WEMO,( IFTTT) and Wink Spotter
Forum rules
Wed Nov 28, 2018 3:06 pm
Re: WEMO,( IFTTT) and Wink Spotter
wideglidejrp wrote:
I purchased a HaoZee Smart Plug. It doesn't say Neo Coolcam anywhere, but I suspect that is what is under the covers. The setup went exactly according to the inclusion instructions; three quick clicks. It works very nicely.
Yes, there are actually a smallish number of actual device manufacturers that make Z-Wave devices - everyone else just OEMs them and adds their branding. Is it identifying itself with a manufacturer name or is it just listed as generic? If the latter, please submit the device info (on the config dialog) so we can get it properly added to the Compatible Devices list.
Wed Nov 28, 2018 4:05 pm
wideglidejrp offline
Here is the config info. Looks like a branding-only deal.
Indigo Z-Wave Version: 2.0.119
Node ID: 48
Model: Power Plug (NAS-WR02ZU)
Model ID: 00030087
Manufacturer: Neo
Manufacturer ID: 0258
Protocol Version: 4.05
Application Version: 3.94
Model Definition Version: 1
Library Type: 3
Class Hierarchy: 04 : 10 : 01
Command Class Base: 25
Command Versions: 20v1 85v1 86v1 27v1 72v1 70v1 71v1 32v4 73v1 59v1 5Av1 5Ev1 25v1
Features: routing, beaming, energyMeter
Neighbors: 29, 30, 34, 35, 45
Associations: 1:[1] 2:[] 3:[]
Config Values: 1:1 10:1 2:300 5:1 7:1
John R Patrick
Author of
Home Attitude
Wed Nov 28, 2018 5:45 pm
Yep, it's identifying as a Neo so we already know about it.
Thu May 28, 2020 5:39 pm
EagleDTW offline
Hi All,
I know that I'm pretty late to this discussion, but have started using the script by members earlier in the thread to check status of Wemo devices. I believe that since the change to an online account has occurred ~27May2020 that the script no longer has the privilege to access the devices - what does everyone believe is a good solution?
Thank you,
Daniel
Sun Jun 07, 2020 3:53 pm
EagleDTW offline
Is anybody else having issues :?: :!: :?:
