Fibaro KeyFob
Posted: Tue Feb 07, 2017 1:37 pm
Any chance of this being added to Indigo? Looks pretty cool:
http://www.fibaro.com/en/products/keyfob/
Software Support and Home Automation Forum
https://forums.indigodomo.com/
matt (support) wrote:Can you copy/paste the Event Log results of the define/sync operation in Indigo with it?
controller included module: 034 - Basic Wall Controller
stopped controller inclusion mode
Syncing - started for "034 - Basic Wall Controller"
Syncing - retrieved module neighbors list: 3, 4, 7, 25
Syncing - assigning return route to "034 - Basic Wall Controller"
Syncing - assigned return route
Syncing - retrieved manufacture and model names: Fibaro System - 010F, Basic Wall Controller - 10011000
Syncing - retrieved protocol version 4.38, app version 3.02
Syncing - retrieved class hierarchy: Routing Slave : Wall Controller : Basic Wall Controller (04 : 18 : 01, base 00)
Syncing - retrieved command classes: 80v1 84v2 85v1 86v1 8Ev1 56v1 98v1 59v1 5Av1 5Bv1 5Ev1 20v1 22v1 70v1 72v1 73v1 75v1 7Av1
Syncing - retrieved encrypt commands: - none -
Syncing - retrieved capabilities: routing, battery, beaming, security, waking
Syncing - retrieved wake interval of 0 minutes
Syncing - device "034 - Basic Wall Controller" wake interval changed to 60 minutes
Syncing - retrieved group 1 associations: []
Syncing - retrieved group 2 associations: []
Syncing - retrieved group 3 associations: []
Syncing - retrieved group 4 associations: []
Syncing - retrieved group 5 associations: []
Syncing - retrieved group 6 associations: []
Syncing - retrieved group 7 associations: []
Syncing - retrieved group 8 associations: []
Syncing - retrieved group 9 associations: []
Syncing - retrieved group 10 associations: []
Syncing - retrieved group 11 associations: []
Syncing - retrieved group 12 associations: []
Syncing - retrieved group 13 associations: []
Syncing - retrieved battery level of 46%
received "KeyFob" scene 1 // Button 1 short press
received "KeyFob" scene 2 // Button 2 short press
received "KeyFob" scene 3 // Button 3 short press
received "KeyFob" scene 4 // Button 4 short press
received "KeyFob" scene 5 // Button 5 short press
received "KeyFob" scene 6 // Button 6 short press
received "KeyFob" scene 513 // Button 1 long press
received "KeyFob" scene 257
received "KeyFob" scene 514 // Button 2 long press
received "KeyFob" scene 258
received "KeyFob" scene 515 // Button 3 long press
received "KeyFob" scene 259
received "KeyFob" scene 516 // Button 4 long press
received "KeyFob" scene 260
received "KeyFob" scene 517 // Button 5 long press
received "KeyFob" scene 261
received "KeyFob" scene 518 // Button 6 long press
received "KeyFob" scene 262
howartp wrote:As autolog says, my plugin should work with this out of the box until Matt adds it.
Zwave Scene Controller Debug -----
Zwave Scene Controller Debug Central Scene Command received:
Zwave Scene Controller Debug Raw command: 01 0B 00 04 00 24 05 5B 03 08 80 04 05
Zwave Scene Controller Debug Node: 36
Zwave Scene Controller Debug Button: 4
Zwave Scene Controller Error Error in plugin execution ReceivedBroadcast:
File "plugin.py", line 89, in zwaveCommandReceived
IndexError: list index out of range
