Indigo hangs every 12 Hours....
Fri Apr 12, 2024 10:51 am
kidney offline
I'm I the only that Indigo freeze/hangs every 12-18 Hours, system process are through the roof and nothing responds anymore.
I force quit the app and my cpu process stays @ 450 - 500% used.
I have to open activity monitor and quit every single process that is related to indigo or reboot
indigopluginhost3 is at 400% usage.....
This has been happening for the last couple of month and is getting worst in the last few weeks!
Screen Sharing Picture 12 April 2024 at 12.45.43 EDT.jpeg (346.22 KiB) Viewed 218 times
Fri Apr 12, 2024 11:10 am
Re: Indigo hangs every 12 Hours....
You need to figure out which plugin (or script) is running in that runaway process.
Double click on that process in the Activity Monitor window, then click on the "Open Files and Ports" tab, then copy the contents of the window to this thread.
Fri Apr 12, 2024 4:03 pm
kidney offline
Looks like home assistant....
/Library/Application Support/Perceptive Automation/Indigo 2023.2/Plugins/HomeAssistantAgent.indigoPlugin/Contents/Server Plugin
/Library/Application Support/Perceptive Automation/Indigo 2023.2/IndigoPluginHost3.app/Contents/MacOS/IndigoPluginHost3
/System/Library/CoreServices/SystemVersion.bundle/English.lproj/SystemVersion.strings
/private/var/db/timezone/tz/2024a.1.0/icutz/icutz44l.dat
/System/Library/CoreServices/SystemAppearance.bundle/Contents/Resources/SystemAppearance.car
/private/var/db/analyticsd/events.allowlist
/System/Library/Keyboard Layouts/AppleKeyboardLayouts.bundle/Contents/Resources/AppleKeyboardLayouts-L.dat
/System/Library/Caches/com.apple.IntlDataCache.le.kbdx
/System/Library/Keyboard Layouts/AppleKeyboardLayouts.bundle/Contents/Resources/InfoPlist.loctable
/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/lib-dynload/math.cpython-311-darwin.so
/Library/Preferences/Logging/.plist-cache.ikLoKJNL
/private/var/folders/jg/vg_nrsvn5g7d_3yvj0rtbcgc0000gn/0/com.apple.LaunchServices.dv/com.apple.LaunchServices-5028-v2.csstore
/System/Library/CoreServices/SystemAppearance.bundle/Contents/Resources/FauxVibrantLight.car
/System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/lib-dynload/_socket.cpython-311-darwin.so
/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/lib-dynload/_json.cpython-311-darwin.so
/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/lib-dynload/_datetime.cpython-311-darwin.so
/Library/Frameworks/Python.framework/Versions/3.11/Python
/usr/share/icu/icudt74l.dat
/System/Library/CoreServices/SystemAppearance.bundle/Contents/Resources/Aqua.car
/System/Library/CoreServices/SystemAppearance.bundle/Contents/Resources/VibrantLight.car
/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/lib-dynload/array.cpython-311-darwin.so
/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/lib-dynload/select.cpython-311-darwin.so
/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/lib-dynload/_pickle.cpython-311-darwin.so
/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/lib-dynload/_struct.cpython-311-darwin.so
/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/lib-dynload/_elementtree.cpython-311-darwin.so
/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/lib-dynload/_heapq.cpython-311-darwin.so
/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/lib-dynload/_queue.cpython-311-darwin.so
/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/lib-dynload/_hashlib.cpython-311-darwin.so
/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/lib-dynload/_bz2.cpython-311-darwin.so
/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/lib-dynload/readline.cpython-311-darwin.so
/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/lib-dynload/_bisect.cpython-311-darwin.so
/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/lib-dynload/fcntl.cpython-311-darwin.so
/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/lib-dynload/termios.cpython-311-darwin.so
/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/lib-dynload/pyexpat.cpython-311-darwin.so
/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/lib-dynload/_opcode.cpython-311-darwin.so
/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/lib-dynload/_typing.cpython-311-darwin.so
/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/lib-dynload/_ctypes.cpython-311-darwin.so
/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/lib-dynload/_blake2.cpython-311-darwin.so
/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/lib-dynload/binascii.cpython-311-darwin.so
/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/lib-dynload/_ssl.cpython-311-darwin.so
/Library/Frameworks/Python.framework/Versions/3.11/lib/libncursesw.5.dylib
/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/lib-dynload/_asyncio.cpython-311-darwin.so
/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/lib-dynload/_random.cpython-311-darwin.so
/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/lib-dynload/zlib.cpython-311-darwin.so
/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/lib-dynload/_posixsubprocess.cpython-311-darwin.so
/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/lib-dynload/_contextvars.cpython-311-darwin.so
/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/lib-dynload/_sha512.cpython-311-darwin.so
/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/lib-dynload/_lzma.cpython-311-darwin.so
/Library/Frameworks/Python.framework/Versions/3.11/lib/libssl.3.dylib
/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/lib-dynload/unicodedata.cpython-311-darwin.so
/Library/Frameworks/Python.framework/Versions/3.11/lib/libcrypto.3.dylib
/dev/null
/dev/null
/dev/null
localhost:55434->localhost:indigo-server
/Library/Application Support/Perceptive Automation/Indigo 2023.2/Logs/no.homeassistant.plugin/plugin.log
->0xd46174d788080d28
->0x4cfdd83a981441a7
*:mdns
localhost:mdns
10.36.10.2:mdns
10.36.50.3:mdns
count=3, state=0x8
->0x5f278f81542816d1
->0x5f278f8154281541
10.36.50.3:51282->10.36.50.116:8123
Fri Apr 12, 2024 4:21 pm
Yup. So please start a new thread in in the HAA forum: viewforum.php?f=396
Post a summary of your HA installation (host OS, number of devices, number of entities). Confirm that you're running the latest version of HAA, and give a summary of the number of HAA devices you've created in Indigo (and what types they are). Also check your log for any HAA plugin errors.
