KeyFob is working now
Thank you Matt, it was really fast!
Kind regards,
08.05.2017 20:20:23
Z-Wave controller included module: 126 - Basic Wall Controller
Z-Wave querying module for encryption support
Z-Wave starting encryption key exchange with module
Z-Wave completed encryption key exchange with module
Z-Wave stopped controller inclusion mode
08.05.2017 20:21:15
Z-Wave Syncing - started for "126 - Basic Wall Controller"
Z-Wave Syncing - retrieved module neighbors list: 1, 3, 4, 9, 10, 12, 27, 28, 56, 57, 58, 59, 60, 61, 62, 74, 76, 78, 80, 86, 100, 122, 124
Z-Wave Syncing - assigning return route to "126 - Basic Wall Controller"
08.05.2017 20:21:34
Z-Wave Error Syncing - failed to assign return route
Z-Wave Error Timeout waiting for "126 - Basic Wall Controller". Module might be asleep, or is unreachable.
Z-Wave started controller inclusion mode
Z-Wave stopping controller inclusion mode
Z-Wave Syncing - started for "127 - Basic Wall Controller"
Z-Wave Syncing - retrieved module neighbors list: 1, 3, 4, 9, 10, 12, 27, 28, 50, 56, 57, 58, 59, 60, 61, 62, 74, 76, 78, 80, 86, 97, 100, 122, 124
Z-Wave Syncing - assigning return route to "127 - Basic Wall Controller"
Z-Wave Syncing - retrieved manufacture and model names: Fibaro System - 010F, Keyfob (FGKF601) - 10011000
Z-Wave Syncing - retrieved protocol version 4.38, app version 3.02
Z-Wave Syncing - retrieved class hierarchy: Routing Slave : Wall Controller : Basic Wall Controller (04 : 18 : 01, base 00)
Z-Wave Syncing - retrieved command classes: 80v1 84v2 85v1 86v1 8Ev1 56v1 98v1 59v1 5Av1 5Bv1 5Ev1 20v1 22v1 70v1 72v1 73v1 75v1 7Av1
Z-Wave Syncing - retrieved encrypt commands: - none -
Z-Wave Syncing - retrieved capabilities: routing, battery, beaming, security, waking
Z-Wave Syncing - retrieved wake interval of 0 minutes
Z-Wave Syncing - device "127 - Basic Wall Controller" wake interval changed to 60 minutes
Z-Wave Syncing - retrieved group 1 associations: []
Z-Wave Syncing - retrieved group 2 associations: []
Z-Wave Syncing - retrieved group 3 associations: []
Z-Wave Syncing - retrieved group 4 associations: []
Z-Wave Syncing - retrieved group 5 associations: []
Z-Wave Syncing - retrieved group 6 associations: []
Z-Wave Syncing - retrieved group 7 associations: []
Z-Wave Syncing - retrieved group 8 associations: []
Z-Wave Syncing - retrieved group 9 associations: []
Z-Wave Syncing - retrieved group 10 associations: []
Z-Wave Syncing - retrieved group 11 associations: []
Z-Wave Syncing - retrieved group 12 associations: []
Z-Wave Syncing - retrieved group 13 associations: []
Z-Wave Syncing - added group 1 association to interface
Z-Wave Syncing - retrieved battery level of 100%
Z-Wave Syncing - created device "127 - Keyfob (FGKF601)"
Z-Wave Syncing - complete
SQL Logger creating table device_history_374652588 for "127 - Keyfob (FGKF601)"
SQL Logger adding column "batterylevel_ui" to table device_history_374652588 ("127 - Keyfob (FGKF601)")
petematheson wrote:Using native 'when receiving z-wave command' via Indigo with the updated Z-Wave library.
In the logs I just see 'Button 1 pressed' rather than 'Button one pressed twice' which I believe I should see? (Since it shows in the list of available commands)
