Trouble when power is restored after power cut.
Tue Aug 15, 2023 11:39 am
CliveS offline
I have been having several power blips recently and this is causing havoc with several plug-ins.
I can catch most errors (not all) and restart most plug-ins (except if they have the “Red Dot’) but that does not clear them up 100%, there must be a better option, personally I would like to restart Indigo after the reflector comes back on line for a clean startup but not sure I can?
As you can see it can take upto 15 minutes for the reflector to get on line as the ISP modem, Dream Machine router, 24 Port switch, access ports, HomePod mini and Apple TV all power up and sync.
2023-08-15 13:48:47.746   Application   Starting Indigo Server version 2022.2.2 on macOS Version 13.5 (Build 22G74)
2023-08-15 13:48:48.363   Application   Loading database "/Library/Application Support/Perceptive Automation/Indigo 2022.2/Databases/xxxxxxxxxx.indiDb"
2023-08-15 13:48:48.541   Application   Waiting for client to connect
2023-08-15 13:48:50.790   Application   Indigo Cocoa client connected
2023-08-15 13:48:50.801   Error   Unable to connect to IndigoDomo.com.
2023-08-15 14:03:28.645   Alexa Warning   Your reflector isn't available - you won't be able to use Alexa until the reflector is operating correctly.
2023-08-15 14:03:57.774   Reflector   starting reflector connection to https://xxxxxxxxx.indigodomo.net
Any ideas apart from buying 5 x UPS’s (as that will not get WAF! )
CliveS
Users browsing this forum: No registered users and 18 guests
