TP-Link WiFi Switches
Forum rules
Wed Aug 28, 2019 12:58 am
ChopOMatic offline
Re: TP-Link WiFi Switches
I have one of the TP-Links bulbs set up. Hope to play with it tomorrow with the scripts.
Tue Sep 17, 2019 4:15 pm
jtburgess offline
Berkinet and Ramias have made MANY changes to support multi-plug devices and devices that report energy usage, but nothing specific for light bulbs. Thanks, guys!
The GitHub master has just been merged with all of those changes, but I haven't yet made this into a "release".
JAY - if you have time please check it out and remind me what I need to do to release it. I am rereading the indigo_7.3_documentation:plugin_guide, so just mistakes I might make that aren't documented.
You too. download the GitHub master and see it it does everything you need. If not ... how's your python :)
or maybe its already working for you !
Tue Sep 17, 2019 4:27 pm
On Github, just create a release, zip up the plugin and attach it to the release, then in your Indigo Account just edit the plugin and save it - it should automatically pick up the new one.
Looking forward to this as Amazon has the dual-outlet one on sale today and I just picked one up... ;)
Wed Sep 18, 2019 1:49 pm
Well, the upgrade didn't go well. Did a status request on an existing device and got:
   TP-Link Device Error            Error in plugin execution CalcDeviceFunc:
  File "plugin.py", line 372, in getDeviceStateList
AttributeError: 'NoneType' object has no attribute 'append'
   TP-Link Device Error            Error in plugin execution ServerReplacedElem:
  File "/Library/Application Support/Perceptive Automation/Indigo 7.3/IndigoPluginHost.app/Contents/Resources/PlugIns/plugin_base.py", line 1179, in deviceUpdated
  File "plugin.py", line 146, in deviceStartComm
KeyError: key multiPlug not found in dict
   TP-Link Device Error            Error in plugin execution ExecuteAction:
  File "plugin.py", line 250, in actionControlDimmerRelay
Then, did another, and:
  File "plugin.py", line 333, in actionControlUniversal
TypeError: not enough arguments for format string
So, something broke my existing smart plug... :( :roll:
I'll revert back until these issues are worked out.
Wed Sep 18, 2019 3:47 pm
berkinet offline
jay (support) wrote:
Well, the upgrade didn't go well.... ...So, something broke my existing smart plug... :( :roll:
Devices from previous versions of this plugin are not compatible with the new version. You will need to delete the old devices and then recreate them.
Wed Sep 18, 2019 4:02 pm
What??? That really sucks...
Wed Sep 18, 2019 4:13 pm
berkinet offline
Or not. There is now only one device type for all TP-Link WiFi plugs. The plugin does a discovery process for all compatible devices on the local network. The Indigo device is then automatically configured, though you can change a few options. Give it a try.
Wed Sep 18, 2019 6:54 pm
That's great for people adding new devices.
It sucks for us that have existing devices that we have to go recreate since deleting devices means I have to go manually change all the places they've been linked. This is not a good user experience...
Wed Sep 18, 2019 7:47 pm
You do know it's possible to change the devices when the new version of the plugin starts?
Thu Sep 19, 2019 12:15 am
berkinet offline
FlyingDiver wrote:
...You do know it's possible to change the devices when the new version of the plugin starts?
Yes I do, and I felt that given the significant functional and design differences between the new and old releases and the likely small number of devices anyone might have, it was better to have a fresh start.
Thu Sep 19, 2019 5:50 am
I had a similar problem with a different plugin I was working on. I found that I could "salvage" the old devices by changing them to a different type with a manual address (like X-10) then change them back to the correct plugin with the new device type.
Thu Sep 19, 2019 5:53 am
Then it would have been better to use a different plugin ID, which is what I ended up doing with the Ecobee plugin. I couldn't make them backward compatible, so the users were going to have to change the devices anyway.
Thu Sep 19, 2019 8:22 am
Yeah, I'll give that a try. It often won't work for custom devices (since state information that could be used in actions might break), but since these are standard relay and dimmer devices, it might work.
If there is some holdup to migrating devices (which should always be the first choice if possible), then another option, and one we took with the WeatherSnoop plugin, would be to leave legacy devices in place and add a new device type. This would not "break" anything, but would allow users to use the new device type when adding devices. In the case of WeatherSnoop, WS v2 had a fixed set of states regardless of the type of weather station that it was talking to. But with WS3, each agent presented all the data available for the specific hardware (or service) it was talking to. So it didn't make any sense to attempt to migrate those devices (since the data sets were so different) but we also didn't want to break any existing users.
I understand the sentiment even if I don't agree. But at the very least, you should catch when an older device attempts to start up, log an error with what to do to deal with the issue, and then disable the device. Still not a great solution, but much better than allowing random stack traces to show up in the Event Log. Better UX with likely a minimum amount of work.
Thu Sep 19, 2019 9:55 am
berkinet offline
FlyingDiver wrote:
...Then it would have been better to use a different plugin ID, which is what I ended up doing with the Ecobee plugin. I couldn't make them backward compatible, so the users were going to have to change the devices anyway.
And then you’d be right where you are today, having to recreate all your devices.
Quite simply, if you don’t like the new version, don’t use it. Enough said,
Sun Sep 22, 2019 9:38 am
CliveS offline
Due to the Alexa Hue being neutered (thanks Amazon!!) I decided to buy an HS110 and it works well but when I Send Status Request or Update I get the following error
CliveS
Page 6 of 8 1 ... 3, 4, 5, 6, 7, 8
