Definite interest here. SWEET.
ChopOMatic wrote:Definite interest here. SWEET.
#!/usr/bin/env python -u
# Set target IP, port and command to send
ip = "192.168.5.113" # the ip address of your plug
port = 9999 # normally leave at the default 9999
# Set the polling frequency
offUpFreq = 30 # interval in secs between updates when the plug is off should be <= 30
onUpFreq = 2 # interval in secs between updates when the plug is on
# Specify the variable names for the following data elements
indigoStateVarName = "tplinkState"
indigoWattsVarName = "tplinkWatts"
indigoAmpsVarName = "tplinkAmps"
indigoVoltsVarName = "tplinkVolts"
# No changes needed below this point #
import socket
import json
import sys
from struct import pack
from threading import Event
import binascii
import subprocess
import signal
# Make sure we are not already running
cmd = '/usr/bin/pgrep -f tpmonitor.py'
process = subprocess.Popen(cmd, shell=True, stdout=subprocess.PIPE)
myPID, err = process.communicate()
# indigo.server.log("Got pid = %s" % (my_pid), type="TP-Link", isError=True)
if len(myPID.splitlines()) >0:
indigo.server.log("Quiting. tpmonitor.py is already running. pid = %s" % (myPID), type="TP-Link", isError=True)
return
indigo.server.log("PID of TPLink Monitor is: " + myPID, type="TP-Link")
# Create a way to exit the timed loop...
def reset(signo, _frame):
indigo.server.log("Polling wait interup received", type="TP-Link")
exit.set()
# ...and a trigger to invoke the exit
signal.signal(getattr(signal, 'SIGUSR1'), reset)
# Encryption and Decryption of TP-Link Smart Home Protocol
# XOR Autokey Cipher with starting key = 171
def encrypt(string):
key = 171
result = pack('>I', len(string))
for i in string:
a = key ^ ord(i)
key = a
result += chr(a)
return result
def decrypt(string):
key = 171
result = ""
for i in string:
a = key ^ ord(i)
key = ord(i)
result += chr(a)
return result
# Get our variable references from Indigo
indigoState = indigo.variables[indigoStateVarName]
indigoWatts = indigo.variables[indigoWattsVarName]
indigoAmps = indigo.variables[indigoAmpsVarName]
indigoVolts = indigo.variables[indigoVoltsVarName]
except Exception as e:
indigo.server.log("Fatal error looking uo Indigo variables: %s" % (str(e)), type="TP-Link", isError=True)
return
# set variables for the connection the the TPLink plug and the reply processing
cmdEm = '{"emeter":{"get_realtime":{}}}'
enccmdEm = encrypt(cmdEm)
cmdSt = '{"system":{"get_sysinfo":{}}}'
enccmdSt = encrypt(cmdSt)
lastState = 2 # 2 is not a legal state. Thus a state change will be forced on the first run
lastWatts = 0
errCount = 0
failFlag = False
failMsg = "Empty"
updateFreq = offUpFreq
# Open a socket and get ready to send and receive data
sock_tcp = socket.socket(socket.AF_INET, socket.SOCK_STREAM, 0)
sock_tcp.settimeout(10)
sock_tcp.connect((ip, port))
indigo.server.log("Untrapped Exception attempting to open connection to %s:%s. %s|%s" % (ip, str(port), str(sys.exc_info()[0]), str(e)), type="TP-Link", isError=True)
return
indigo.server.log("Connected to TPLink Wi-Fi Smartplug at %s." % ip, type="TP-Link", isError=False)
while True:
# indigo.server.log("Starting TCP Read", type="TP-Link", isError=True)
sock_tcp.send(enccmdSt)
sRcvd = sock_tcp.recv(8096)
if not sRcvd:
indigo.server.log("No sRcvd received", type="TP-Link", isError=True)
# indigo.server.log("Received sRcvd: |%s|" % (binascii.hexlify(bytearray(sRcvd))), type="TP-Link", isError=True)
sData = json.loads(decrypt(sRcvd[4:]))
state = sData['system']['get_sysinfo']['relay_state']
sock_tcp.send(enccmdEm)
eRcvd = sock_tcp.recv(8096)
if not eRcvd:
indigo.server.log("No eRcvd received", type="TP-Link", isError=True)
# indigo.server.log("Received eRcvd: |%s|" % (binascii.hexlify(bytearray(eRcvd))), type="TP-Link", isError=True)
eData = json.loads(decrypt(eRcvd[4:]))
curWatts = eData['emeter']['get_realtime']['power_mw']
curVolts = eData['emeter']['get_realtime']['voltage_mv']
curAmps = eData['emeter']['get_realtime']['current_ma']
if abs(curWatts - lastWatts) > 5000 or state != lastState:
startFreq = updateFreq
if state == 1:
updateFreq = onUpFreq
if startFreq != updateFreq:
indigo.server.log("Polling frequency reset to %s secs." % (str(updateFreq)), type="TP-Link", isError=False)
lastWatts = curWatts # do this here so we get a delta against the last reported watts
# indigo.server.log(u"Info log message: %s, %s, %s, %s" % (str(state), str(curWatts/1000), str(float(curAmps)/1000), str(curVolts/1000)))
indigo.variable.updateValue(indigoState, value=str(state))
indigo.variable.updateValue(indigoWatts, value=str(curWatts/1000))
indigo.variable.updateValue(indigoAmps, value=str(float(curAmps)/1000))
indigo.variable.updateValue(indigoVolts, value=str(curVolts/1000))
lastState = state
errCount = 0
except socket.timeout:
errCount += 1
if errCount < 10:
indigo.server.log("Timeout (" + str(errCount) + " fails) waiting for host " + ip + ":" + str(port), isError=True)
failMsg = "Timeout waiting for host "
failFlag = True
except socket.error:
errCount += 1
if errCount < 10:
indigo.server.log("Could not connect to host (" + str(errCount) + " fails) " + ip + ":" + str(port), isError=True)
failMsg = "Could not connect to host"
failFlag = True
except (KeyError, ValueError) as e:
errCount += 1
if errCount < 10:
indigo.server.log("No valid response received (" + str(errCount) + " fails) " + ip + ":" + str(port) + " | " + str(e), isError=True)
failMsg = "No valid response received"
failFlag = True
errCount += 1
if errCount < 10:
indigo.server.log("Untrapped exception(" + str(errCount) + " fails) " + ip + ":" + str(port) + " | " + str(e), isError=True)
failMsg = "Untrapped Exception" + str(sys.exc_info()[0]) + " | " + str(e)
failFlag = True
if failFlag:
indigo.server.log("Quitting: %s %s:%s" % (failMsg, ip, str(port)), type="TP-Link", isError=True)
break
# Start a short, interuptable, event to create a delay between loop invocations
exit = Event()
exit.wait(updateFreq)
exit.clear()
sock_tcp.close()
indigo.server.log("Received quit signal, shutting down connection to %s:%s" % (ip, port), type="TP-Link", isError=True)
return
#!/bin/zsh
TPLINK=/usr/local/bin/tplink_smartplug.py
PLUGADDR=192.168.5.113
#### Do not change anything below this line ####
FUNC=$1
# get the pid of the Indigo TPLink monitor so we can tell it when to update
PID=`pgrep -f tpmonitor.py|head -1`
alias tpOn='$TPLINK -t $PLUGADDR -c on >/dev/null 2>&1'
alias tpOff='$TPLINK -t $PLUGADDR -c off >/dev/null 2>&1'
alias tpStatus='kill -SIGUSR1 $PID;$TPLINK -t $PLUGADDR -c info | grep Received | sed -e "s/Received..//" | json_pp | grep relay_state | cut -c26 | tr -d "\n"'
case $FUNC in
on)
tpOn
tpStatus
off)
tpOff
tpStatus
toggle)
STATE=`tpStatus`
case $STATE in
0)
tpOn
tpStatus
1)
tpOff
tpStatus
echo Unknown state $STATE received from plug
exit 1
esac
status)
tpStatus
echo Error: on, off or status required
exit 1
esac
exit 0
jay (support) wrote:Is there some reason not to use the TP-Link plugin? I have a couple of the HS105 WiFi Plug Mini's and they seem to work well.
Back on Fri Dec 29, 2017, jay (support) wrote:No need for a plugin really - just execute a run shell script action that points to that script.
berkinet wrote:[size=85]On the other hand, take a look at the third post in this thread...Back on Fri Dec 29, 2017, jay (support) wrote:No need for a plugin really - just execute a run shell script action that points to that script.
jay (support) wrote:...That was a year before the plugin was created...
berkinet wrote:jay (support) wrote:...That was a year before the plugin was created...
Yes, I know. I was just answering your question “Is there some reason not to use the TP-Link plugin? “. I had seen your post, and then posts from others offering ideas and help so I didn’t think to look to see if there was already a plugin.
jay (support) wrote:We are already in contact and I have alpha code running doing periodic polling....Hopefully, if you issue a pull request with your additions to the plugin jtburgess will accept them and create a new release.....
jtburgess wrote:If there are any other known TPLink device types, now would be the time to let us all know, so I can incorporate them in the next release.
jay (support) wrote:In looking at their smart home site, they also appear to have a couple of switches, plugs (including in-wall) and a variety of bulbs including color. Does anyone have any of those?
