Keyboard controlled by Indigo
Forum rules
Fri Jul 10, 2015 1:09 pm
roquej offline
I am looking for a keyboard (like the never released Z-Wave Poly-Pad keypad) that would work with Indigo? It can be z-wave, Insteon, or one that would work with RFXCOM). The use-case is for garage entry.
Any suggestions would be greatly appreciate it.
Regards,
JP
Fri Jul 10, 2015 1:16 pm
roquej offline
Re: Keyboard controlled by Indigo
Found this one: http://www.alekoproducts.com/Wireless-K ... 172-ap.htm. Any idea if t would work with the RFXCOM plugin?
Again, thank you.
JP
Fri Jul 10, 2015 2:18 pm
Are you needing the code from the device, or simply 'correct code' acceptance.
If the above or other zwave modules don't work, any code lock (http://www.accesscontroltechnology.com/ ... tal-keypad is my favourite) can be used with a binary input sensor such as Fibaro/Qubino switches.
Fri Jul 10, 2015 3:12 pm
roquej offline
Correct code acceptance is all I need. Cool. I think this might work.
Thank you!
JP
Fri Jul 10, 2015 3:17 pm
Cool.
That lock has multiple user codes and timed or held-open.
At work there's a 24/7 site-team code which holds the barrier open for events, plus the regular code for visitors that changes monthly, that opens barrier for 5 seconds.
Wed Jul 15, 2015 1:59 am
howartp wrote:
Cool.
Interesting, although wouldn't it just take someone just removing the device and shorting the wires together to get it to raise.. Like in some silly spy movie?
Also what code do you use for 24/7 access? I need it for.. Research purposes.
Wed Jul 15, 2015 4:06 pm
durosity wrote:
howartp wrote:
Cool.
Not sure because I never saw the install - though if you're that bothered you can drive round the grass and between two bollards - it's for active visitor management, not security.
The 24/7 code is 1234 and the password to login remotely is 'password'.
