TP-Link WiFi Switches
Forum rules
Wed Jan 20, 2021 9:48 pm
pgershon offline
Re: TP-Link WiFi Switches
I started getting an error in my log:
(tpl_polling.py:run:126): 2 consecutive polling error for device "Office Lights": TP-Link connection timeout
Seems to go away when I reload the plugin. Not sure what the cause is but it happened on5 or 6 different evenings.
Fri Jan 22, 2021 10:37 pm
jtburgess offline
It really should be a warning, indicating a timeout waiting for a response. You’ll get a similar message after 5 consecutive errors and 8 consecutive errors before it finally gives up at 10. Then the message is
Unable to poll device %s: %s after 10 attempts. Polling for this device will now shut down.
And then you really might want to restart.
If you never see that, you have nothing to worry about. The worst case is that it won’t record a state change as quickly.
Tue Feb 02, 2021 1:15 pm
pgershon offline
I was messing around with the plugin, looking to dim my lights through Indigo as well as turn them on/off. I figured I might come up with a quick hack while the plugin was expanded. I found the reverse engineering code for the Kasa line, and I modified "commands" in protocol.py to included dimmer references. Then I modified the devices.xml to allow the device to dim as well as go on/off. Finally I added logic to the plugin.py to react to dimmer commands:
        elif action.deviceAction == indigo.kDimmerRelayAction.SetBrightness:
            cmd = "setBright"
Unfortunately, I get an error message:
TP-Link Device Error (plugin.py:actionControlDimmerRelay:319): send "new device" setBright failed with result "{"dimmer":{"err_code":-1,"err_msg":"module not support"}}"
I am not sure why the module thinks my HS220 is not supported - it should be per
Any ideas?
Tue Feb 02, 2021 2:24 pm
jtburgess offline
It’s not quite as simple as that. The bulbs use a much different JSON schema than plugs.
There is a beta available on my GitHub site that supports dimming.
Check it out : https://github.com/jtburgess/indigo-TP-LInk.
I’m waiting for confirmation that I didn’t break anything (like energy management) before I finalize an indigo release.
Let me know what you think.
Tue Feb 02, 2021 5:00 pm
pgershon offline
Thanks - I gave it a whirl. Unfortunately, I think I have a tweener. I have an HS220 dimming light switch - not a bulb. In essence, I believe, it's a relay with a dimmer. The old plugin worked fine with my HS220 except I had no capability to change the dimmer state - so if it were set to 50% with the iPhone app, Indigo could turn on/off at 50%. I believe your new code is for a bulb, which as you said, is a different JSON.
Here was my error log when I tried to set up a new device using the beta:
1) for dimmable bulb:
Feb 2, 2021 at 5:58:45 PM
TP-Link Devices Error (plugin.py:getSubType:115): model HS220 is not recognised
TP-Link Devices Error Error in plugin execution UiAction:
File "plugin.py", line 500, in selectTpDevice
File "/Library/Application Support/Perceptive Automation/Indigo 7.5/Plugins/TP-Link-Device.indigoPlugin/Contents/Server Plugin/tplink_dimmer_plugin.py", line 106, in selectTpDevice
KeyError: ('mic_mac',)
TP-Link Devices Error Error in plugin execution ServerReplacedElem:
File "/Library/Application Support/Perceptive Automation/Indigo 7.5/IndigoPluginHost.app/Contents/Resources/PlugIns/plugin_base.py", line 1179, in deviceUpdated
File "plugin.py", line 219, in deviceStartComm
KeyError: key model not found in dict
2) for smartplug
File "plugin.py", line 225, in deviceStartComm
File "/Library/Application Support/Perceptive Automation/Indigo 7.5/Plugins/TP-Link-Device.indigoPlugin/Contents/Server Plugin/tplink_relay_plugin.py", line 51, in deviceStartComm
NameError: global name 'description' is not defined
This may help: https://python-kasa.readthedocs.io/en/latest/
Tue Feb 02, 2021 6:05 pm
pgershon offline
Found what I needed:
'setBright': '{"system": {"set_relay_state": {"state": 1}},"smartlife.iot.dimmer": {"set_brightness": {"brightness": 100}}}',
Will set brightness to 100. I can modify the brightness from there. Need to fix the device state reporting to, but at least I can dim and brighten lights now. Useful for when I wake up in middle of night and don't want to wake the puppy etc
