API Keys for Server
Fri Jun 16, 2023 2:28 pm
Turribeach offline
Re: API Keys for Server
I think this is a different problem, it can't validate the cert. They have recently renewed their cert so it could be either you are getting the old cert or your setup can't validate it.
Screenshot 2023-06-16 at 21.25.24.png (65.46 KiB) Viewed 1685 times
Can you install this on your Indigo's Python install?
pip install --upgrade certifi
Fri Jun 16, 2023 2:41 pm
Vaillant offline
Also getting Error Unable to connect to IndigoDomo.com
Not happy how this is implemented :(
Fri Jun 16, 2023 2:48 pm
mike_c offline
I appreciate the error may be different but the root cause (needing to connect to a remote server to run things locally) is the same.
I’m unfamiliar with indigos python install. I don’t run any embedded scripts. Further instructions appreciated.
Fri Jun 16, 2023 4:14 pm
We are experiencing a server problem. Actively working on it now and will post when it is fixed.
Fri Jun 16, 2023 4:36 pm
We had a problem with how a new SSL certificate was installed on our server which caused problems for the Indigo Server.
It is fixed now, but may take 15 minutes for your reflector to re-establish itself. Appreciate everyone's patience with this not working earlier.
Fri Jun 16, 2023 4:58 pm
mike_c offline
As of 23:57 (uk time) and a quick server reboot, all appears to be operational again. Thanks
Wed Oct 04, 2023 2:25 pm
The original post on this thread was requesting API keys that don't require backend calls to our server for validation. The most recent release (2023.1.0) now has this capability via what we call Local Secrets.
Sun Oct 08, 2023 5:49 am
Turribeach offline
Many thanks for fulfilling this. I would have preferred to call them local keys and also to use public/private API keys to avoid having hardcoded keys in plain text config files but this would do nicely for the people like me that want full offline mode operation.
Mon Oct 09, 2023 3:29 pm
Turribeach offline
PS: A bit of FUD on the logging message when using local secrets...
 Web Server Warning              HTTP API v2 POST command received, id: 'optional-user-generated-id' from '192.168.111.11'
Mon Oct 09, 2023 6:27 pm
That's not FUD. We believe (based on prior feedback among other things) that users should be very aware of any incoming API connections. This message is shown for all API messages (not just for those using local secrets). You can turn off these warnings in the new Advanced Web Server Config dialog.
Tue Oct 10, 2023 12:11 am
Turribeach offline
I agree on that 100%. I just don’t think an API call should be logged as a Warning message and neither should be highlighted in yellow (which is a side effect of logging it as a warning). So if I want logging I need to leave the warning messages.
