http://www.squareconnect.com/index.html
Is there or will there be support for the SQ Blaster or how would I approach making an integration?
OH
wiery wrote:I integrated this with a shell script that worked quite well but to be honest it was a far better option to get the Global Cache ones. If you want the script I can get it for you if you want
jay (support) wrote:Assuming it has an API, you could build an Indigo Plugin for it using our Plugin API/SDK...
We have no current plans to build any integration ourselves.
#!/bin/bash
# Called as: send_ir_cmd <command name>
# e.g. send_ir_cmd POWER ON
# or send_ir_cmd "POWER ON"
# Get name and location of the script
me=${0##*/}
mydir=$(which $0)
mydir=${mydir%/*}
mydir=${mydir:-/}
mydir=$(cd "$mydir"; pwd)
# Command name (join command line arguments)
# If no arguments, reset them to UPPERCASED "_" seperated words of link call name
#if [[ $# -eq 0 && -L $0 ]]; then
#set -- $(echo "$me" | tr '_a-z' ' A-Z')
#fi
cmd="$*"
# Set the server name
# (will make command line option later)
server=192.168.0.8
# Set the API to call
api=docmnd.xml
# Set the device
dev=dev2898133276
# Set location of XML ir_data file to use (based on script location and device name)
ir_data_file=$mydir/$dev.xml
# Just list command names if $1 is "-l"
if [[ $1 = "-l" ]]; then
awk '
BEGIN {RS="<"; FS="\""; rc=1}
$0~/ command_name="/ {sub(/^.* command_name="/,""); print $1}
' $ir_data_file |
sort
exit $?
elif [[ $1 = "-c" ]]; then
awk '
' $ir_data_file |
sort |
awk 'BEGIN {ORS=", "}; {printf "%-20s",$0}; NR%5==0 {printf "\n"}; END {printf "\n"}'
exit $?
fi
# Get the ir_data for the command passed, exit if not found
if ! ir_data=$(awk -v cmd="$cmd" '
rc!=0 && $0~"command_name=\""cmd"\"" {sub(/^.* ir_data="/,""); print $1; rc=0}
END {exit rc}
' $ir_data_file)
then
echo "$me: No IR data found for device \"$dev\" command \"$cmd\" in data file \"$ir_data_file\"" >&2
exit 1
fi
# Set the data to POST
data='<docommand
key="'$dev'"
repeat= "100"
seq = "0"
command="'"$cmd"'"
ir_data="'"$ir_data"'"
ch="0"
echo "--- Data to POST ---"
echo "$data"
echo "--- End of data to POST ---"
# Supply data on STDIN to curl to POST to server API
# (let response go to STDOUT - script exit code will be that of curl)
#echo "${data:?}" | curl -v -d @- --dump-header - http://${server:?}/${api:?}
/usr/bin/wget -O - -v --post-data="${data:?}" http://${server:?}/${api:?}
echo=$?
echo
exit $rc
