
Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Static Controller : Static Controller : Static Computer Controller (02 : 02 : 01)
Z-Wave Debug . . getNodeProtocolInfo: base class command: 00
Z-Wave Debug . . getNodeProtocolInfo: supported class commands: 20
Z-Wave Debug . . getNodeProtocolInfo: encrypt class commands:
Z-Wave Debug . . getNodeProtocolInfo: features: beaming
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 02 B8
Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 52 9C 00 04 20 01 5D
Z-Wave Debug . . getNodeProtocolInfo: node 002, class name: Binary Sensor (routing)
Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Routing Slave : Binary Sensor : Binary Sensor (routing) (04 : 20 : 01)
Z-Wave Debug . . getNodeProtocolInfo: base class command: 30
Z-Wave Debug . . getNodeProtocolInfo: supported class commands: 20 30
Z-Wave Debug . . getNodeProtocolInfo: features: routing, beaming
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 03 B9
Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 D3 9C 00 04 11 01 ED
Z-Wave Debug . . getNodeProtocolInfo: node 003, class name: Dimmable Power Switch
Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Routing Slave : Mulitlevel Switch : Dimmable Power Switch (04 : 11 : 01)
Z-Wave Debug . . getNodeProtocolInfo: base class command: 26
Z-Wave Debug . . getNodeProtocolInfo: supported class commands: 20 26 27
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 04 BE
Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 D3 9C 01 04 11 01 EC
Z-Wave Debug . . getNodeProtocolInfo: node 004, class name: Dimmable Power Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 05 BF
Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 53 9C 00 04 20 01 5C
Z-Wave Debug . . getNodeProtocolInfo: node 005, class name: Binary Sensor (routing)
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 06 BC
Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 D3 9C 00 04 11 04 E8
Z-Wave Debug . . getNodeProtocolInfo: node 006, class name: Dimmable Scene Switch
Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Routing Slave : Mulitlevel Switch : Dimmable Scene Switch (04 : 11 : 04)
Z-Wave Debug . . getNodeProtocolInfo: supported class commands: 20 26 27 2B 2C 72
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 07 BD
Z-Wave Debug . . getNodeProtocolInfo: node 007, class name: Dimmable Power Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 08 B2
Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 53 9C 01 04 18 01 65
Z-Wave Debug . . getNodeProtocolInfo: node 008, class name: Basic Wall Controller
Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Routing Slave : Wall Controller : Basic Wall Controller (04 : 18 : 01)
Z-Wave Debug starting node healing thread
Z-Wave Debug starting node status polling thread
Z-Wave Debug RCVD nodeInfoFrame: 01 18 00 49 84 08 12 04 18 01 5E 86 72 5B 85 59 73 70 80 84 5A 7A EF 5B 20 B3
Z-Wave Debug RCVD sceneActivateCmd2: 01 0B 00 04 00 08 05 5B 03 A9 00 01 0D
Z-Wave Debug . . sceneActivateCmd2: node 008, type: 0, scene: 1
Z-Wave received "Ella's Switch" scene 1
Z-Wave Debug RCVD requestBatteryLevel: 01 09 00 04 00 08 03 80 03 5E 24
Z-Wave Debug . . requestBatteryLevel: node 008, level 94
Z-Wave received "008 - Ella's Switch" status update battery level 94%
Z-Wave Debug RCVD nodeAwake: 01 08 00 04 00 08 02 84 07 7A
Z-Wave Debug . . nodeAwake: node 008
Z-Wave Debug SENT requestBatteryLevel: 01 09 00 13 08 02 80 02 25 92 DA
Z-Wave Debug . . nodeAwake: inhibit count++ to 1
Z-Wave Debug . . nodeAwake: started inhibit sleep timer
Z-Wave Debug RCVD requestBatteryLevel: 01 09 00 04 00 08 03 80 03 5B 21
Z-Wave Debug . . requestBatteryLevel: node 008, level 91
Z-Wave received "008 - Ella's Switch" status update battery level 91%
Z-Wave Debug . . nodeAwake: inhibit count-- to 0
Z-Wave Debug . . nodeAwake: stopping inhibit sleep timer
Z-Wave Debug SENT goToSleep: 01 09 00 13 08 02 84 08 24 93 D4
Z-Wave Debug RCVD packet: 01 05 00 13 93 00 7A (hex)
Z-Wave Debug RCVD sceneActivateCmd2: 01 0B 00 04 00 08 05 5B 03 AA 00 01 0E
Z-Wave Debug . . . . . . . : skipping battery check (next check in 717 mins)
Z-Wave Debug SENT goToSleep: 01 09 00 13 08 02 84 08 24 94 D3
Z-Wave Debug RCVD packet: 01 05 00 13 94 00 7D (hex)
Z-Wave Debug RCVD sceneActivateCmd2: 01 0B 00 04 00 08 05 5B 03 AB 00 01 0F
Z-Wave Debug SENT goToSleep: 01 09 00 13 08 02 84 08 24 95 D2
Z-Wave Debug RCVD packet: 01 05 00 13 95 00 7C (hex)
Z-Wave Debug RCVD sceneActivateCmd2: 01 0B 00 04 00 08 05 5B 03 AC 00 01 08
Z-Wave Debug RCVD requestBatteryLevel: 01 09 00 04 00 08 03 80 03 58 22
Z-Wave Debug . . requestBatteryLevel: node 008, level 88
Z-Wave received "008 - Ella's Switch" status update battery level 88%
Z-Wave Debug SENT goToSleep: 01 09 00 13 08 02 84 08 24 96 D1
Z-Wave Debug RCVD packet: 01 05 00 13 96 00 7F (hex)
Z-Wave Debug RCVD sceneActivateCmd2: 01 0B 00 04 00 08 05 5B 03 AD 00 02 0A
Z-Wave Debug . . sceneActivateCmd2: node 008, type: 0, scene: 2
Z-Wave received "Ella's Switch" scene 2
Z-Wave Debug SENT goToSleep: 01 09 00 13 08 02 84 08 24 97 D0
Z-Wave Debug RCVD packet: 01 05 00 13 97 00 7E (hex)
Z-Wave Debug RCVD sceneActivateCmd2: 01 0B 00 04 00 08 05 5B 03 AE 00 02 09
Z-Wave Debug SENT goToSleep: 01 09 00 13 08 02 84 08 24 98 DF
Z-Wave Debug RCVD packet: 01 05 00 13 98 00 71 (hex)
Z-Wave Debug RCVD sceneActivateCmd2: 01 0B 00 04 00 08 05 5B 03 AF 00 02 08
Z-Wave Debug SENT goToSleep: 01 09 00 13 08 02 84 08 24 99 DE
Z-Wave Debug RCVD packet: 01 05 00 13 99 00 70 (hex)
Z-Wave Debug RCVD sceneActivateCmd2: 01 0B 00 04 00 08 05 5B 03 B0 00 02 17
Z-Wave Debug SENT goToSleep: 01 09 00 13 08 02 84 08 24 9A DD
Z-Wave Debug RCVD packet: 01 05 00 13 9A 00 73 (hex)
Tue Feb 14, 2017 8:44 am
Hi Matt, was this information useful?
Tue Feb 14, 2017 10:30 pm
Yes, that is helpful. I've added it to the request list so we can create a device definition for it so that the Trigger UI will show correctly.
In the mean time I believe you can use howartp's ZWave Scene Controller plugin right now to create triggers for it.
Sat Feb 18, 2017 7:40 pm
Thanks Matt, that plugin worked perfectly.
Sun Dec 12, 2021 8:38 am
Matt,
The plugin has been working somewhat inconsistently for a while now, it often misses a button 2 press until I've pressed button 1 first. Which just serves to annoy anyone who tries to simply turn a light off! (I've change the batteries, doesn't make a difference) I was going to ditch the plugin and use the native device when I realized that Indigo see a press, and a release, but not a double-press (in the logs). Also, when I try to make a Trigger for the device, the only option is for battery state, not button or scene.
What am I missing?
-jonathan
Users browsing this forum: No registered users and 19 guests
