Any plans or way to get the Belkin Wemo devices connecting to Indigo?
The IFTTT integration would be fun.
Also same question about the Wink Spotter by Quirky.
https://www.quirky.com/shop/609[/color]
Rick
# Python script to operate or obtain status of Wemo switch
# based on a script WeMo.py published by pruppert on GitHub
# at https://gist.github.com/pruppert/
# Usage:
# Tested with Wemo Insight switch as an embedded script in an
# Indigo Action Group as Server Action/Script and File Action/Execute Script
#!/usr/bin/python
import re
import urllib2
# Configuration:
# Enter the local IP address of your WeMo in the parentheses of the ip variable below.
# You may have to check your router to see what local IP is assigned to the WeMo.
# It is recommended that you assign a static local IP to the WeMo to ensure the WeMo is always at that address.
# Uncomment one of the triggers at the end of this script.
# Insert the appropriate message for the Indigo event log at line 89
ip = ''
class wemo:
OFF_STATE = '0'
ON_STATES = ['1', '8']
ip = None
ports = [49153, 49152, 49154, 49151, 49155]
def __init__(self, switch_ip):
self.ip = switch_ip
def toggle(self):
status = self.status()
if status in self.ON_STATES:
result = self.off()
result = 'WeMo is now off.'
elif status == self.OFF_STATE:
result = self.on()
result = 'WeMo is now on.'
raise Exception("UnexpectedStatusResponse")
return result
def on(self):
return self._send('Set', 'BinaryState', 1)
def off(self):
return self._send('Set', 'BinaryState', 0)
def status(self):
return self._send('Get', 'BinaryState')
def name(self):
return self._send('Get', 'FriendlyName')
def signal(self):
return self._send('Get', 'SignalStrength')
def _get_header_xml(self, method, obj):
method = method + obj
return '"urn:Belkin:service:basicevent:1#%s"' % method
def _get_body_xml(self, method, obj, value=0):
return '<u:%s xmlns:u="urn:Belkin:service:basicevent:1"><%s>%s</%s></u:%s>' % (method, obj, value, obj, method)
def _send(self, method, obj, value=None):
body_xml = self._get_body_xml(method, obj, value)
header_xml = self._get_header_xml(method, obj)
for port in self.ports:
result = self._try_send(self.ip, port, body_xml, header_xml, obj)
if result is not None:
self.ports = [port]
return result
raise Exception("TimeoutOnAllPorts")
def _try_send(self, ip, port, body, header, data):
request = urllib2.Request('http://%s:%s/upnp/control/basicevent1' % (ip, port))
request.add_header('Content-type', 'text/xml; charset="utf-8"')
request.add_header('SOAPACTION', header)
request_body = '<?xml version="1.0" encoding="utf-8"?>'
request_body += '<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/">'
request_body += '<s:Body>%s</s:Body></s:Envelope>' % body
request.add_data(request_body)
result = urllib2.urlopen(request, timeout=3)
return self._extract(result.read(), data)
except Exception as e:
print str(e)
return None
def _extract(self, response, name):
exp = '<%s>(.*?)<\/%s>' % (name, name)
g = re.search(exp, response)
if g:
return g.group(1)
return response
def output(message):
# Write message to Indigo server event log
indigo.server.log ("Insert data type eg status/signal strength/etc here) " + message)
switch = wemo(ip)
# Configuration:
# Uncomment only one of the lines below to make the script work.
#output(switch.on())
#output(switch.off())
#output(switch.toggle())
#output(switch.status())
