Indigo Server restarting occasionally
Wed May 24, 2023 7:42 am
Jason G. offline
Hi-
I've seen the Indigo server just restart itself a few times over the last few weeks. When I come back to my computer the Indigo client (which I usually leave running all the time) is asking me to start local server or connect to remote server... It looks like the server stopped for some reason, the client timed out, and the server started up again by itself.
Looking at the logs I see this:
2023-05-24 09:09:37.879   Received INSTEON   "Bedroom 8-button" on (button 7)
2023-05-24 09:13:42.934   Received INSTEON   "Pantry Sensor" on (button 1)
2023-05-24 09:15:03.273   Received INSTEON   "Pantry Sensor" off (button 1)
2023-05-24 09:16:16.410   Application   Starting Indigo Server version 2022.2.2 on macOS Version 11.7.7 (Build 20G1345)
2023-05-24 09:16:16.884   Application   Loading database "/Library/Application Support/Perceptive Automation/Indigo 2022.2/Databases/MyHouse.indiDb"
2023-05-24 09:16:16.967   Application   Waiting for client to connect
2023-05-24 09:16:16.981   Application   Retrieved unchanged location for sunset/sunrise calculation
2023-05-24 09:16:31.967   Warning   timeout waiting for client to connect
2023-05-24 09:16:32.217   Application   Finding disabled plugins
The rest of the logs are the normal startup sequence. I don't have anything special scheduled to run ~9:15am, and no obvious reason for the server to restart.
I haven't made any significant changes in the last month or so, other than macOS updates dot-updates - this iMac is running macOS Big Sur 11.7.7. My Indigo version is 2022.2.2. Plugins haven't changed recently, but I'm using Alexa, Ecobee 2, Email+, HomeKitLink Siri, Pushover. It looks like my HomeKitLink was on an older version, so I just updated to the most recent release. That doesn't seem like it would cause the server to restart, but it's worth mentioning.
I'm wondering if maybe this is related to the FileIO problem which was fixed/behavior changed with Indigo version2022.2?
This isn't a huge problem because the server restarts itself, but is there a way I can turn on more logging to see what is causing the server to restart?
Jason
Wed May 24, 2023 9:07 am
Re: Indigo Server restarting occasionally
Odd. Check your Mac's Console for any IndigoServer process crashes or messages to see if the server crashed and was automatically restarted. You can use the time from the Event Log as a reference.
Also, does it always happen around the same time? Does there seem to be any consistency around frequency (every day, every 3 days, every Monday, etc).
Wed May 24, 2023 11:12 am
Jason G. offline
Found some good info in the Console :: Crash Reports.
One thing that jumps out at me is the Time Awake Since Boot for all of them are very round numbers. Not sure if that is a clue, or just obfuscated rounding for the log.
Here are the times it has crashed:
- 5/19 at 3:32 pm - Time Awake Since Boot: 84000 seconds
- 5/21 at 5:31 pm - Time Awake Since Boot: 260000 seconds
- 5/22 at 4:11 pm - Time Awake Since Boot: 340000 seconds
- 5/23 at 5:14 pm - Time Awake Since Boot: 430000 seconds
- 5/24 at 8:10 am - Time Awake Since Boot: 480000 seconds
- 5/24 at 9:16 am - Time Awake Since Boot: 490000 seconds
I have since rebooted my computer for general hygiene, and while writing up these notes the IndigoServer crashed again at 1:06 pm - Time Awake Since Boot: 11000 seconds.
I can share more/all of the crash reports, or the portions that matter. It looks like a lot of this is redundant stuff, but I don't know how to read it so posting it all in case it helps.
Here's the crash from this morning at 9:16 am:
Process:               IndigoServer [52795]
Path:                  /Library/Application Support/Perceptive Automation/*/IndigoServer.app/Contents/MacOS/IndigoServer
Identifier:            com.perceptiveautomation.indigo-server
Version:               2022.2.2 (2022.2.2)
Code Type:             X86-64 (Native)
Parent Process:        ??? [1]
Responsible:           IndigoServer [52795]
User ID:               502
Date/Time:             2023-05-24 09:16:16.268 -0400
OS Version:            macOS 11.7.7 (20G1345)
Report Version:        12
Anonymous UUID:        B1B63233-A5F9-70C3-9DCE-DD59518C7D1D
System Integrity Protection: enabled
Crashed Thread:        0  Dispatch queue: com.apple.main-thread
Exception Type:        EXC_BAD_ACCESS (SIGSEGV)
Exception Codes:       KERN_INVALID_ADDRESS at 0x0000000000000018
Exception Note:        EXC_CORPSE_NOTIFY
Termination Signal:    Segmentation fault: 11
Termination Reason:    Namespace SIGNAL, Code 0xb
Terminating Process:   exc handler [52795]
VM Regions Near 0x18:
    __TEXT                      10db6a000-10de52000    [ 2976K] r-x/r-x SM=COW  /Library/Application Support/Perceptive Automation/*/IndigoServer.app/Contents/MacOS/IndigoServer
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0   libsystem_malloc.dylib           0x00007fff20300cdf tiny_free_list_add_ptr + 389
1   libsystem_malloc.dylib           0x00007fff202fe33f tiny_malloc_from_free_list + 1632
2   libsystem_malloc.dylib           0x00007fff202fd75d tiny_malloc_should_clear + 233
3   libsystem_malloc.dylib           0x00007fff202fc667 szone_malloc_should_clear + 66
4   libsystem_malloc.dylib           0x00007fff20315f3b _malloc_zone_malloc + 118
5   libc++abi.dylib                  0x00007fff2049982a operator new(unsigned long) + 26
6   com.perceptiveautomation.indigo-server   0x000000010dc638de 0x10db6a000 + 1022174
7   com.perceptiveautomation.indigo-server   0x000000010dc6378a 0x10db6a000 + 1021834
8   com.perceptiveautomation.indigo-server   0x000000010dc42979 0x10db6a000 + 887161
9   com.perceptiveautomation.indigo-server   0x000000010dc426c0 0x10db6a000 + 886464
10  com.apple.CoreFoundation         0x00007fff205cccdc __CFRUNLOOP_IS_CALLING_OUT_TO_A_SOURCE0_PERFORM_FUNCTION__ + 17
11  com.apple.CoreFoundation         0x00007fff205ccc44 __CFRunLoopDoSource0 + 180
12  com.apple.CoreFoundation         0x00007fff205cc9c4 __CFRunLoopDoSources0 + 242
13  com.apple.CoreFoundation         0x00007fff205cb3ec __CFRunLoopRun + 893
14  com.apple.CoreFoundation         0x00007fff205ca9ac CFRunLoopRunSpecific + 563
15  com.apple.HIToolbox              0x00007fff288161f3 RunCurrentEventLoopInMode + 292
16  com.apple.HIToolbox              0x00007fff28815f55 ReceiveNextEventCommon + 587
17  com.apple.HIToolbox              0x00007fff28815cf3 _BlockUntilNextEventMatchingListInModeWithFilter + 70
18  com.apple.AppKit                 0x00007fff22dd4ad2 _DPSNextEvent + 864
19  com.apple.AppKit                 0x00007fff22dd32a5 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 1364
20  com.apple.AppKit                 0x00007fff22dc55c9 -[NSApplication run] + 586
21  com.apple.AppKit                 0x00007fff22d997cc NSApplicationMain + 816
22  libdyld.dylib                    0x00007fff204eff3d start + 1
Thread 1:
0   libsystem_kernel.dylib           0x00007fff204a1cbe __psynch_cvwait + 10
1   libsystem_pthread.dylib          0x00007fff204d4e49 _pthread_cond_wait + 1298
2   com.perceptiveautomation.indigo-server   0x000000010dc4525b 0x10db6a000 + 897627
3   com.perceptiveautomation.indigo-server   0x000000010dc4fb34 0x10db6a000 + 940852
4   com.perceptiveautomation.indigo-server   0x000000010dc4e9bd 0x10db6a000 + 936381
5   com.perceptiveautomation.indigo-server   0x000000010dc4e5fc 0x10db6a000 + 935420
6   com.perceptiveautomation.indigo-server   0x000000010ddac3b8 0x10db6a000 + 2368440
7   libsystem_pthread.dylib          0x00007fff204d48fc _pthread_start + 224
8   libsystem_pthread.dylib          0x00007fff204d0443 thread_start + 15
Thread 2:
Thread 3:
2   com.perceptiveautomation.indigo-server   0x000000010dc5193e 0x10db6a000 + 948542
3   com.perceptiveautomation.indigo-server   0x000000010dc5149f 0x10db6a000 + 947359
4   com.perceptiveautomation.indigo-server   0x000000010dc6bdb2 0x10db6a000 + 1056178
5   com.perceptiveautomation.indigo-server   0x000000010dc4f581 0x10db6a000 + 939393
6   com.perceptiveautomation.indigo-server   0x000000010dc4e9f0 0x10db6a000 + 936432
7   com.perceptiveautomation.indigo-server   0x000000010dc4e5fc 0x10db6a000 + 935420
8   com.perceptiveautomation.indigo-server   0x000000010ddac3b8 0x10db6a000 + 2368440
9   libsystem_pthread.dylib          0x00007fff204d48fc _pthread_start + 224
10  libsystem_pthread.dylib          0x00007fff204d0443 thread_start + 15
Thread 4:
0   libsystem_kernel.dylib           0x00007fff204a7636 __select + 10
1   com.perceptiveautomation.indigo-server   0x000000010dc22ed0 0x10db6a000 + 757456
2   com.perceptiveautomation.indigo-server   0x000000010dc4f581 0x10db6a000 + 939393
3   com.perceptiveautomation.indigo-server   0x000000010dc4e9f0 0x10db6a000 + 936432
4   com.perceptiveautomation.indigo-server   0x000000010dc4e5fc 0x10db6a000 + 935420
5   com.perceptiveautomation.indigo-server   0x000000010ddac3b8 0x10db6a000 + 2368440
6   libsystem_pthread.dylib          0x00007fff204d48fc _pthread_start + 224
7   libsystem_pthread.dylib          0x00007fff204d0443 thread_start + 15
Thread 5:
4   com.perceptiveautomation.indigo-server   0x000000010dce7fb4 0x10db6a000 + 1564596
Thread 6:: com.apple.NSEventThread
0   libsystem_kernel.dylib           0x00007fff2049f29a mach_msg_trap + 10
1   libsystem_kernel.dylib           0x00007fff2049f60c mach_msg + 60
2   com.apple.CoreFoundation         0x00007fff205ccebf __CFRunLoopServiceMachPort + 316
3   com.apple.CoreFoundation         0x00007fff205cb59f __CFRunLoopRun + 1328
5   com.apple.AppKit                 0x00007fff22f5ab7a _NSEventThread + 124
Thread 7:
1   com.perceptiveautomation.indigo-server   0x000000010dc2c0c7 0x10db6a000 + 794823
Thread 8:
Thread 9:
Thread 10:
4   com.perceptiveautomation.indigo-server   0x000000010dc6fc68 0x10db6a000 + 1072232
Thread 11:
Thread 12:
Thread 13:
Thread 14:
1   com.perceptiveautomation.indigo-server   0x000000010dcf50fb 0x10db6a000 + 1618171
Thread 15:
4   com.perceptiveautomation.indigo-server   0x000000010dceb10c 0x10db6a000 + 1577228
Thread 16:
Thread 17:
Thread 18:
Thread 19:
1   com.perceptiveautomation.indigo-server   0x000000010dbb5900 0x10db6a000 + 309504
Thread 20:
4   com.perceptiveautomation.indigo-server   0x000000010dc6fe1b 0x10db6a000 + 1072667
Thread 21:
Thread 22:
0   libsystem_pthread.dylib          0x00007fff204d0420 start_wqthread + 0
Thread 23:
Thread 24:
Thread 25:
Thread 26:
Thread 0 crashed with X86 Thread State (64-bit):
  rax: 0x000000004d2f001c  rbx: 0x00000000cb6a7024  rcx: 0x000000004d2f6bd0  rdx: 0x00007fc7dd7d3ae0
  rdi: 0x000000010e355080  rsi: 0x000007fc7dd7d3ae  rbp: 0x00007ffee2094170  rsp: 0x00007ffee2094140
   r8: 0x000000000000cfa6   r9: 0x0000000000000000  r10: 0x00007fc7dd700000  r11: 0x00007fc7dd75b910
  r12: 0x000000000000000f  r13: 0xb00007fc7dd7d3ae  r14: 0xf000000000000001  r15: 0x0000000000000010
  rip: 0x00007fff20300cdf  rfl: 0x0000000000010283  cr2: 0x0000000000000018
Logical CPU:     2
Error Code:      0x00000006 (no mapping for user data write)
Trap Number:     14
Thread 0 instruction stream:
  0f 49 39 c4 0f 85 88 03-00 00 4d 85 ff 0f 84 a9  .I9.......M.....
  01 00 00 48 89 d6 48 c1-ee 04 49 31 d5 4c 89 e8  ...H..H...I1.L..
  48 c1 e8 08 44 01 e8 4c-89 e9 48 c1 e9 10 01 c1  H...D..L..H.....
  4c 89 e8 48 c1 e8 18 01-c8 4c 89 e9 48 c1 e9 20  L..H.....L..H..
  01 c1 4c 89 e8 48 c1 e8-28 01 c8 4c 89 e9 48 c1  ..L..H..(..L..H.
  e9 30 01 c1 49 c1 ed 38-41 01 cd 49 0f a4 d5 3c  .0..I..8A..I...<
 [4d]89 6f 08 e9 5f 01 00-00 41 83 7a 18 ff 0f 84  M.o.._...A.z....   <==
  fe 01 00 00 4e 8b 7c ce-20 4d 85 ff 0f 84 f5 01  ....N.|. M......
  00 00 48 8b 8e 80 08 00-00 48 85 c9 0f 84 e5 01  ..H......H......
  00 00 4c 39 d1 0f 84 dc-01 00 00 31 db 45 31 f6  ..L9.......1.E1.
  45 31 db 48 89 c8 48 25-00 00 f0 ff 42 0f b7 84  E1.H..H%....B...
  88 2a 3f 00 00 66 85 c0-4c 0f 45 d9 44 0f 45 f0  .*?..f..L.E.D.E.
Thread 0 last branch register state not available.
Binary Images:
       0x10db6a000 -        0x10de51fff +com.perceptiveautomation.indigo-server (2022.2.2 - 2022.2.2) <C076CDFA-2FBE-3726-A3BA-FE749E6B4047> /Library/Application Support/Perceptive Automation/*/IndigoServer.app/Contents/MacOS/IndigoServer
       0x10de9a000 -        0x10e211fff +org.python.python (3.10.2, [c] 2001-2021 Python Software Foundation. - 3.10.2) <3CE17F5D-8DFD-3F3A-A9BC-5C4E01A76680> /Library/Frameworks/Python.framework/Versions/3.10/Python
       0x11039a000 -        0x11039dfff  com.apple.textencoding.unicode (7.0 - 7.0) <C12F68DE-58BA-3A8F-BEE1-9252A9D1753D> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
       0x1104b1000 -        0x11054cfff  dyld (852.2) <4FF2ABFD-E712-356A-9458-F9914B67D65C> /usr/lib/dyld
       0x1107a6000 -        0x1107b1fff +math.cpython-310-darwin.so (0) <4A55F324-1DB5-3E8E-B4A3-D0CB20013EC7> /Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/lib-dynload/math.cpython-310-darwin.so
       0x1107c2000 -        0x1107d1fff +_datetime.cpython-310-darwin.so (0) <A907E930-C2F0-3176-B917-D08B07406265> /Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/lib-dynload/_datetime.cpython-310-darwin.so
       0x1107e6000 -        0x1107edfff +_struct.cpython-310-darwin.so (0) <D5F4083E-0864-3EBC-A2E9-129DDADAE0F9> /Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/lib-dynload/_struct.cpython-310-darwin.so
       0x115add000 -        0x115b1cfff +sa_main.so (0) <6A3CF985-E839-3A56-B4FD-D1B0CAF9847E> /Library/Application Support/Perceptive Automation/*/IndigoServer.app/Contents/Resources/PlugIns/sa_main.so
       0x115b45000 -        0x115b4cfff +binascii.cpython-310-darwin.so (0) <79FA1095-97A6-3586-886C-5A51ACB27E60> /Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/lib-dynload/binascii.cpython-310-darwin.so
       0x115b59000 -        0x115b60fff +_hashlib.cpython-310-darwin.so (0) <78D684EB-2026-3C47-8194-478AA04650D7> /Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/lib-dynload/_hashlib.cpython-310-darwin.so
       0x115b71000 -        0x115bd0fff +libssl.1.1.dylib (0) <D960874E-A136-30DD-9A9C-31E470D91A4F> /Library/Frameworks/Python.framework/Versions/3.10/lib/libssl.1.1.dylib
       0x115c05000 -        0x115e2cfff +libcrypto.1.1.dylib (0) <6B13011F-DBA3-36CD-9117-B724136BC280> /Library/Frameworks/Python.framework/Versions/3.10/lib/libcrypto.1.1.dylib
       0x115ecd000 -        0x115ed4fff +_blake2.cpython-310-darwin.so (0) <76FAB244-42DD-3FA0-86B9-F0679396B3A8> /Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/lib-dynload/_blake2.cpython-310-darwin.so
       0x115ee1000 -        0x115ee8fff +_json.cpython-310-darwin.so (0) <236B4A1E-31D8-3078-81B7-5B774DEFC0EF> /Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/lib-dynload/_json.cpython-310-darwin.so
       0x115ff5000 -        0x116004fff +_socket.cpython-310-darwin.so (0) <42CD0F4C-F2BB-338E-A6FA-A4C9AFC56A72> /Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/lib-dynload/_socket.cpython-310-darwin.so
       0x116015000 -        0x11601cfff +select.cpython-310-darwin.so (0) <0FD43AC5-BFF4-3E66-A785-A60C9AAC1875> /Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/lib-dynload/select.cpython-310-darwin.so
       0x116029000 -        0x116030fff +array.cpython-310-darwin.so (0) <C34A750A-7833-35CE-AEBE-7B16CA1C6246> /Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/lib-dynload/array.cpython-310-darwin.so
       0x116041000 -        0x11605cfff +_pickle.cpython-310-darwin.so (0) <EF432C1B-C3BC-376D-8D94-BDD86C5182A3> /Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/lib-dynload/_pickle.cpython-310-darwin.so
       0x116071000 -        0x116074fff +_heapq.cpython-310-darwin.so (0) <AAD960EE-8DE2-3078-99D2-615CE69BD61F> /Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/lib-dynload/_heapq.cpython-310-darwin.so
       0x116081000 -        0x116084fff +_queue.cpython-310-darwin.so (0) <4BAD058D-BFA8-3BA5-90E2-2DB8B879A682> /Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/lib-dynload/_queue.cpython-310-darwin.so
       0x116191000 -        0x116198fff +zlib.cpython-310-darwin.so (0) <3AC75649-307B-3AF2-A1A9-13DCFDD5095C> /Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/lib-dynload/zlib.cpython-310-darwin.so
       0x1161a9000 -        0x1161acfff +_bz2.cpython-310-darwin.so (0) <F83970CA-D9A0-3EE3-8BB1-BDF120CB89B5> /Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/lib-dynload/_bz2.cpython-310-darwin.so
       0x1161b9000 -        0x1161e8fff +_lzma.cpython-310-darwin.so (0) <49A06B90-E089-3D9A-9C38-A893F3876AB6> /Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/lib-dynload/_lzma.cpython-310-darwin.so
       0x1161fd000 -        0x116200fff +_bisect.cpython-310-darwin.so (0) <4474B77C-5356-3E2E-9F40-97A25F0CF2F6> /Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/lib-dynload/_bisect.cpython-310-darwin.so
       0x11620d000 -        0x116210fff +_random.cpython-310-darwin.so (0) <D3BA7AAB-D301-3674-8FD7-7119D82D9D9F> /Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/lib-dynload/_random.cpython-310-darwin.so
       0x11621d000 -        0x116224fff +_sha512.cpython-310-darwin.so (0) <9F2E74BB-197A-3457-9FC7-26CF116E9993> /Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/lib-dynload/_sha512.cpython-310-darwin.so
       0x116231000 -        0x116234fff +_uuid.cpython-310-darwin.so (0) <21BAF83E-DA2E-32F4-8D34-045238CC43C0> /Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/lib-dynload/_uuid.cpython-310-darwin.so
       0x116241000 -        0x11626cfff +sa_geturl.so (0) <AB1D1D95-F93E-35A6-84A3-AADEA009A859> /Library/Application Support/Perceptive Automation/*/IndigoServer.app/Contents/Resources/PlugIns/sa_geturl.so
       0x116289000 -        0x1162a0fff +_ssl.cpython-310-darwin.so (0) <0558EB2E-5BED-32DC-A792-ACBB103E7587> /Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/lib-dynload/_ssl.cpython-310-darwin.so
       0x1165bd000 -        0x1166c8fff +unicodedata.cpython-310-darwin.so (0) <2194AFB9-E1EC-3553-821D-D694A661577D> /Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/lib-dynload/unicodedata.cpython-310-darwin.so
       0x1166d9000 -        0x1166e0fff +_multibytecodec.cpython-310-darwin.so (0) <6349B381-ECD8-3E96-9B52-39D6A7875EBC> /Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/lib-dynload/_multibytecodec.cpython-310-darwin.so
       0x1166f1000 -        0x1166f4fff +_scproxy.cpython-310-darwin.so (0) <2598BEFE-99A5-3DD2-A3CB-1D35876A64D0> /Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/lib-dynload/_scproxy.cpython-310-darwin.so
       0x116901000 -        0x116914fff +utilfuncs.so (0) <D1D6C356-FDA3-3E05-BDB2-D16B915077DA> /Library/Application Support/Perceptive Automation/*/IndigoServer.app/Contents/Resources/PlugIns/utilfuncs.so
       0x116929000 -        0x116934fff +_elementtree.cpython-310-darwin.so (0) <AB09597C-B46A-3ED1-8A49-AB0E2195D634> /Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/lib-dynload/_elementtree.cpython-310-darwin.so
       0x116949000 -        0x116974fff +pyexpat.cpython-310-darwin.so (0) <18147D16-BB34-3B8E-A3D5-D354CDEFDD75> /Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/lib-dynload/pyexpat.cpython-310-darwin.so
    0x7fff2020c000 -     0x7fff2020dfff  libsystem_blocks.dylib (79) <F5B25F38-FC21-3BF5-A147-3B913DA098BE> /usr/lib/system/libsystem_blocks.dylib
    0x7fff2020e000 -     0x7fff20243fff  libxpc.dylib (2038.120.1.700.2) <00FA6919-25CB-3B8F-BC41-55D3E976BC33> /usr/lib/system/libxpc.dylib
    0x7fff20244000 -     0x7fff2025bfff  libsystem_trace.dylib (1277.120.1) <1F20357C-395F-3095-B525-AD9403290A92> /usr/lib/system/libsystem_trace.dylib
    0x7fff2025c000 -     0x7fff202f9fff  libcorecrypto.dylib (1000.140.4) <BDD3FF5E-34F8-3AC0-A05C-F9AC17C88BBF> /usr/lib/system/libcorecrypto.dylib
    0x7fff202fa000 -     0x7fff20326fff  libsystem_malloc.dylib (317.140.5) <3AB4C7E9-C49C-3EB7-9370-370F3F655024> /usr/lib/system/libsystem_malloc.dylib
    0x7fff20327000 -     0x7fff2036bfff  libdispatch.dylib (1271.120.2) <5D824C33-C5E2-38A8-BD00-D934443DBDAB> /usr/lib/system/libdispatch.dylib
    0x7fff2036c000 -     0x7fff203a5fff  libobjc.A.dylib (824.1) <A0961DED-3477-3856-A6BC-CFE2475CB2F4> /usr/lib/libobjc.A.dylib
    0x7fff203a6000 -     0x7fff203a8fff  libsystem_featureflags.dylib (28.60.1) <2BAC8770-AFC8-3FE2-B6C6-27CE44B2B2BA> /usr/lib/system/libsystem_featureflags.dylib
    0x7fff203a9000 -     0x7fff20431fff  libsystem_c.dylib (1439.141.1) <BC8BCEEA-CA52-32C7-9FF5-E444CF9EF66A> /usr/lib/system/libsystem_c.dylib
    0x7fff20432000 -     0x7fff20487fff  libc++.1.dylib (905.6) <5BA6B5ED-7842-3B13-86B0-00EB511CE2FE> /usr/lib/libc++.1.dylib
    0x7fff20488000 -     0x7fff2049dfff  libc++abi.dylib (905.6) <B96FC1DD-0056-3E11-862A-C0BB8239FEA0> /usr/lib/libc++abi.dylib
    0x7fff2049e000 -     0x7fff204cdfff  libsystem_kernel.dylib (7195.141.49.701.3) <D2E4554A-FBB6-3AD0-AA55-AABDD4F52E55> /usr/lib/system/libsystem_kernel.dylib
    0x7fff204ce000 -     0x7fff204d9fff  libsystem_pthread.dylib (454.120.2.700.1) <409239A7-2E4E-31C7-87EB-EE50B7981204> /usr/lib/system/libsystem_pthread.dylib
    0x7fff204da000 -     0x7fff20515fff  libdyld.dylib (852.2) <FD8DB5BC-F199-3524-9DC4-DAEC0E94712F> /usr/lib/system/libdyld.dylib
    0x7fff20516000 -     0x7fff2051ffff  libsystem_platform.dylib (254.80.2) <52A77346-8AA5-3BB7-906D-C7503B491CF9> /usr/lib/system/libsystem_platform.dylib
    0x7fff20520000 -     0x7fff2054bfff  libsystem_info.dylib (542.40.4) <406353B2-E48A-3D20-B08F-0AB26ED8A0B3> /usr/lib/system/libsystem_info.dylib
    0x7fff2054c000 -     0x7fff209e9fff  com.apple.CoreFoundation (6.9 - 1778.105) <B4B8042A-9415-3F26-91AC-735C968B0D95> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
    0x7fff209ea000 -     0x7fff20c21fff  com.apple.LaunchServices (1122.45 - 1122.45) <3FFE90CC-F4A8-39AF-B478-01E7FF2A520B> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
    0x7fff20c22000 -     0x7fff20cf6fff  com.apple.gpusw.MetalTools (1.0 - 1) <72285C8A-5F98-31A0-9CA1-30CF4387584B> /System/Library/PrivateFrameworks/MetalTools.framework/Versions/A/MetalTools
    0x7fff20cf7000 -     0x7fff20f53fff  libBLAS.dylib (1336.140.1) <D4B16233-BAE7-3D63-BB59-5DCEC63345EB> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
    0x7fff20f54000 -     0x7fff20fa1fff  com.apple.Lexicon-framework (1.0 - 86.2) <09EC8AE4-7FC7-3D2D-A6DD-C484B664B1D5> /System/Library/PrivateFrameworks/Lexicon.framework/Versions/A/Lexicon
    0x7fff20fa2000 -     0x7fff21010fff  libSparse.dylib (106) <0FD77742-B7DB-3296-9D0F-0DEF7EB4FF7D> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparse.dylib
    0x7fff21011000 -     0x7fff2108efff  com.apple.SystemConfiguration (1.20 - 1.20) <D59BEA1F-BD5D-383A-8977-64F5B72F16C4> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
    0x7fff2108f000 -     0x7fff210c3fff  libCRFSuite.dylib (50) <2DADF4F9-0BD3-33CF-9939-979E69F2453C> /usr/lib/libCRFSuite.dylib
    0x7fff210c4000 -     0x7fff212fcfff  libmecabra.dylib (929.10) <58AA4922-A668-3165-802C-5FB4DF848E40> /usr/lib/libmecabra.dylib
    0x7fff212fd000 -     0x7fff2165bfff  com.apple.Foundation (6.9 - 1778.105) <4F4709DD-C198-3AA1-86A0-71D2F2FDD65D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
    0x7fff2165c000 -     0x7fff21744fff  com.apple.LanguageModeling (1.0 - 247.3) <EAAF99AF-2D5F-3EC5-B7F7-41D7236A09F3> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
    0x7fff21745000 -     0x7fff2187bfff  com.apple.CoreDisplay (237.4 - 237.4) <CDD47724-D213-3665-BD34-A51F374AE94F> /System/Library/Frameworks/CoreDisplay.framework/Versions/A/CoreDisplay
    0x7fff2187c000 -     0x7fff21aecfff  com.apple.audio.AudioToolboxCore (1.0 - 1181.72.5) <541A108B-D52C-3F7B-B004-F31E16243BAF> /System/Library/PrivateFrameworks/AudioToolboxCore.framework/Versions/A/AudioToolboxCore
    0x7fff21aed000 -     0x7fff21cd2fff  com.apple.CoreText (677.6.0.4 - 677.6.0.4) <1E81E372-02B3-3E9C-BB48-33DC80E49158> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
    0x7fff21cd3000 -     0x7fff22364fff  com.apple.audio.CoreAudio (5.0 - 5.0) <A5ED9C97-E177-388F-AED8-D760C6963377> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
    0x7fff22365000 -     0x7fff226bcfff  com.apple.security (7.0 - 59754.141.1.701.2) <D4C990E4-874C-3B6D-8D8B-E62AB749F7F5> /System/Library/Frameworks/Security.framework/Versions/A/Security
    0x7fff226bd000 -     0x7fff2291cfff  libicucore.A.dylib (66112.1) <9F2A881A-25DA-3386-9DCE-D2B67C2A4141> /usr/lib/libicucore.A.dylib
    0x7fff2291d000 -     0x7fff22926fff  libsystem_darwin.dylib (1439.141.1) <75592BEC-777B-381F-8C07-15B8A4C712A7> /usr/lib/system/libsystem_darwin.dylib
    0x7fff22927000 -     0x7fff22c12fff  com.apple.CoreServices.CarbonCore (1307.3 - 1307.3) <76566083-9F9C-3055-812A-079693A69D32> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
    0x7fff22c13000 -     0x7fff22c51fff  com.apple.CoreServicesInternal (476.1.1 - 476.1.1) <86274AF8-B5F9-3BD3-A286-4E6E104DDB4D> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
    0x7fff22c52000 -     0x7fff22c8cfff  com.apple.CSStore (1122.45 - 1122.45) <9031093C-453F-3321-B662-2E42A15F3546> /System/Library/PrivateFrameworks/CoreServicesStore.framework/Versions/A/CoreServicesStore
    0x7fff22c8d000 -     0x7fff22d3bfff  com.apple.framework.IOKit (2.0.2 - 1845.120.6) <A395F442-1253-3CA9-953F-7A235EEB7F67> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
    0x7fff22d3c000 -     0x7fff22d47fff  libsystem_notify.dylib (279.40.4) <02E22D9D-01E2-361C-BB9A-B5BE18D28280> /usr/lib/system/libsystem_notify.dylib
    0x7fff22d48000 -     0x7fff22d95fff  libsandbox.1.dylib (1441.141.13.701.2) <2980861C-F66B-362A-A4FA-5DFF811495A8> /usr/lib/libsandbox.1.dylib
    0x7fff22d96000 -     0x7fff23ae1fff  com.apple.AppKit (6.9 - 2022.70.111) <5C4B04E9-1056-3B1A-9C2D-B149A6E107B9> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
    0x7fff23ae2000 -     0x7fff23d30fff  com.apple.UIFoundation (1.0 - 729) <55B6D90D-A0ED-38D7-B858-1068A31C1C09> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
    0x7fff23d31000 -     0x7fff23d43fff  com.apple.UniformTypeIdentifiers (637 - 637) <F59AD9D8-0FBF-303E-9F14-5F7213E5488E> /System/Library/Frameworks/UniformTypeIdentifiers.framework/Versions/A/UniformTypeIdentifiers
    0x7fff23d44000 -     0x7fff23ecefff  com.apple.desktopservices (1.21 - 1346.6.1) <CC3C6040-8A52-3BF9-8E70-92F71F6A3E45> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
    0x7fff23ee2000 -     0x7fff240f0fff  com.apple.CoreDuet (1.0 - 1) <102D2F72-2F9C-38F5-80E1-49C201300A5F> /System/Library/PrivateFrameworks/CoreDuet.framework/Versions/A/CoreDuet
    0x7fff240f1000 -     0x7fff241adfff  libboringssl.dylib (351.140.2) <73F497D7-516F-302A-9A41-B5964EE7B31E> /usr/lib/libboringssl.dylib
    0x7fff241ae000 -     0x7fff24834fff  libnetwork.dylib (2288.140.9) <2DE517EE-E318-366B-A7FA-AD5F62D007CB> /usr/lib/libnetwork.dylib
    0x7fff24835000 -     0x7fff24cd4fff  com.apple.CFNetwork (1240.0.4.3 - 1240.0.4.3) <2496F861-924B-35B8-A39F-B887C19705B9> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
    0x7fff24cd5000 -     0x7fff24ce3fff  libsystem_networkextension.dylib (1295.140.4.701.1) <9C5A85AC-C593-34FD-8481-5CFC05DE3897> /usr/lib/system/libsystem_networkextension.dylib
    0x7fff24ce4000 -     0x7fff24ce4fff  libenergytrace.dylib (22.100.1) <EDE247D7-22AC-3339-AC3E-04A5BD13E3F2> /usr/lib/libenergytrace.dylib
    0x7fff24ce5000 -     0x7fff24d41fff  libMobileGestalt.dylib (978.140.1) <D95EDD2B-F269-35E2-A39E-6FF6318BD1C1> /usr/lib/libMobileGestalt.dylib
    0x7fff24d42000 -     0x7fff24d58fff  libsystem_asl.dylib (385.0.2) <88F4051D-1CF5-314E-A952-247C38996E16> /usr/lib/system/libsystem_asl.dylib
    0x7fff24d59000 -     0x7fff24d71fff  com.apple.TCC (1.0 - 1) <898C8BE6-EBC0-3BEB-B898-2EF336802530> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
    0x7fff24d72000 -     0x7fff250d7fff  com.apple.SkyLight (1.600.0 - 588.10) <78FFC855-8FB8-300B-878C-174F019DBA94> /System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/SkyLight
    0x7fff250d8000 -     0x7fff25761fff  com.apple.CoreGraphics (2.0 - 1463.19.1) <C911B812-7401-3EAF-B365-A9B7B98B708A> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
    0x7fff25762000 -     0x7fff25859fff  com.apple.ColorSync (4.13.0 - 3473.8.1) <B66E5ABE-B72B-3607-8FB6-3CE54142829A> /System/Library/Frameworks/ColorSync.framework/Versions/A/ColorSync
    0x7fff2585a000 -     0x7fff258b5fff  com.apple.HIServices (1.22 - 716) <76A6ECCF-9098-3A1F-A80B-40408A9AA4A5> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
    0x7fff25c5c000 -     0x7fff2607bfff  com.apple.CoreData (120 - 1048) <6D7D0B7E-7646-3F79-8108-0C1D11821749> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
    0x7fff2607c000 -     0x7fff26091fff  com.apple.ProtocolBuffer (1 - 285.24.10.20.1) <6EC4B8BC-C44A-3211-A0B5-A7298518231B> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
    0x7fff26092000 -     0x7fff26245fff  libsqlite3.dylib (321.3) <8F485B58-8440-310F-9F08-60AACABBBDC1> /usr/lib/libsqlite3.dylib
    0x7fff26246000 -     0x7fff262c2fff  com.apple.Accounts (113 - 113) <1021C0F9-F834-33DB-A66D-EE4391C58740> /System/Library/Frameworks/Accounts.framework/Versions/A/Accounts
    0x7fff262c3000 -     0x7fff262dafff  com.apple.commonutilities (8.0 - 900) <4D28711F-3425-31EB-A9D5-3FA489461EA3> /System/Library/PrivateFrameworks/CommonUtilities.framework/Versions/A/CommonUtilities
    0x7fff262db000 -     0x7fff2635afff  com.apple.BaseBoard (526 - 526) <8ABD1C28-584C-33E7-8BE8-4EFC5EEF1575> /System/Library/PrivateFrameworks/BaseBoard.framework/Versions/A/BaseBoard
    0x7fff2635b000 -     0x7fff263a3fff  com.apple.RunningBoardServices (1.0 - 505.100.9) <BE0AEF0C-A31A-32F1-8157-9560A1A24633> /System/Library/PrivateFrameworks/RunningBoardServices.framework/Versions/A/RunningBoardServices
    0x7fff263a4000 -     0x7fff26418fff  com.apple.AE (918.6 - 918.6) <D2A72117-7C81-33AF-BE98-7B73037CFBA7> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
    0x7fff26419000 -     0x7fff2641ffff  libdns_services.dylib (1310.140.1) <EABE9A6A-96DE-3A2E-B0E0-17F277A65757> /usr/lib/libdns_services.dylib
    0x7fff26420000 -     0x7fff26427fff  libsystem_symptoms.dylib (1431.140.1) <E9CB193F-260B-3835-B76E-A2209343FA1E> /usr/lib/system/libsystem_symptoms.dylib
    0x7fff26428000 -     0x7fff265b3fff  com.apple.Network (1.0 - 1) <6A3C9CBC-DE8E-3D0A-BA52-316E70255DCD> /System/Library/Frameworks/Network.framework/Versions/A/Network
    0x7fff265b4000 -     0x7fff265e3fff  com.apple.analyticsd (1.0 - 1) <88A76CB5-2ACF-32C3-89AA-A06636C06957> /System/Library/PrivateFrameworks/CoreAnalytics.framework/Versions/A/CoreAnalytics
    0x7fff265e4000 -     0x7fff265e6fff  libDiagnosticMessagesClient.dylib (112) <8CE0D64A-597F-3048-80C3-590D866D067A> /usr/lib/libDiagnosticMessagesClient.dylib
    0x7fff265e7000 -     0x7fff26633fff  com.apple.spotlight.metadata.utilities (1.0 - 2150.29) <88322A2A-3DDD-35E0-A95C-54F4D5693191> /System/Library/PrivateFrameworks/MetadataUtilities.framework/Versions/A/MetadataUtilities
    0x7fff26634000 -     0x7fff266cefff  com.apple.Metadata (10.7.0 - 2150.29) <0ABF8F88-B7D4-3787-9779-624B53D01702> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
    0x7fff266cf000 -     0x7fff266d5fff  com.apple.DiskArbitration (2.7 - 2.7) <21325211-A5F7-3AB9-BDFE-6B6DC06E587E> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
    0x7fff266d6000 -     0x7fff26d3dfff  com.apple.vImage (8.1 - 544.6) <1DD123D7-ACC3-3FCB-838E-C91C6E4D31B8> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
    0x7fff26d3e000 -     0x7fff2701bfff  com.apple.QuartzCore (1.11 - 927.24) <C2F144F0-B972-390B-B0DC-51B79F3B4DF2> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
    0x7fff2701c000 -     0x7fff2705dfff  libFontRegistry.dylib (309.0.0.2) <D13D1774-9FC2-3A3B-BFD0-8ABFAF9AE1E0> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
    0x7fff2705e000 -     0x7fff2719efff  com.apple.coreui (2.1 - 692.1) <AEA9DF7F-4E7E-3D39-9DBF-55276520B97C> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
    0x7fff2719f000 -     0x7fff2728afff  com.apple.ViewBridge (553.1 - 553.1) <AC1840D6-7482-385E-ABDF-5BE8DC38C612> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
    0x7fff2728b000 -     0x7fff27296fff  com.apple.PerformanceAnalysis (1.278.3 - 278.3) <24DDF51B-8405-30AF-9879-5172C325BF0C> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
    0x7fff27297000 -     0x7fff272a6fff  com.apple.OpenDirectory (11.7 - 230.40.1) <B7BB547E-B00F-37B3-A4A8-AF414F029E64> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
    0x7fff272a7000 -     0x7fff272c6fff  com.apple.CFOpenDirectory (11.7 - 230.40.1) <E4682D99-DD7C-3C74-A0A1-E561B6E616C6> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
    0x7fff272c7000 -     0x7fff272d3fff  com.apple.CoreServices.FSEvents (1290.120.6 - 1290.120.6) <78184C84-4633-3867-AACD-8F0256F40D5A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents
    0x7fff272d4000 -     0x7fff272f8fff  com.apple.coreservices.SharedFileList (144 - 144) <243CAB7D-EA1A-3322-9833-B4B24F63AB3E> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.framework/Versions/A/SharedFileList
    0x7fff272f9000 -     0x7fff272fbfff  libapp_launch_measurement.dylib (14.1) <2AE731D8-757E-3A23-8375-9D266B762CC3> /usr/lib/libapp_launch_measurement.dylib
    0x7fff272fc000 -     0x7fff27343fff  com.apple.CoreAutoLayout (1.0 - 21.10.1) <32846C89-8FED-3225-B370-34FB1DA82A85> /System/Library/PrivateFrameworks/CoreAutoLayout.framework/Versions/A/CoreAutoLayout
    0x7fff27344000 -     0x7fff27426fff  libxml2.2.dylib (34.24) <E503070F-8944-3BF9-B4CC-09E891FF0BF1> /usr/lib/libxml2.2.dylib
    0x7fff27427000 -     0x7fff27474fff  com.apple.CoreVideo (1.8 - 0.0) <FE8A9F52-4140-36D8-BE09-800E75857EAD> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
    0x7fff27475000 -     0x7fff27477fff  com.apple.loginsupport (1.0 - 1) <FF0F8335-44A1-30C6-A005-5B50FAEC72CF> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport
    0x7fff27478000 -     0x7fff2749ffff  com.apple.aps.framework (4.0 - 4.0) <AB586FD6-9C10-323B-A585-DCB42153B8E2> /System/Library/PrivateFrameworks/ApplePushService.framework/Versions/A/ApplePushService
    0x7fff274a0000 -     0x7fff274bbfff  com.apple.UserManagement (1.0 - 1) <DCDC3E80-E995-3091-A68C-957984CB100B> /System/Library/PrivateFrameworks/UserManagement.framework/Versions/A/UserManagement
    0x7fff274bc000 -     0x7fff2764dfff  com.apple.cloudkit.CloudKit (990 - 990) <732C028A-288F-3DCB-AE2A-591E60F0D5C8> /System/Library/Frameworks/CloudKit.framework/Versions/A/CloudKit
    0x7fff283b2000 -     0x7fff2842efff  com.apple.corelocation (2420.19.23 - 2420.19.23) <958D7B80-9E0B-31A4-A5ED-DCB20F4A571C> /System/Library/Frameworks/CoreLocation.framework/Versions/A/CoreLocation
    0x7fff2842f000 -     0x7fff2843ffff  libsystem_containermanager.dylib (318.100.4.700.1) <45445167-AFC7-3406-A858-9AE8D8F45907> /usr/lib/system/libsystem_containermanager.dylib
    0x7fff28440000 -     0x7fff28451fff  com.apple.IOSurface (290.8.2 - 290.8.2) <B98B7126-FFF8-343F-BE66-32212DE3BEBE> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
    0x7fff28452000 -     0x7fff2845bfff  com.apple.IOAccelerator (442.10 - 442.10) <19FBA808-F918-3BB2-BE78-A1B0D10D724D> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
    0x7fff2845c000 -     0x7fff2857ffff  com.apple.Metal (244.303 - 244.303) <A9397F90-E221-397B-BA10-B52135A72D68> /System/Library/Frameworks/Metal.framework/Versions/A/Metal
    0x7fff28580000 -     0x7fff2859cfff  com.apple.audio.caulk (1.0 - 70) <A8D1B95D-91AF-3FF5-9CD7-93661045C83A> /System/Library/PrivateFrameworks/caulk.framework/Versions/A/caulk
    0x7fff2859d000 -     0x7fff28687fff  com.apple.CoreMedia (1.0 - 2780.10.4.1.1) <237F9A0B-FE1F-3E4D-BE4D-8E27989EA845> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
    0x7fff28688000 -     0x7fff287e4fff  libFontParser.dylib (305.6.0.5) <5FCE9223-2698-31E9-847E-5830294FCE85> /System/Library/PrivateFrameworks/FontServices.framework/libFontParser.dylib
    0x7fff287e5000 -     0x7fff28ae0fff  com.apple.HIToolbox (2.1.1 - 1062) <621A473B-BE8A-3381-970A-25F253BE208A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
    0x7fff28ae1000 -     0x7fff28af4fff  com.apple.framework.DFRFoundation (1.0 - 267) <C10A9E83-76B8-35E7-9604-F29855DD76D8> /System/Library/PrivateFrameworks/DFRFoundation.framework/Versions/A/DFRFoundation
    0x7fff28af5000 -     0x7fff28af8fff  com.apple.dt.XCTTargetBootstrap (1.0 - 18119.2) <41D5117E-E262-3638-B01E-494487E7DB39> /System/Library/PrivateFrameworks/XCTTargetBootstrap.framework/Versions/A/XCTTargetBootstrap
    0x7fff28af9000 -     0x7fff28b22fff  com.apple.CoreSVG (1.0 - 149) <6215F1BD-17B3-3B6E-8FB1-3C0AD5AD3C26> /System/Library/PrivateFrameworks/CoreSVG.framework/Versions/A/CoreSVG
    0x7fff28b23000 -     0x7fff28d60fff  com.apple.ImageIO (3.3.0 - 2130.15.1) <7517CFA5-A440-385C-8B8B-BC2D9D71B0D1> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
    0x7fff28d61000 -     0x7fff290dcfff  com.apple.CoreImage (16.3.0 - 1140.2) <3C2DE86C-89FA-3EC1-ACFE-6BE95F54B123> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
    0x7fff290dd000 -     0x7fff29143fff  com.apple.MetalPerformanceShaders.MPSCore (1.0 - 1) <02F2E0C6-0C0F-3390-A63B-189832967015> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/Frameworks/MPSCore.framework/Versions/A/MPSCore
    0x7fff29144000 -     0x7fff29147fff  libsystem_configuration.dylib (1109.140.1) <53B71513-3009-3A8C-A5AA-9C15DD0AB54E> /usr/lib/system/libsystem_configuration.dylib
    0x7fff29148000 -     0x7fff2914cfff  libsystem_sandbox.dylib (1441.141.13.701.2) <1E19BC49-484C-32BB-8BB7-99D41C63F86E> /usr/lib/system/libsystem_sandbox.dylib
    0x7fff2914d000 -     0x7fff2914efff  com.apple.AggregateDictionary (1.0 - 1) <CD5E6E8F-7AB6-345E-9243-D5D674DC0225> /System/Library/PrivateFrameworks/AggregateDictionary.framework/Versions/A/AggregateDictionary
    0x7fff2914f000 -     0x7fff29152fff  com.apple.AppleSystemInfo (3.1.5 - 3.1.5) <15CBB967-FAAE-3A22-A87F-4833A9D835E3> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo
    0x7fff29153000 -     0x7fff29154fff  liblangid.dylib (136) <D6DDBEB6-7A9A-3F00-8DEF-18934CFC0A08> /usr/lib/liblangid.dylib
    0x7fff29155000 -     0x7fff291f9fff  com.apple.CoreNLP (1.0 - 245.2) <F40C2289-9A6D-3C55-A6DA-FFAD41636415> /System/Library/PrivateFrameworks/CoreNLP.framework/Versions/A/CoreNLP
    0x7fff291fa000 -     0x7fff29200fff  com.apple.LinguisticData (1.0 - 399) <E6DC793D-3133-3D9B-BCF8-E4A628E45586> /System/Library/PrivateFrameworks/LinguisticData.framework/Versions/A/LinguisticData
    0x7fff29201000 -     0x7fff298a9fff  libBNNS.dylib (288.100.5) <1E45AC70-6C75-3F27-9252-40DF6B2D674A> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBNNS.dylib
    0x7fff298aa000 -     0x7fff29a7cfff  libvDSP.dylib (760.100.3) <7F1276C0-C9F6-3C6F-A0F7-1EB4EA666BD8> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
    0x7fff29a7d000 -     0x7fff29a8efff  com.apple.CoreEmoji (1.0 - 128.4) <011AA15B-6988-3F36-81A3-2B52B561D6E0> /System/Library/PrivateFrameworks/CoreEmoji.framework/Versions/A/CoreEmoji
    0x7fff29a8f000 -     0x7fff29a99fff  com.apple.IOMobileFramebuffer (343.0.0 - 343.0.0) <28991DA2-1726-3F77-A9C5-4BB5AAEFA166> /System/Library/PrivateFrameworks/IOMobileFramebuffer.framework/Versions/A/IOMobileFramebuffer
    0x7fff29a9a000 -     0x7fff29b6cfff  com.apple.framework.CoreWLAN (16.0 - 1657) <6502460E-673A-348D-A129-2F833524D58F> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
    0x7fff29b6d000 -     0x7fff29d6efff  com.apple.CoreUtils (6.6 - 660.37) <035AE42A-2786-3FD8-9C93-167988643972> /System/Library/PrivateFrameworks/CoreUtils.framework/Versions/A/CoreUtils
    0x7fff29d6f000 -     0x7fff29d91fff  com.apple.MobileKeyBag (2.0 - 1.0) <104A49DA-4F43-3D53-B537-F28E10F0C4E4> /System/Library/PrivateFrameworks/MobileKeyBag.framework/Versions/A/MobileKeyBag
    0x7fff29d92000 -     0x7fff29da2fff  com.apple.AssertionServices (1.0 - 505.100.9) <1B805E53-D42F-3019-88F0-64D3BD287DDB> /System/Library/PrivateFrameworks/AssertionServices.framework/Versions/A/AssertionServices
    0x7fff29da3000 -     0x7fff29e2efff  com.apple.securityfoundation (6.0 - 55240.40.4) <4ABC6EAE-13DA-3F86-AE2D-86F64B034C7D> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
    0x7fff29e2f000 -     0x7fff29e38fff  com.apple.coreservices.BackgroundTaskManagement (1.0 - 104) <8CF5B495-3026-3CE1-9EFC-8D7D71380A43> /System/Library/PrivateFrameworks/BackgroundTaskManagement.framework/Versions/A/BackgroundTaskManagement
    0x7fff29e39000 -     0x7fff29e3dfff  com.apple.xpc.ServiceManagement (1.0 - 1) <B6694E37-991A-3C64-A0B6-4F465DF39C14> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
    0x7fff29e3e000 -     0x7fff29e40fff  libquarantine.dylib (119.40.4) <21C63859-6DFB-3463-9ADF-BB44FB28067C> /usr/lib/system/libquarantine.dylib
    0x7fff29e41000 -     0x7fff29e4cfff  libCheckFix.dylib (31) <3D9AE153-2087-36F9-B6FB-CBCD4AFE3D5C> /usr/lib/libCheckFix.dylib
    0x7fff29e4d000 -     0x7fff29e64fff  libcoretls.dylib (169.100.1) <FC8265A0-9659-35D9-BA6F-6507A44742FE> /usr/lib/libcoretls.dylib
    0x7fff29e65000 -     0x7fff29e75fff  libbsm.0.dylib (68.40.1) <0CF67F8A-268D-320A-A3A4-D7C2D9AB8027> /usr/lib/libbsm.0.dylib
    0x7fff29e76000 -     0x7fff29ebffff  libmecab.dylib (929.10) <47A982DF-1436-366E-AC45-1DA068832AED> /usr/lib/libmecab.dylib
    0x7fff29ec0000 -     0x7fff29ec5fff  libgermantok.dylib (24) <189F508A-723B-345D-918F-178CF15077F3> /usr/lib/libgermantok.dylib
    0x7fff29ec6000 -     0x7fff29edbfff  libLinearAlgebra.dylib (1336.140.1) <27358E5F-256F-309F-AAC8-BAC4A56C7BF4> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib
    0x7fff29edc000 -     0x7fff2a0fafff  com.apple.MetalPerformanceShaders.MPSNeuralNetwork (1.0 - 1) <B7F8218A-2DA2-35A4-9200-3BD52CCF125C> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/Frameworks/MPSNeuralNetwork.framework/Versions/A/MPSNeuralNetwork
    0x7fff2a0fb000 -     0x7fff2a14afff  com.apple.MetalPerformanceShaders.MPSRayIntersector (1.0 - 1) <3993AC67-62B4-3E49-B5BF-E8F814CE6C97> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/Frameworks/MPSRayIntersector.framework/Versions/A/MPSRayIntersector
    0x7fff2a14b000 -     0x7fff2a2acfff  com.apple.MLCompute (1.0 - 1) <6026D664-0453-321F-81FE-A40AD902849E> /System/Library/Frameworks/MLCompute.framework/Versions/A/MLCompute
    0x7fff2a2ad000 -     0x7fff2a2e3fff  com.apple.MetalPerformanceShaders.MPSMatrix (1.0 - 1) <A194A321-8DD9-3051-97EC-3C4630946007> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/Frameworks/MPSMatrix.framework/Versions/A/MPSMatrix
    0x7fff2a2e4000 -     0x7fff2a33afff  com.apple.MetalPerformanceShaders.MPSNDArray (1.0 - 1) <A72429D4-3BED-34DD-BEDE-322A0975A8BC> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/Frameworks/MPSNDArray.framework/Versions/A/MPSNDArray
    0x7fff2a33b000 -     0x7fff2a3cbfff  com.apple.MetalPerformanceShaders.MPSImage (1.0 - 1) <0B333F06-FAD5-3689-9017-15334AD4F51C> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/Frameworks/MPSImage.framework/Versions/A/MPSImage
    0x7fff2a3cc000 -     0x7fff2a3dbfff  com.apple.AppleFSCompression (125 - 1.0) <1C5279EE-8F78-386E-9E4D-24A3785CACA2> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression
    0x7fff2a3dc000 -     0x7fff2a3e8fff  libbz2.1.0.dylib (44) <6E82D414-3810-36CF-94FF-B1BDF48DB501> /usr/lib/libbz2.1.0.dylib
    0x7fff2a3e9000 -     0x7fff2a3edfff  libsystem_coreservices.dylib (127.1) <6D84FA08-CB2B-34E1-9AB4-A54E82CB9161> /usr/lib/system/libsystem_coreservices.dylib
    0x7fff2a3ee000 -     0x7fff2a41bfff  com.apple.CoreServices.OSServices (1122.45 - 1122.45) <872BCC1C-6A21-3539-A41B-12EBFD808972> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
    0x7fff2a41c000 -     0x7fff2a54bfff  com.apple.AuthKit (1.0 - 1) <C678E6CB-DAE9-3AD0-9AA2-9D192426C184> /System/Library/PrivateFrameworks/AuthKit.framework/Versions/A/AuthKit
    0x7fff2a5ea000 -     0x7fff2a5fcfff  libz.1.dylib (76.140.1) <A2FF8D14-1632-3047-9829-CC90239F97FF> /usr/lib/libz.1.dylib
    0x7fff2a5fd000 -     0x7fff2a644fff  libsystem_m.dylib (3186.100.3) <1836B380-C579-3195-BC3F-77404D432186> /usr/lib/system/libsystem_m.dylib
    0x7fff2a645000 -     0x7fff2a645fff  libcharset.1.dylib (59) <3A46C22D-E678-356B-9BAD-6E837704D662> /usr/lib/libcharset.1.dylib
    0x7fff2a646000 -     0x7fff2a64bfff  libmacho.dylib (980) <F7BDAFE5-4E49-39DD-8F94-CD5E49C91A90> /usr/lib/system/libmacho.dylib
    0x7fff2a64c000 -     0x7fff2a667fff  libkxld.dylib (7195.141.49.701.3) <93417300-BD7C-3CDD-9581-873131288A41> /usr/lib/system/libkxld.dylib
    0x7fff2a668000 -     0x7fff2a673fff  libcommonCrypto.dylib (60178.120.3) <B057F752-3057-394D-A3F6-AA11A04A6392> /usr/lib/system/libcommonCrypto.dylib
    0x7fff2a674000 -     0x7fff2a67efff  libunwind.dylib (201) <9D6A6228-8DC3-3521-B458-4EDE4A9F5E65> /usr/lib/system/libunwind.dylib
    0x7fff2a67f000 -     0x7fff2a686fff  liboah.dylib (203.58) <AC9E8A76-FCAA-3F97-802A-D22EF770463B> /usr/lib/liboah.dylib
    0x7fff2a687000 -     0x7fff2a691fff  libcopyfile.dylib (173.40.2) <BD7EAE7B-28C1-36DF-96B8-F506D50DFF28> /usr/lib/system/libcopyfile.dylib
    0x7fff2a692000 -     0x7fff2a699fff  libcompiler_rt.dylib (102.2) <BA910DC2-C697-3DAD-9A70-7C8CD5217AC3> /usr/lib/system/libcompiler_rt.dylib
    0x7fff2a69a000 -     0x7fff2a69cfff  libsystem_collections.dylib (1439.141.1) <21F2EF42-56ED-3E0F-9C29-94E0888DC52C> /usr/lib/system/libsystem_collections.dylib
    0x7fff2a69d000 -     0x7fff2a69ffff  libsystem_secinit.dylib (87.60.1) <E976428F-F9E2-334B-AA91-9AAD40234718> /usr/lib/system/libsystem_secinit.dylib
    0x7fff2a6a0000 -     0x7fff2a6a2fff  libremovefile.dylib (49.120.1) <5AC9F8EC-F0E8-3D8A-ADB5-96B5FB581896> /usr/lib/system/libremovefile.dylib
    0x7fff2a6a3000 -     0x7fff2a6a3fff  libkeymgr.dylib (31) <9FBE08F6-0679-3976-AFDC-1EAF40C3958F> /usr/lib/system/libkeymgr.dylib
    0x7fff2a6a4000 -     0x7fff2a6abfff  libsystem_dnssd.dylib (1310.140.1) <8C4D6C93-285F-3587-A986-5BB96A1C664F> /usr/lib/system/libsystem_dnssd.dylib
    0x7fff2a6ac000 -     0x7fff2a6b1fff  libcache.dylib (83) <56DCEFF5-111E-32FD-B4E9-E148507C4FEC> /usr/lib/system/libcache.dylib
    0x7fff2a6b2000 -     0x7fff2a6b3fff  libSystem.B.dylib (1292.120.1) <96E71ED1-0206-3EB1-A67C-CE44C0D0725E> /usr/lib/libSystem.B.dylib
    0x7fff2a6b4000 -     0x7fff2a6b7fff  libfakelink.dylib (3) <6002BC93-3627-366E-8D21-A552D56CB215> /usr/lib/libfakelink.dylib
    0x7fff2a6b8000 -     0x7fff2a6b8fff  com.apple.SoftLinking (1.0 - 1) <3D0CEDFD-B263-39CA-8B31-E0A498D05EB3> /System/Library/PrivateFrameworks/SoftLinking.framework/Versions/A/SoftLinking
    0x7fff2a6b9000 -     0x7fff2a6f0fff  libpcap.A.dylib (98.100.3) <236EE73F-6D38-38E0-9BC0-B427DEB7F9FD> /usr/lib/libpcap.A.dylib
    0x7fff2a6f1000 -     0x7fff2a7e1fff  libiconv.2.dylib (59) <DEE0153A-BDF9-33CA-B8C7-3C39DB906B5E> /usr/lib/libiconv.2.dylib
    0x7fff2a7e2000 -     0x7fff2a7f3fff  libcmph.dylib (8) <83A69507-07D1-387F-9D06-1011E7909EAC> /usr/lib/libcmph.dylib
    0x7fff2a7f4000 -     0x7fff2a865fff  libarchive.2.dylib (83.100.2) <45B577F5-0064-3E73-89B8-BE4A121B214F> /usr/lib/libarchive.2.dylib
    0x7fff2a866000 -     0x7fff2a8cdfff  com.apple.SearchKit (1.4.1 - 1.4.1) <7C264603-379D-38BF-A3EC-49C01059C5E5> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
    0x7fff2a8ce000 -     0x7fff2a8cffff  libThaiTokenizer.dylib (3) <BA265C01-176E-3F7D-97F6-7FAABB0CAEC8> /usr/lib/libThaiTokenizer.dylib
    0x7fff2a8d0000 -     0x7fff2a8f2fff  com.apple.applesauce (1.0 - 16.28) <EAFF4FEC-51F3-3D0D-9D99-E62E75937F1B> /System/Library/PrivateFrameworks/AppleSauce.framework/Versions/A/AppleSauce
    0x7fff2a8f3000 -     0x7fff2a90afff  libapple_nghttp2.dylib (1.41) <AC9520D7-D54F-3031-9503-FEA5A5ED5E56> /usr/lib/libapple_nghttp2.dylib
    0x7fff2a90b000 -     0x7fff2a921fff  libSparseBLAS.dylib (1336.140.1) <7D926256-F187-33CA-87D6-74F1660C438A> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparseBLAS.dylib
    0x7fff2a922000 -     0x7fff2a923fff  com.apple.MetalPerformanceShaders.MetalPerformanceShaders (1.0 - 1) <9BFE310E-E910-3228-BDF5-21A7C4468D89> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/MetalPerformanceShaders
    0x7fff2a924000 -     0x7fff2a928fff  libpam.2.dylib (28.40.1) <C851B25F-835B-3543-A93F-4EAA521DDC34> /usr/lib/libpam.2.dylib
    0x7fff2a929000 -     0x7fff2a948fff  libcompression.dylib (96.120.1) <F36054C1-6074-3A22-82EF-6F4A2A52599C> /usr/lib/libcompression.dylib
    0x7fff2a949000 -     0x7fff2a94efff  libQuadrature.dylib (7) <256CB21E-2878-3F22-B4B5-E1FB60D64C9E> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libQuadrature.dylib
    0x7fff2a94f000 -     0x7fff2acecfff  libLAPACK.dylib (1336.140.1) <02F2D4D1-8763-32D1-B5F9-9DD439EFC8E8> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
    0x7fff2aced000 -     0x7fff2ad3cfff  com.apple.DictionaryServices (1.2 - 341) <FB843860-C7D5-3060-B50E-303A3CBAE9A9> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
    0x7fff2ad3d000 -     0x7fff2ad55fff  liblzma.5.dylib (16) <455C9083-014D-3037-AC54-1395F3796734> /usr/lib/liblzma.5.dylib
    0x7fff2ad56000 -     0x7fff2ad57fff  libcoretls_cfhelpers.dylib (169.100.1) <6760D250-2628-3DA2-A8A4-6F438E09527A> /usr/lib/libcoretls_cfhelpers.dylib
    0x7fff2ad58000 -     0x7fff2ae53fff  com.apple.APFS (1677.141.3 - 1677.141.3) <E4B0DF0F-E1A5-3FEF-A2A6-8105AD54D95A> /System/Library/PrivateFrameworks/APFS.framework/Versions/A/APFS
    0x7fff2ae54000 -     0x7fff2ae62fff  libxar.1.dylib (452.140.1) <9E460111-1BBC-31FE-8CAF-FA8AEC22C1E9> /usr/lib/libxar.1.dylib
    0x7fff2ae63000 -     0x7fff2ae66fff  libutil.dylib (58.40.3) <B5961283-0856-3D78-AE9C-EAFB6A903569> /usr/lib/libutil.dylib
    0x7fff2ae67000 -     0x7fff2ae8ffff  libxslt.1.dylib (17.10) <52B300FD-B3F6-3689-9554-98B543A298C7> /usr/lib/libxslt.1.dylib
    0x7fff2ae90000 -     0x7fff2ae9afff  libChineseTokenizer.dylib (37.1) <62BC78D3-1400-3366-A04E-C8BEE6AC00B5> /usr/lib/libChineseTokenizer.dylib
    0x7fff2ae9b000 -     0x7fff2af58fff  libvMisc.dylib (760.100.3) <560739C2-D16B-36CA-89F4-BD4DD2192333> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
    0x7fff2af59000 -     0x7fff2aff0fff  libate.dylib (3.0.6) <CCD85C79-E892-339A-B0AB-E385D4F635F5> /usr/lib/libate.dylib
    0x7fff2aff1000 -     0x7fff2aff8fff  libIOReport.dylib (64.100.1) <0997845A-1FF3-35B3-A5ED-2FB16D07F624> /usr/lib/libIOReport.dylib
    0x7fff2aff9000 -     0x7fff2b00cfff  com.apple.CrashReporterSupport (10.13 - 15053.1) <146251D8-7623-3944-86B2-36EE47BD982E> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
    0x7fff2b00d000 -     0x7fff2b023fff  com.apple.AppSSOCore (1.0 - 1) <1D69DD90-FA97-353C-8FB2-D94A83FE4E4E> /System/Library/PrivateFrameworks/AppSSOCore.framework/Versions/A/AppSSOCore
    0x7fff2b0c3000 -     0x7fff2b0f9fff  com.apple.pluginkit.framework (1.0 - 1) <3A37B687-BDC8-315B-996D-7601E168DE47> /System/Library/PrivateFrameworks/PlugInKit.framework/Versions/A/PlugInKit
    0x7fff2b0fa000 -     0x7fff2b101fff  libMatch.1.dylib (38) <48FD1C03-C887-3052-9641-BF27E829577E> /usr/lib/libMatch.1.dylib
    0x7fff2b102000 -     0x7fff2b18dfff  libCoreStorage.dylib (554.140.2) <A8AC005D-0E07-33B5-B441-C0D208F740E8> /usr/lib/libCoreStorage.dylib
    0x7fff2b18e000 -     0x7fff2b1e1fff  com.apple.AppleVAFramework (6.1.3 - 6.1.3) <1D2A99E8-473C-3C56-BD50-98549FDC8932> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
    0x7fff2b1e2000 -     0x7fff2b1fbfff  libexpat.1.dylib (26.141.1) <0416D6BA-2AEB-3BBA-8584-FA28E62E8007> /usr/lib/libexpat.1.dylib
    0x7fff2b1fc000 -     0x7fff2b205fff  libheimdal-asn1.dylib (597.140.4) <60E659ED-BF63-3853-868D-D82D981AA955> /usr/lib/libheimdal-asn1.dylib
    0x7fff2b206000 -     0x7fff2b21afff  com.apple.IconFoundation (479.4 - 479.4) <71915E97-2F3E-36EE-B000-0EE7B258DD29> /System/Library/PrivateFrameworks/IconFoundation.framework/Versions/A/IconFoundation
    0x7fff2b21b000 -     0x7fff2b287fff  com.apple.IconServices (479.4 - 479.4) <C3E66299-D698-3AF5-B34D-D2782F91E106> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
    0x7fff2b288000 -     0x7fff2b326fff  com.apple.MediaExperience (1.0 - 1) <F5328457-1856-3DA3-B254-EC4FBBA7799F> /System/Library/PrivateFrameworks/MediaExperience.framework/Versions/A/MediaExperience
    0x7fff2b327000 -     0x7fff2b34ffff  com.apple.persistentconnection (1.0 - 1.0) <CF93C3EC-D1D1-3BAE-92B1-5D85A969F748> /System/Library/PrivateFrameworks/PersistentConnection.framework/Versions/A/PersistentConnection
    0x7fff2b350000 -     0x7fff2b35efff  com.apple.GraphVisualizer (1.0 - 100.1) <928039C0-8548-38A0-BBE9-6AA807CCE7B7> /System/Library/PrivateFrameworks/GraphVisualizer.framework/Versions/A/GraphVisualizer
    0x7fff2b35f000 -     0x7fff2b77afff  com.apple.vision.FaceCore (4.3.2 - 4.3.2) <13FFCD22-55DB-301B-9C6F-03C94266591B> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
    0x7fff2b77b000 -     0x7fff2b7c2fff  com.apple.OTSVG (1.0 - 677.6.0.4) <F89F3381-E8B0-3964-995E-6213AD6955B2> /System/Library/PrivateFrameworks/OTSVG.framework/Versions/A/OTSVG
    0x7fff2b7c3000 -     0x7fff2b7c9fff  com.apple.xpc.AppServerSupport (1.0 - 2038.120.1.700.2) <4528DEF8-B771-32D1-BA7E-5AA91ECDE448> /System/Library/PrivateFrameworks/AppServerSupport.framework/Versions/A/AppServerSupport
    0x7fff2b7ca000 -     0x7fff2b7dcfff  libhvf.dylib (1.0 - $[CURRENT_PROJECT_VERSION]) <A4E8327C-E3BF-3295-A3D1-68F579D020E4> /System/Library/PrivateFrameworks/FontServices.framework/libhvf.dylib
    0x7fff2b7dd000 -     0x7fff2b7dffff  libspindump.dylib (295.3) <E090FDF1-6C64-39B9-A750-63EC6AB7E0C1> /usr/lib/libspindump.dylib
    0x7fff2b7e0000 -     0x7fff2b8a0fff  com.apple.Heimdal (4.0 - 2.0) <52976F1C-2F22-397A-8F21-38BEB3061DC2> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
    0x7fff2ba40000 -     0x7fff2ba7cfff  com.apple.bom (14.0 - 235.3) <B849E4CE-F977-3F27-857C-8000AD4FE041> /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
    0x7fff2ba7d000 -     0x7fff2bac6fff  com.apple.AppleJPEG (1.0 - 1) <2A8FF19B-B937-3F0B-A59B-A9A8B24F53E6> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
    0x7fff2bac7000 -     0x7fff2bba6fff  libJP2.dylib (2130.15.1) <C2B32668-634C-3381-9198-D4FD35C2D616> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
    0x7fff2bba7000 -     0x7fff2bbaafff  com.apple.WatchdogClient.framework (1.0 - 98.120.2) <2907CD2F-A115-34CF-BB9D-DCFEBAEE78F3> /System/Library/PrivateFrameworks/WatchdogClient.framework/Versions/A/WatchdogClient
    0x7fff2bbab000 -     0x7fff2bbe1fff  com.apple.MultitouchSupport.framework (4440.3.1 - 4440.3.1) <9F19F332-ADC4-3D35-A9ED-C62AC334A704> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
    0x7fff2bbe2000 -     0x7fff2bd40fff  com.apple.VideoToolbox (1.0 - 2780.10.4.1.1) <774F6519-3AF4-3B1C-BCA8-72B287B8CF05> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
    0x7fff2bd41000 -     0x7fff2bd74fff  libAudioToolboxUtility.dylib (1181.72.5) <F1E3759E-BE9B-30CE-97F0-669ECD0F012F> /usr/lib/libAudioToolboxUtility.dylib
    0x7fff2bd75000 -     0x7fff2bd95fff  libPng.dylib (2130.15.1) <AA721061-95C4-31E0-9E1A-F375334CFBD5> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
    0x7fff2bd96000 -     0x7fff2bdf7fff  libTIFF.dylib (2130.15.1) <805390BE-34D6-3199-BA77-D38412B6D61C> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
    0x7fff2bdf8000 -     0x7fff2be14fff  com.apple.IOPresentment (58 - 37) <BA4B88DD-52FF-3F07-82E2-533E7D6548C0> /System/Library/PrivateFrameworks/IOPresentment.framework/Versions/A/IOPresentment
    0x7fff2be15000 -     0x7fff2be1cfff  com.apple.GPUWrangler (6.3.6 - 6.3.6) <D41B27C4-9FC6-3F2F-8C65-06F9ED6EE43D> /System/Library/PrivateFrameworks/GPUWrangler.framework/Versions/A/GPUWrangler
    0x7fff2be1d000 -     0x7fff2be20fff  libRadiance.dylib (2130.15.1) <53A4F5E3-2CC7-3F4C-A61B-9561A27FAB3B> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
    0x7fff2be21000 -     0x7fff2be26fff  com.apple.DSExternalDisplay (3.1 - 380) <85C7B7A3-8E61-3773-A7A1-0E594C390144> /System/Library/PrivateFrameworks/DSExternalDisplay.framework/Versions/A/DSExternalDisplay
    0x7fff2be27000 -     0x7fff2be4bfff  libJPEG.dylib (2130.15.1) <9C80AB07-FC1C-3AE5-9175-44A1F25107B2> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
    0x7fff2be4c000 -     0x7fff2be7bfff  com.apple.ATSUI (1.0 - 1) <D64FE353-AFFA-3B55-8E85-F222434E2FC1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATSUI.framework/Versions/A/ATSUI
    0x7fff2be7c000 -     0x7fff2be80fff  libGIF.dylib (2130.15.1) <D4B17FC0-E79B-39CC-ABBC-7332A13E0AAF> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
    0x7fff2be81000 -     0x7fff2be8afff  com.apple.CMCaptureCore (1.0 - 82.6) <E96DDCE5-8BCF-392D-84C6-87D76BC9DF9A> /System/Library/PrivateFrameworks/CMCaptureCore.framework/Versions/A/CMCaptureCore
    0x7fff2be8b000 -     0x7fff2bed2fff  com.apple.print.framework.PrintCore (16.1 - 531.1) <D8F84239-11A0-311F-A66C-99C87F99D879> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
    0x7fff2bed3000 -     0x7fff2bfa0fff  com.apple.TextureIO (3.10.9 - 3.10.9) <3AC1D19C-DACE-33A7-9C89-BDD3D38A7080> /System/Library/PrivateFrameworks/TextureIO.framework/Versions/A/TextureIO
    0x7fff2bfa1000 -     0x7fff2bfa9fff  com.apple.InternationalSupport (1.0 - 61.1) <D4CAEFD9-602F-3112-AD33-A674F2A6EC7F> /System/Library/PrivateFrameworks/InternationalSupport.framework/Versions/A/InternationalSupport
    0x7fff2bfaa000 -     0x7fff2c024fff  com.apple.datadetectorscore (8.0 - 674) <3B902938-2B3E-31A5-A57B-151BBB5D8BC8> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
    0x7fff2c025000 -     0x7fff2c082fff  com.apple.UserActivity (439 - 439) <59BC012A-4927-3FB9-9AEF-75F0096A1548> /System/Library/PrivateFrameworks/UserActivity.framework/Versions/A/UserActivity
    0x7fff2c820000 -     0x7fff2c888fff  libusrtcp.dylib (2288.140.9) <B2AC18A1-14F0-3E98-AD39-CCADD02BC73A> /usr/lib/libusrtcp.dylib
    0x7fff2ccc7000 -     0x7fff2cceffff  com.apple.locationsupport (2420.19.23 - 2420.19.23) <3A08E563-896C-36BA-A111-F9581DCAC8BD> /System/Library/PrivateFrameworks/LocationSupport.framework/Versions/A/LocationSupport
    0x7fff2ccf0000 -     0x7fff2cd21fff  libSessionUtility.dylib (76.69) <9CA8B6AC-ADC8-3805-A7AE-2532B3C0EBB0> /System/Library/PrivateFrameworks/AudioSession.framework/libSessionUtility.dylib
    0x7fff2cd22000 -     0x7fff2ce56fff  com.apple.audio.toolbox.AudioToolbox (1.14 - 1.14) <99F6F2D8-189D-398C-A38C-B6B49F66A6E8> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
    0x7fff2ce57000 -     0x7fff2cebcfff  com.apple.audio.AudioSession (1.0 - 76.69) <85C29DF5-2A9A-3029-8AF5-91E83074C414> /System/Library/PrivateFrameworks/AudioSession.framework/Versions/A/AudioSession
    0x7fff2cebd000 -     0x7fff2cecffff  libAudioStatistics.dylib (27.64) <C46ED1DB-C7F4-3E56-B992-25821F9B1CE1> /usr/lib/libAudioStatistics.dylib
    0x7fff2ced0000 -     0x7fff2cedffff  com.apple.speech.synthesis.framework (9.0.66 - 9.0.66) <1746AB65-AAAA-3BAB-AAD3-C158FB532798> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
    0x7fff2cee0000 -     0x7fff2cf4cfff  com.apple.ApplicationServices.ATS (377 - 516) <484D4858-74A8-3541-91E5-2C74F70A3824> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
    0x7fff2cf4d000 -     0x7fff2cf65fff  libresolv.9.dylib (68.2) <78461752-674E-35D5-94D6-17E627802577> /usr/lib/libresolv.9.dylib
    0x7fff2d098000 -     0x7fff2d177fff  libSMC.dylib (20) <038349BC-2D55-3E20-B3C3-BFEEA36E730A> /usr/lib/libSMC.dylib
    0x7fff2d178000 -     0x7fff2d1d7fff  libcups.2.dylib (494.6) <1D5E2150-45D5-354B-ABE3-5B1996D1EAB4> /usr/lib/libcups.2.dylib
    0x7fff2d1d8000 -     0x7fff2d1e7fff  com.apple.LangAnalysis (1.7.0 - 254) <EEF814D5-A3F9-3FF4-8F1B-D6083AFAEC52> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
    0x7fff2d1e8000 -     0x7fff2d1f2fff  com.apple.NetAuth (6.2 - 6.2) <2FB90509-3BD8-39CF-BE6A-5490F84FF284> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
    0x7fff2d1f3000 -     0x7fff2d1fafff  com.apple.ColorSyncLegacy (4.13.0 - 1) <00861A68-F725-3E01-BDB9-64823636DD90> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSyncLegacy.framework/Versions/A/ColorSyncLegacy
    0x7fff2d1fb000 -     0x7fff2d206fff  com.apple.QD (4.0 - 416) <AAE33CA8-0995-3BA3-B5CE-4ED19706BB44> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
    0x7fff2d207000 -     0x7fff2d85bfff  com.apple.audio.AudioResourceArbitration (1.0 - 1) <09E26A64-0C70-38AD-B9C9-7F8847E1F09F> /System/Library/PrivateFrameworks/AudioResourceArbitration.framework/Versions/A/AudioResourceArbitration
    0x7fff2d85c000 -     0x7fff2d867fff  com.apple.perfdata (1.0 - 67.40.1) <4A3F192A-2416-3D16-B318-A160264359DE> /System/Library/PrivateFrameworks/perfdata.framework/Versions/A/perfdata
    0x7fff2d868000 -     0x7fff2d876fff  libperfcheck.dylib (41) <7D626792-9A87-3A1F-BE6E-C7D8FE62B800> /usr/lib/libperfcheck.dylib
    0x7fff2d877000 -     0x7fff2d886fff  com.apple.Kerberos (3.0 - 1) <69B24A09-0788-3ACA-A01C-358746980694> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
    0x7fff2d887000 -     0x7fff2d8d7fff  com.apple.GSS (4.0 - 2.0) <5C6BCBC8-F041-3588-AC99-94CD85737E2B> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
    0x7fff2d8d8000 -     0x7fff2d8e8fff  com.apple.CommonAuth (4.0 - 2.0) <82E6D81F-8B40-3986-B5F2-CF151AD8C06C> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
    0x7fff2d93e000 -     0x7fff2d95dfff  com.apple.security.KeychainCircle.KeychainCircle (1.0 - 1) <AAC60400-EE4B-3218-BA43-0E65E456DD66> /System/Library/PrivateFrameworks/KeychainCircle.framework/Versions/A/KeychainCircle
    0x7fff2d95e000 -     0x7fff2d966fff  com.apple.CorePhoneNumbers (1.0 - 1) <463A5379-F673-3712-8422-9A0DA38D75E5> /System/Library/PrivateFrameworks/CorePhoneNumbers.framework/Versions/A/CorePhoneNumbers
    0x7fff2d967000 -     0x7fff2d9f0fff  libTelephonyUtilDynamic.dylib (5359.1) <33FC7675-E872-3D9D-9423-3A979FBCE29A> /usr/lib/libTelephonyUtilDynamic.dylib
    0x7fff2dab9000 -     0x7fff2dab9fff  liblaunch.dylib (2038.120.1.700.2) <E8DA6C72-9C09-3791-8F1D-49F552EC77D7> /usr/lib/system/liblaunch.dylib
    0x7fff2e2a0000 -     0x7fff2e3ebfff  com.apple.Sharing (1630 - 1630) <35DFD4B9-28E6-35BE-AD57-6959C23715B4> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
    0x7fff2e3ec000 -     0x7fff2e50dfff  com.apple.Bluetooth (8.0.5 - 8.0.5d7) <173115D9-072B-3205-8A79-419EE173EB9E> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
    0x7fff2e527000 -     0x7fff2e580fff  com.apple.ProtectedCloudStorage (1.0 - 1) <D3CB43FC-19DA-37A6-A823-62B5D8F3714A> /System/Library/PrivateFrameworks/ProtectedCloudStorage.framework/Versions/A/ProtectedCloudStorage
    0x7fff2e7e0000 -     0x7fff2fcdbfff  com.apple.GeoServices (1.0 - 1757.26.6.2.3) <E0958986-903A-315D-9913-FBE5784EFFA5> /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/GeoServices
    0x7fff2fce8000 -     0x7fff2fd0ffff  com.apple.RemoteViewServices (2.0 - 163) <960463A4-6F65-3E89-8918-FA77BF9F6ADC> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
    0x7fff2fd10000 -     0x7fff2fd1ffff  com.apple.SpeechRecognitionCore (6.1.25 - 6.1.25) <08338B73-5E68-33E3-93DC-F5BAF287CF82> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecognitionCore
    0x7fff2fd20000 -     0x7fff2fd27fff  com.apple.speech.recognition.framework (6.0.3 - 6.0.3) <927F7D7F-8BD2-3EF2-A239-C20010C2149E> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
    0x7fff2ff55000 -     0x7fff2ff55fff  libsystem_product_info_filter.dylib (8.40.1) <BB06C92C-6BD7-310C-A176-DC0DCE8D9F2B> /usr/lib/system/libsystem_product_info_filter.dylib
    0x7fff3002d000 -     0x7fff3002dfff  com.apple.Accelerate.vecLib (3.11 - vecLib 3.11) <F46E0ACF-7524-3CA3-A64A-5DDF6081EB67> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
    0x7fff30053000 -     0x7fff30053fff  com.apple.CoreServices (1122.45 - 1122.45) <C3145415-E2CC-355B-9400-047C46FF1044> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
    0x7fff3020f000 -     0x7fff3020ffff  com.apple.Accelerate (1.11 - Accelerate 1.11) <3D8DECC6-19B3-3A32-98CF-EB07536D1635> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
    0x7fff3027c000 -     0x7fff30280fff  com.apple.AppleSRP (5.0 - 1) <07D9751D-89E5-37C3-8DBA-764CF8EAD2EB> /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP
    0x7fff30281000 -     0x7fff3028cfff  com.apple.frameworks.CoreDaemon (1.3 - 1.3) <A0235B63-1146-385F-8EEC-2E02CF1C24C0> /System/Library/PrivateFrameworks/CoreDaemon.framework/Versions/B/CoreDaemon
    0x7fff30a52000 -     0x7fff30ab7fff  com.apple.CoreBluetooth (1.0 - 1) <EABA3795-3E43-3CA7-BA08-530E2934608E> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
    0x7fff30ab8000 -     0x7fff30ac1fff  com.apple.SymptomDiagnosticReporter (1.0 - 79.120.1) <D764B1B5-3D72-3E24-AD98-47FD4716F03B> /System/Library/PrivateFrameworks/SymptomDiagnosticReporter.framework/Versions/A/SymptomDiagnosticReporter
    0x7fff30ac2000 -     0x7fff30ad4fff  com.apple.PowerLog (1.0 - 1) <986B448C-A89F-3C1D-AED2-64D094F9326E> /System/Library/PrivateFrameworks/PowerLog.framework/Versions/A/PowerLog
    0x7fff30ad5000 -     0x7fff30ae1fff  com.apple.AppleIDAuthSupport (1.0 - 1) <B3A39FB5-40F3-381D-B7E1-B679241F5643> /System/Library/PrivateFrameworks/AppleIDAuthSupport.framework/Versions/A/AppleIDAuthSupport
    0x7fff30ae2000 -     0x7fff30b8afff  com.apple.DiscRecording (9.0.3 - 9030.4.5) <2EB0A304-1C88-350B-BDFA-B9F73767D44C> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
    0x7fff30b8b000 -     0x7fff30bbefff  com.apple.MediaKit (16 - 927.40.2) <058F1A64-1627-3D16-89D3-5BF269940F83> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
    0x7fff30bbf000 -     0x7fff30caafff  com.apple.DiskManagement (14.0 - 1733.140.2) <037C755C-7622-37EC-9795-50169FBA1374> /System/Library/PrivateFrameworks/DiskManagement.framework/Versions/A/DiskManagement
    0x7fff31098000 -     0x7fff311e7fff  com.apple.FileProvider (349.141.2.700.1 - 349.141.2.700.1) <8A840A12-246F-36D5-ADAC-DEE495B068FF> /System/Library/Frameworks/FileProvider.framework/Versions/A/FileProvider
    0x7fff311e8000 -     0x7fff3120afff  com.apple.GenerationalStorage (2.0 - 323) <A5B45271-8338-3884-AFA9-0DDEB7C8D2E5> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
    0x7fff31580000 -     0x7fff3164efff  com.apple.CoreTelephony (113 - 8260.1) <BAB8C462-7025-35AE-9FF2-080C1605F5CA> /System/Library/Frameworks/CoreTelephony.framework/Versions/A/CoreTelephony
    0x7fff31808000 -     0x7fff31877fff  com.apple.FrontBoardServices (703.16.1 - 703.16.1) <5A37EA4D-5048-346A-A108-85C85322CA4B> /System/Library/PrivateFrameworks/FrontBoardServices.framework/Versions/A/FrontBoardServices
    0x7fff31878000 -     0x7fff318a1fff  com.apple.BoardServices (1.0 - 526) <4291EACE-21EB-3FBB-B047-928ACB10B126> /System/Library/PrivateFrameworks/BoardServices.framework/Versions/A/BoardServices
    0x7fff31b46000 -     0x7fff31b81fff  com.apple.DebugSymbols (195.1 - 195.1) <CE654754-3ECE-3E2C-9194-5AE0CF9C3BE9> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
    0x7fff31b82000 -     0x7fff31c37fff  com.apple.CoreSymbolication (12.5 - 64544.81.1) <47B26D54-12C1-32BF-BF40-062AAEB11699> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
    0x7fff31c38000 -     0x7fff31c41fff  com.apple.CoreTime (284.0.4) <28FC6634-B10D-3C3A-A82B-9FD35A4EFA5D> /System/Library/PrivateFrameworks/CoreTime.framework/Versions/A/CoreTime
    0x7fff31c42000 -     0x7fff31cb7fff  com.apple.Rapport (2.6.0 - 260.3) <458FD1B0-87E6-31D6-A9E9-F61346208D62> /System/Library/PrivateFrameworks/Rapport.framework/Versions/A/Rapport
    0x7fff3258c000 -     0x7fff325d8fff  com.apple.coreduetcontext (1.0 - 1) <2038763E-79C0-34B2-B359-6E2BBACF7FFC> /System/Library/PrivateFrameworks/CoreDuetContext.framework/Versions/A/CoreDuetContext
    0x7fff325d9000 -     0x7fff32b45fff  com.apple.Intents (1.0 - 1) <E386CC66-77ED-3E6D-B39A-AABA32F9F53B> /System/Library/Frameworks/Intents.framework/Versions/A/Intents
    0x7fff32b46000 -     0x7fff32ba9fff  com.apple.framework.Apple80211 (17.0 - 1728) <4A2AFAA7-94A4-3DE1-B078-0ABE71A868D1> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
    0x7fff32baa000 -     0x7fff32cfbfff  com.apple.CoreWiFi (3.0 - 341) <A17FE96E-6C9B-3C1A-8DF5-A28450F53926> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi
    0x7fff32cfc000 -     0x7fff32d16fff  com.apple.BackBoardServices (1.0 - 1.0) <49254756-6605-3D38-B6BB-61B1F7DB46A8> /System/Library/PrivateFrameworks/BackBoardServices.framework/Versions/A/BackBoardServices
    0x7fff32f6c000 -     0x7fff32f7bfff  com.apple.RemoteServiceDiscovery (1.0 - 1.120.1) <770FE929-BBEB-37E0-9BF1-288A41809A4A> /System/Library/PrivateFrameworks/RemoteServiceDiscovery.framework/Versions/A/RemoteServiceDiscovery
    0x7fff32fdd000 -     0x7fff32fe4fff  com.apple.EFILogin (2.0 - 2) <5379A1B7-201D-333C-BCF5-005C4B30EE14> /System/Library/PrivateFrameworks/EFILogin.framework/Versions/A/EFILogin
    0x7fff32fe5000 -     0x7fff32ff0fff  libcsfde.dylib (554.140.2) <71B9E18E-B9B1-3E17-933E-64ADF6F7B5D7> /usr/lib/libcsfde.dylib
    0x7fff3306c000 -     0x7fff330cefff  com.apple.AppSupport (1.0.0 - 29) <FBDB573A-D054-37D3-8F14-7C20A587402E> /System/Library/PrivateFrameworks/AppSupport.framework/Versions/A/AppSupport
    0x7fff3323b000 -     0x7fff3323bfff  com.apple.ApplicationServices (48 - 50) <CBF1F8E2-1AD8-36C6-9D1C-6ED9CE9B2F95> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
    0x7fff33550000 -     0x7fff33550fff  libHeimdalProxy.dylib (79) <69042CA5-B0DE-392D-8B32-51446EA228C5> /System/Library/Frameworks/Kerberos.framework/Versions/A/Libraries/libHeimdalProxy.dylib
    0x7fff33603000 -     0x7fff33603fff  com.apple.audio.units.AudioUnit (1.14 - 1.14) <1A2C9DDE-749F-3134-9F0A-2BC6C4E08AC0> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
    0x7fff3366b000 -     0x7fff33689fff  com.apple.DuetActivityScheduler (1.0 - 1) <7C81F246-DA7F-3670-B209-E2F39B4D6607> /System/Library/PrivateFrameworks/DuetActivityScheduler.framework/Versions/A/DuetActivityScheduler
    0x7fff3369e000 -     0x7fff336aafff  com.apple.IntentsFoundation (1.0 - 1) <E96F3782-546A-3F0B-B78F-D93CFBBB0E64> /System/Library/PrivateFrameworks/IntentsFoundation.framework/Versions/A/IntentsFoundation
    0x7fff336ab000 -     0x7fff336b0fff  com.apple.PushKit (1.0 - 1) <FDBA00A7-699D-3BF7-A038-13FC6F384E42> /System/Library/Frameworks/PushKit.framework/Versions/A/PushKit
    0x7fff336b1000 -     0x7fff336e4fff  com.apple.C2 (1.3 - 573) <83D1DC55-8A4A-39A6-8850-243044E35DD4> /System/Library/PrivateFrameworks/C2.framework/Versions/A/C2
    0x7fff34044000 -     0x7fff34046fff  com.apple.CoreDuetDebugLogging (1.0 - 1) <B97F59AF-49D5-3135-BBD9-6C574C766B32> /System/Library/PrivateFrameworks/CoreDuetDebugLogging.framework/Versions/A/CoreDuetDebugLogging
    0x7fff34047000 -     0x7fff34053fff  com.apple.CoreDuetDaemonProtocol (1.0 - 1) <F1448256-FCDF-3FA0-9474-B5F32E115398> /System/Library/PrivateFrameworks/CoreDuetDaemonProtocol.framework/Versions/A/CoreDuetDaemonProtocol
    0x7fff345d3000 -     0x7fff34623fff  com.apple.ChunkingLibrary (334.1 - 334.1) <EE9D29D9-4BA8-3B6D-9AEC-5C9A90FD8AD2> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
    0x7fff35037000 -     0x7fff3503afff  com.apple.Cocoa (6.11 - 23) <15A15258-98A1-31F1-AE6C-D3B2265EF419> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
    0x7fff3cc7b000 -     0x7fff3cd0efff  libquic.dylib (2288.140.9) <284779AC-9F20-3BB3-A68A-EEDF69D962ED> /usr/lib/libquic.dylib
    0x7fff3cd19000 -     0x7fff3cd38fff  com.apple.private.SystemPolicy (1.0 - 1) <89781097-BA30-3186-B368-3830D1FE4FC0> /System/Library/PrivateFrameworks/SystemPolicy.framework/Versions/A/SystemPolicy
    0x7fff3d656000 -     0x7fff3d661fff  com.apple.MallocStackLogging (1.0 - 1) <6DBA8C72-0F01-3679-942D-746726306459> /System/Library/PrivateFrameworks/MallocStackLogging.framework/Versions/A/MallocStackLogging
    0x7fff3d662000 -     0x7fff3d664fff  liblog_network.dylib (2288.140.9) <E389893F-AEC1-36BA-948D-BD6D2B7B068A> /usr/lib/log/liblog_network.dylib
    0x7fff3d676000 -     0x7fff3d688fff  libmis.dylib (274.140.2) <D8990A31-A5AE-3535-BE5E-3EE9A8D0C9F9> /usr/lib/libmis.dylib
    0x7fff47a61000 -     0x7fff47aa2fff  com.apple.osanalytics.OSAnalytics (1.0 - 1) <4A29103B-7A09-313F-9406-F21F29DAB78E> /System/Library/PrivateFrameworks/OSAnalytics.framework/Versions/A/OSAnalytics
    0x7fff5153d000 -     0x7fff515dcfff  com.apple.Symbolication (12.5 - 64544.70.3) <40591E3B-8121-3AB4-95CE-94F44DB2A24E> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
    0x7fff6b9d3000 -     0x7fff6b9d9fff  libCoreFSCache.dylib (200.12) <B6360761-3B05-35AE-8E0C-F819414FD093> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
    0x7fff6b9da000 -     0x7fff6b9defff  libCoreVMClient.dylib (200.12) <4D617E02-85B8-3BC2-82FE-5CEA77809181> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
    0x7fff6b9df000 -     0x7fff6b9eefff  com.apple.opengl (18.5.9 - 18.5.9) <610E765C-8C0D-3422-AD6E-636D3EBD2AD0> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
    0x7fff6b9ef000 -     0x7fff6b9f1fff  libCVMSPluginSupport.dylib (18.5.9) <C7B33518-2685-3985-ABCB-FC3B0105748C> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
    0x7fff6b9f2000 -     0x7fff6b9fafff  libGFXShared.dylib (18.5.9) <AD53ED9A-C694-3EF4-863E-898E88F6D84C> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
    0x7fff6b9fb000 -     0x7fff6ba2efff  libGLImage.dylib (18.5.9) <6C478ED9-E513-3E43-B9F1-D15A20A0EE85> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
    0x7fff6ba2f000 -     0x7fff6ba6bfff  libGLU.dylib (18.5.9) <D5473328-FD13-36A5-9CAC-CF4F59CDAA29> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
    0x7fff6bc00000 -     0x7fff6bc0afff  libGL.dylib (18.5.9) <08A0476A-D04F-3816-AA4D-11EC2467F748> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
    0x7fff6d04a000 -     0x7fff6d0a2fff  com.apple.opencl (4.6 - 4.6) <8C87D26C-12C6-33E8-AE32-45B699667DB3> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
    0x7fff77639000 -     0x7fff77640fff  libRosetta.dylib (203.58) <AC9E8A76-FCAA-3F97-802A-D22EF770463B> /usr/lib/libRosetta.dylib
External Modification Summary:
  Calls made by other processes targeting this process:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
  Calls made by this process:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
  Calls made by all processes on this machine:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=740.4M resident=0K(0%) swapped_out_or_unallocated=740.4M(100%)
Writable regions: Total=1.2G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=1.2G(100%)
                                VIRTUAL   REGION
REGION TYPE                        SIZE    COUNT (non-coalesced)
Activity Tracing                   256K        1
Dispatch continuations            64.0M        1
Kernel Alloc Once                    8K        1
MALLOC                           143.3M       47
MALLOC guard page                   72K       14
MALLOC_MEDIUM (reserved)         960.0M        8         reserved VM address space (unallocated)
SQLite page cache                  192K        3
STACK GUARD                       56.1M       27
Stack                             21.3M       37
VM_ALLOCATE                       10.0M       14
__DATA                            14.4M      356
__DATA_CONST                      15.7M      184
__DATA_DIRTY                       882K      122
__FONT_DATA                          4K        1
__LINKEDIT                       503.4M       61
__OBJC_RO                         70.2M        1
__OBJC_RW                         2496K        2
__TEXT                           237.2M      353
__UNICODE                          588K        1
libnetwork                         128K        8
mapped file                       43.7M        9
shared memory                      756K       15
TOTAL                              2.1G     1266
TOTAL, minus reserved VM space     1.2G     1266
Wed May 24, 2023 3:23 pm
Re: Indigo Server restarting occasionally
Hi Jason,
I wouldn't read too much into the Time Awake Since Boot crash report field on the crash report. Those values almost always appear to be rounded or imprecise.
Does the Event Log around 9:16 (several minutes before) look the same as the Event Log you originally posted?
I decoded the stack trace of the crash report but unfortunately it didn't provide many clues. I think some memory pointers are becoming corrupt before the crash, which then later causes the crash when memory is allocated. That is, by the time the crash happens it is already off the road and into the weeds so determining what caused the actual problem is difficult.
Mon May 29, 2023 3:45 pm
Jason G. offline
There was nothing unusual in the event logs from 5/24 leading up to any of the 3 times it crashed that day. Just lights turning on and off like normal, based on me and my family's activities.
And oddly, it hasn't crashed since - yeah it's only 5 days, but it was crashing almost every day the prior ~6 days. I haven't rebooted since 5/24, nor done anything else to change the Mac's behavior or setup...
I'll circle back around if it happens again, but at this point I'm willing to chalk the crashes up to gremlins or bad juju.
Thanks for your help!
PS - Thanks for the perspective on Time Awake Since Boot, even though it looks suspicious I don't look at these things as often as you do.
